How to load program v5.14mon DGIX-32014T - Computers & Internet
How to set a Kes load control timer model ISG1201
The Geyser Load Control Timer, ISG1201, is designed to prevent geyser from operating during the Eskom's designated weekly morning and evening peak times. The ISG1201 features 4 easily selectable, pre-programmed, geysers "ON" operating profiles to ensure maximum comfort whilst not burdening the user with the complicated process of having to program the unit.
The profiles are as follows;
  • Program (1) is always "ON"
  • Program (2) "ON" after sunset to accommodate solar geysers
  • Program (3) "OFF" all the time
  • Program (4) savings program - "ON" 6 hours weekdays and 12 hours weekend days
Oct 31, 2013 | Hardware & Accessories
T61 won't go past the Microsoft loading screen
Press F8 during boot, and load Safe Mode. A program may be preventing a proper startup.
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig > Startup tab and uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running.
This just disables them in startup. Programs will still load, but when you initiate.
Oct 01, 2012 | IBM Lenovo ThinkPad T61 Notebook
My computer is too slow - how do I make it faster?
Slow Start Up
There can be a variety of reasons to Windows loading slow during start up. Go to Run, type msconfig and hit enter. Under the 'Start Up' tab, uncheck the unwanted programs and press OK. Things should be a bit fine the next time Windows boots.
Another program worth mentioning here is StartUp Delayer which will help in setting after how much time programs should be loaded after Windows boots. For instance, you could set your instant messenger program to load 50 seconds after Windows starts up.
Slow Loading Start Menu
If the Start Menu items are loading slowly, you can open the Registry Editor by typing in the Run menu 'regedit.exe' and pressing Enter. Go to HKEY_CURRENT_USERControl PanelDesktop. Look for MenuShowDelay, and double click to edit the value. The lower the number specified, the faster the Start Menu will load.
Slow Right Click Context Menu
Probably the Windows Right Click menu on your computer is loading slow because too many programs added unwanted entries there. Just download this program called Mmm, install it and then modify your context menu to remove unwanted items to speed it up.
win-fixes-send-to.jpg Slow Send To Menu
If the Send To menu loads slowly, you can type 'sendto' in the Run Dialog, and remove unwanted items in the Explorer Window that appears. This should add some speed to it.
Slow Defragmentation
The Windows Defragmenter can't get any slower. You need to have an alternative to the Windows Defragmenter, and Defraggler is just one of the best ones available in the market. It's free, and works like a charm and can speed up defragmentation manifold. For some alternatives, see Five Free Programs to Defragment your PC.
Aug 11, 2011 | Computers & Internet
Cant find my webcam icon or anything to click on with a webcam symbol for a emachine mini notebook??
goto control panel goto uninstall program..see if webcam program is loaded...if not close uninstall program... load webcam program
Nov 25, 2010 | E-Machines Computers & Internet
Hello: I recently bought MasterCook Version 11. I presently have version 6.2 on my computer. Can I just install my new version 11 without changing any recipes that I have already added to my present...
If you load a new version of an existing program, it may depend on the new program whether it will overide and revise the existing program or whether it will load as a totally seperate program; thereby having both old and new programs available and most likely 2 different icons on your desktop screen (one for each version).
Some upgrade (Newer) versions will give you the option of choosing to keep the old and have the new one loaded without any interference to the existing version, or to have the new version "take-in" the information of the existing version and then eliminate the need for existing program . In either case, you will not hurt or lose info (that already exits) when loading the new program .
Jul 28, 2010 | ValuSoft Computers & Internet
My pc takes forver to come up. It is loading too many progams and i don't know how to stop them from loading at start up.
If u dont want all the programs to load up when the notebook is booting to the desktop then u can follow these steps which will reduce the time taken by the notebook to boot up-->click on the "Start" option-->u will get a search box just above the start option-->type "msconfig" in the search box & an option of msconfig will appear-->click on that option-->a window of "system configuration" will come up-->click on the tab which reflects "startup"-->now under this tab u will get the list of programs which load up while ur notebook is booting-->so barring a few programs which u need to load while the notebook is loading, u can uncheck the other programs-->unchecking these programs will reduce the boot up time of notebook-->but this doesn't mean that u wont be able to use the disabled programs-->u can double click on the desktop shortcut of the program to start the program, the only thing is that the program will take more than the usual time to load up as it didnt load up at the time of booting-->then click on apply & OK, the booting speed of ur notebook will increase... Note: Do not do any changes in the "services" option as it might damage ur notebook,,,
Jul 23, 2010 | HP Compaq Presario V2000 Notebook
Farmville will not load on the computer, it starts up and then the yellow bar stops half way and stays there
You have to clear history, cache and cookies.
There may be a bug/virus preventing you from loading the page.
Then try to log-in.
If you still can't load farmville, try to load in on another internet server.
Feb 27, 2010 | MPC Computers TransPort T3000 Notebook
Software loading problem
whats ur operating system. i think it is vista. that may be the compatiblity problem with ur software. try it on windows XP . it will solve.. if u want to work it on vista, then u have to download a vista supporting version of that particular software...thats all
Dec 07, 2007 | HP Pavilion dv4000 Notebook
Computers & Internet Logo
22 people viewed this question
David Payne
David Payne
