Question about Sherwood Audio Players & Recorders
Sherwood cdc5506 new turntable won't close - Sherwood Audio Players & Recorders
What would it cost to purchase a styli/needle for Sherwood DEK7-U?
All you need to do is look at the cartridge and find the make and model number of it. Put that into google search and the information on the stylus should come up.
Jul 03, 2014 | Audio Players & Recorders
Need to download a manual for Sherwood DEK-7u turntable in order to determine the stylus model detailsl
No you don't!
Just enter the model number of the Sherwood into Google. Or you can enter the cartridge number that will be even quicker.
Feb 04, 2014 | Audio Players & Recorders
What is a compatible turntable for my Sherwood rx-4109 receiver?
many decks have pre amps or need preamps. hence the reason why you have distorted sound i would guess. you need the opposite of what you used. What record deck did you try?
Jan 06, 2013 | Sherwood New-RX-4109 STEREO RECEIVER WITH...
Sherwood pm9800
HI,
Here is a link for the Sherwood PM 9805. Its a latest version of PM9800. I think it will help you....
Sherwood PM 9805
Ajin
Jul 14, 2012 | Audio Players & Recorders
Technics turntable plays but no sound with Sherwood receiver
The problem is the fact that the new receiver has no phono input. The phono input has an extra stage of amplification built in. Your receiver is working fine. You need to purchase a phono pre-amp. These run around $20. Connect the turntable to the preamp and the presmp output to any line level input on your new receiver and everything will work as expected.
Dan
Apr 12, 2009 | Sherwood RX-4103 Receiver
My turntable works on old reciever and not new one
A traditional turntable only works on Phono (which contains special preamplification and equalization circuitry designed to raise the the level and flatten out the response of a phono cartridge).
After you do that, iIf you're not having hum problems I wouldn't worry about the ground. Or try it again on the FM Ground.
Feb 20, 2009 | Sherwood RX-4105 Receiver
Low volume and unbalanced deck
Turntables require amplification, they have very low output on their own. If your Sherwood has an Aux input try using that, older receivers often had a built-in pre-amp on the aux jack. You can obtain a stand alone pre-amp for less than $50, I use one from mcm, #40-630.
Dec 29, 2008 | Technics SL-BD22 Turntable
Have an older sherwood turntable model st-905 linear direct drive. when i press the button the tonearm humms but will not move
I had a similar problem and found that manually moving the arm back and forth along the tube several times "loosened up the mechanics. They get stiff after sitting a long time. B e sure to protect the needle!
Dec 11, 2008 | Sherwood Audio Players & Recorders
PS-T3 connection to Sherwood 4105 Receiver
You need a phono stage (phono amp) between the turntable and receiver to boost the lower signal from the turntable. If your receiver has phono inputs, use those as there will be a built-in phono stage.
Oct 14, 2008 | Kenwood KD-291RC Turntable
27 people viewed this question
Top Sherwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Sherwood Audio Player and Recorder Expert? Answer questions, earn points and help others
