Question about Ricoh Office Equipment & Supplies
I have a Ricoh sp8200dn printer that has a paper jam at A,B,C all at once only when printing on 8.5x11 paper. We can print 11x17 without problems. What should I check for or replace?
I cleaned rollers and removed dust/toner residue, re-seated the fuser, checked sensors after the fuser for anything blocking them and nothing seems out of place.
    Sergeant:
  • 283 Answers
I suspect the printer is expecting the larger paper. Make sure it's set for 8.5x11.
Posted on Apr 28, 2017
How can i print a test pattern on my sp8200dn printer
After you have selected whichever test pattern you want ie 05 for lined page press the OK and exit this sp. if you go to the 5-990 SP PRINT OUT mode and choose any of the options there the printer will print a pattern on the pages instead of the data.
Oct 08, 2015 | Ricoh Aficio SP8200DN Laser Printer
Line through print
Perhaps did not specify paper thickness (check control panel and print driver).
Toner getting low.
Clean registration roller with clean damp cloth.
Aug 17, 2012 | Ricoh Aficio SP C811DN Laser Printer
We have a Ricoh Aficio CL3500N and every time we print the paper jams and we get the "Remove Misfeed A: Internal Path". I remove the jam and when it tries to print again we get the same thing,...
There may be an obstruction inside the printer. Try this....remove the paper from the paper tray and put paper in the handfeed tray (front of the machine) If it feeds from that tray it means that the feed rollers in the bottom cassette are worn.
Dec 17, 2010 | Ricoh Aficio CL3500N Laser Printer
Ricoh 3045 printer stopped printing error code SC545
Hello, you´re found problem in the fusion unit. Clean the thermistor, and try again. Before try it, most reset the Sc code with service code....Good Luck!
Feb 08, 2010 | Ricoh Office Equipment & Supplies
False Jam at exit on a Toshiba DP3580 copier
make sure your drawer size shows 11x17 on display if not push user interface button then select the drawer and set it to 11x17
Jul 04, 2017 | Toshiba DP2570 Printer
Can't Print
Firstly, I have to ask......the paper is installed, and tray set correctly? Does it read the proper size on the display of the copier?
Ok....next, do you have the optional paper trays installed (3 & 4)?
Is that where the 11 x 17 paper is? Then you probably did not add the accessories when you installed the driver and when printing that paper is unavailable.
right click your printer icon, click "properties", then i think it's under the "accessories" , or "options" button....select the optional trays, and anything else you may have. click 'ok' ...should work.
Mar 19, 2009 | Ricoh Aficio 2018D All-In-One Laser...
Booklet printing on 11x17
In Print Settings make sure the original size is 8 1/2 by 11 and print out size is 11 x 17
Nov 01, 2008 | Ricoh Aficio CL7200 Laser Printer
Full bleed
sure, first you need to use 12x18 paper in the bypass tray. The using your application select to print 11x17. you then cut the paper to 11x17, thats the only way to print full bleed on this system.
http://www.websitetoolbox.com/mb/copierquestions
Jan 07, 2008 | Ricoh Aficio CL7000 Laser Printer
47 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
CheckitRight
CheckitRight
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
