Question about Dishwashers
Please what does the water inlet valve look like a picture will be nice
  • 1462 Answers
SOURCE: Washing Machine fills slowly how to change inlet valve
switch off power remove top switch off water and remove hose. remove inside pipe from valve - usually held by just a spring clip remove electrical terminals valve is just held with a couple of screws usually - remove these and valve will come away. put back in same order
Posted on Jun 22, 2007
  • 1073 Answers
SOURCE: Changing the water inlet valve
remove the top, the water lines from the house connect to the water inlet valve, you can see it near the top with the top off
Posted on Apr 29, 2008
SOURCE: No water in dishwasher
Since no one wanted to offer any advice, I have chose to call the repair service.
Posted on Jul 28, 2008
  • 2694 Answers
SOURCE: I need to reinstall awater inlet valve on my
Parts & Accessories | Shop & Find Lawn & Garden, Appliance Parts at Sears PartsDirect | SearsPartsDirect.com go here,put your model number in and hopefully this will help you,next time you need help send the model number,good luck,just take off one line at a time and install it into the new valve,the lines are different sizes and the solenoids are colored so it's kind of hard to do this wrong,also there should be instructions with the vavle
Posted on Jan 10, 2010
blueextc3221
  • 15935 Answers
SOURCE: whirlpool duet washer How do I replace the bad inlet water valve"
It appears your timer/main controller/CCU has failed in this instance.
http://media.fotki.com/1_p,wbwdbgswgksbgfwxgtqsskgwtqkq,vi/ktfgsrbbdxwtwtqtfwk/1/1303472/5961857/image45924img-or.jpg
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 30, 2010
How do I unblock filter of washing machine
Turn of hot tap and disconnect hot water hose from inlet solenoid, using long nose pliers pull out filter from solenoid.
The problem may well be the solenoid needs replacing as they do tend to fail occasionally.
Oct 10, 2014 | Fisher and Paykel GWL11 Top Load Washer
No fault code washer will not fill
Hi
If the washer won't fill you'll need to check for the water inlet hose, the water inlet valve and the pressure/water level switch assembly. Inspect the inlet hose coming to the washer for any blockages. If the hose is not clogged then check the water inlet valve for any clogs, if the water will not even fill for few seconds then certainly the water inlet valve is bad and should be replaced. You can also use a multimeter to check continuity on inlet valve. If you don't get any value on the multimeter then you'll need to replace the water inlet valve assembly. However, if the valve is fine then the pressure/water level switch assembly should be replaced. Hope this helps... Please post back if you need more information.
Daniel
Aug 30, 2011 | Whirlpool WTW6400SW Cabrio Washer
Icemaker not making ice
Hi
Please check the water inlet valve, it might be frozen or blocked with mineral deposit. Use a hair dryer to remove the blockage. Make sure the water inlet valve's screen is not blocked. If the issue persists, then the water inlet valve has gone bad, use a multimeter to test the water inlet valve's continuity. Use a multimeter to test the continuity. Hope this helps...please post back for further assistance.
Daniel
Aug 24, 2011 | Maytag Refrigerators
Water not entering washer
Hi
Daniel
Aug 03, 2011 | Maytag Bravos MTW6600T Top Load Washer
LG LD2131SH Dishwasher displays a ie error
Hi santjiesfras,
The error code your receiving is an "Inlet Error" message. This means that no water is going into the Dishwasher. Please check the following:
1) Is the tap open.
2) Is the inlet hose kinked?
3) Is your water pressure fine? Because anything less than 0.3kgf/cm(bar) is not going to work
If all of the above is fine, then take off the inlet hose of the dishwasher, and clean the filter which is between the hose and machine (small circular filter). If still not working, then you will need to replace the inlet valve. I would suggest getting a L.G service agent to do so.
Good Luck :-) - J.Q
* If you found this solution helpful, please vote positively. A 4 four thumbs up will do nicely too :-)
Apr 13, 2011 | Dishwashers
The water trickles out very slow when it is filling the machine. I have a Fisher and Paykel GW712 washing machine.
The two things you need to look at is the screens on the inlet of the washer, thes can get plugged with sediment and block water flow, take the hoses off the machine and look for the screens, either in the hose or water inlet connection. Second is the inlet valve, AI will include a couple of pictures of this. If you have an ohm meter all you have to do is check for continuity across the valve, if there is none the valve is bad and needs replaced.
The control panel lifts off by removing two phillips screws on the back of the control panel. The panel then flips over. The picture below shows what it looks like with the control panel removeddcramer531_29.jpg The inlet valve is on the left.
Not shown above are Power Control and Pressure Sensing Module, which plugs into the water inlet valve nipple, and the tech sheet, which you'll find folded up to the left of the water inlet valve. The tech sheet gives detailed instructions for entering diagnostic mode and interpreting the binary diagnostic code generated by the LED display on the control panel touch pad. anew inlet will look like this.dcramer531_30.jpg or very similar, depending on the model.
Dec 16, 2010 | Fisher Paykel EcoSmart GWL15
Letter F appears on screen, and dishwasher does not start. Sounds like pump runs for a bit then stops. Door is closed. What is wrong?.
Hi
Error code F indicates that dishwasher control has detected a fault with dishwasher filling. This is due to faulty water inlet valve. Please check for clogged water inlet valve. Water inlet valve part#35
You can buy it from this link---
Bosch SHU531 water inlet valve
Daniel
Nov 10, 2010 | Bosch SHU5315UC Dishwasher
Maytag Atlantis Model Number MAV9501EWW has problem filling with cold water. I have switched the hoses and can fill with cold water through the hot water valve.
Hi.
Test and eventually replace the inlet valve.
The inlet valve is tested reading impedance, if it is broken, then it usually read infinity (circuit open). Reaing is done disconnecting valve and pointing multimeter probes at valve solenoid contacts (the cold ones in your case).
A definitive test on inlet valve is done reading volts while cycling and observing if valve is opening. For safety reasons is better if the user performs only tests that can be done with power off.
The switching contacts and inlets is also a test even if basic, I think that the valve is gone.
Here part:
Series 21 models: sub 22004333 (water inlet valve)
Series 12 models:VALVE-INLET
Valve is part nr.2 in diagram below. Click on the picture to enlarge.
If you repute this solution helpful, then please do not forget to accept.
Best regards.
Ginko.
Oct 01, 2010 | Maytag Atlantis MAV9501E Top Load Washer
Wont fill with water, replaced the inlet water valve,still wont fill
First of all make sure the water shut off is on. Second check the water float is it jam on the top position that will shut off the water. then the timer switch that control the water inlet valve.Hope this 'll help. God Bless. have a nice day.
Jul 23, 2009 | Kenmore Dishwashers
Dish washer will not fill with water
First I'll check is there any power to the water inlet valve item #19 if there is power then the water inlet valve is defective, if there is no power check the door magnet Item # 13 I found the magnet itself got loose inside the plastic housing and cause the problem as the door is not closing at all. If you need further help please email me at dickson@lau.com
God Bless have a nice day. Dickson
Apr 16, 2007 | Moyer Diebel 24 in. 301HT-40 Built-in...
Dishwashers Logo
29 people viewed this question
Top Dishwashers Experts
