Back to:
Tags:
Hoover F7425-900 SteamVac V2 Widepath Upright Vacuum
Hoover carpet cleaner f7425-900 (by 5 users)
posted by smedmainman on Nov 21, 2007
brushes do not rotate, here a high pitch when i turn it on. brushes move by hand easily
I have the same problem Post a new problem
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
4 Other Users Have The Same Problem
Comment by Guest, posted on Apr 21, 2008
MY BRUSHES ARE NOT ROTATING I CLEANED THE FILTER TURNED IT TO ON POSITION AND STILL WONT WORK ANY ADDITIONAL SOLUTUION S FOR THIS PROBLEM?
Comment by Guest, posted on Apr 14, 2008
the
Comment by ca11a, posted on Dec 22, 2007
brushes will not turn when running but turn freely by hand
Comment by scouser2, posted on Nov 26, 2007
In adddition to brushes not rotating leaks during operation.
Best Solution
posted on Apr 11, 2008
FixYa! (100)
Guest
Rank:Apprentice Apprentice
Rating: 0%, 0 votes
The brushes will not rotate until the handle is released and the pulled backward, the switch should change from handtools to floor
Was this solution helpful? Show your Appreciation by rating it:
Thank You!
Was the solution helpful?
Show your appreciation by commenting on hoover carpet cleaner f7425-900:
I don't want to Accept this solution
Solution #2
posted on Dec 25, 2007
FixYa! (100)
Guest
Rating: 0%, 0 votes
the brushes are run on a vacuum the switch may no be opening
Thank You!
Solution #3
posted on May 13, 2008
Not Rated (0)
vac tube
Rating: 0%, 0 votes
The brushes are driven by air flow from the main motor. There is a gear assy above the brushes that has a metal gear/bearing that seazes up. I used teflon spray lube to free up the bearing. This requires alot of dis-assembly to access that assy.
Thank You!
Can you Help with these Vacuums problems?
Hoover F7425-900 SteamVac V2 Widepath...
Hi there! I am somewhat handy, but, not a savant by any...
its not picking anything up i find it all over the floor...
where does the solution tube plug in
When I turn on my steam cleaner the water pours out from...
Hoover all terrain steamVac brushes wont move. Does this...
Loading problems.
Repair Service
Prescreened Contractors
Get Matched to Prescreened Appliance Services
Category
Zip code
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
