Turntable will not close on new player - Audio Players & Recorders
The turntable started dragging and now the record won't finish because it stops. What's wrong ? do I need a new turntable motor? Everything else seem to be working fine thxs David
Is this a cd player or a turntable recordplayer ???
cd player that drags usually mean theres a misalignment in the tray that holds cd
turntables that drag unless they are direct drive usually need there rubber drive tires replaced or a belt what ever it has
Oct 23, 2015 | Audio Players & Recorders
Crosley CR40 playing 33 1/2 too fast? What can I do to slow it just a little bit?
I would get a vintage turntable and not a new one inexpensive one. The new record players do not last.
Apr 20, 2014 | Crosley Stack-O-Matic CR40 Turntable
Shaky sounding records
Some things to check:-
Is anything preventing the turntable from rotating smoothly, this would cause a judder.
Perhaps the records are sliding on the turntable, a rubber mat will cure this.
Ensure the record player is on a level surface.
Dec 27, 2013 | Crosley Cr704 Turntable Am/fm Radio Record...
CD Changer won't finish loading a CD
I had the same problem and found the cure for it. The drive belt was streched and when it started to close on the disc, the belt would slip and eventually show loading error..The two belts cost $4.50 at belts plus. Hope this helps you
Feb 21, 2013 | Sony MegaStorage CDP-CX355 300-Disc CD...
I have a brand new emerson 3 speed record player, amfm radio, cd player combo. I am having trouble with the turntable rubbing even after we tighten the shipping screw down
Shipping screws are used the hold down the turntable during shipping.
These shipping screws need to be removed after shipping and installation.
Nov 19, 2012 | Emerson 3 Speed Vinil Classic Lp Turntable...
On my Philco Turntable CD with cassette the CD player does not close all the way. If you manually close it, it does not play
You are describing too problems, won't close all the way, could be a bad loadind belt. the second issue it will not play, the timing gear is out of sync, or the laser pickup is not functioning, you will need to take it to a service shop for assessment.
Jun 02, 2012 | Philco (R) Classic Turntable CD Shelf...
Record player does not move
more info needed - could be that the 'belt' driving the turntable has slipped or broke - what type of player is this?
Jul 18, 2009 | RCA Spirit Of St. Louis Radio/Cassette/CD...
Philco turntable cd with cassette player all i get is the cassette playing nothing else works where can i get it fixed here in washington state
just find a local electronic repair shop near you
look in the phone book for electronic /electronic repar shop
i have had to repair these before and the selector chip has failed because of a resistor letting to much current and voltage go into the chip , repair cost $40-$50 depending on the dammage
Oct 29, 2008 | Philco (R) Classic Turntable CD Shelf...
Turntable rpm
found rubber washer that is close to the proper size for the rpm.
Feb 11, 2008 | RCA port Turntable with CD&Digital Radio...
24 people viewed this question
