Question about Blade Saws
I need the part number for the blade hold down part, for a Chicago reciprocating saw #42597
    Master:
  • 496 Answers
Https://www.manualslib.com/manual/752265/Chicago-42597.html?page=8#manual
Page 8 and 9 are part numbers and parts graphic. Once you have the part number, use google or whatever search engine to find your part or an equivalent.
Semper Fi,
Z
Posted on Apr 28, 2017
How do I remove blade that's broken off in a Skil 9216 reciprocating saw?
Turn the release as far as it will go, then tap on something blade down till it emerges.
Aug 03, 2014 | Skil 9216-01 9.0 Amp Variable Speed...
Broken reciprocating saw blade stuck in saw
Hello, I found a very quick and easy solution to this. Pulling the blade release and shaking, and taking the saw apart, did not work. What worked instead was to simply turn the saw on while pulling the blade release at the same time - when I did that, the piece of stuck saw blade came shooting out. Please be VERY CAREFUL while doing this, making sure you are wearing eye protection and pointing the saw away from others, so that no one gets hurt by the ejecting blade piece. I would also suggest knocking and shaking the saw while holding the blade release before you try this, as another poster suggested, because if the blade piece is big enough it might come out this way, or at least it may help loosen it so that it will easily eject outward when you turn the saw on. Good luck!
Jun 26, 2012 | Ryobi P510 18V Cordless One Variable Speed...
How to remove broken blade stub from cordless ryobi reciprocating saw
Try spraying the clamp assy with WD40 and then gently bang the front down against the work surface whilst holding open the clamp lever.
May 16, 2012 | Ryobi 18 V Cordless Reciprocating Saw
Can't get the blade to stay and lock.. what could be the problem?
Try spraying WD40 down into the blade holder. The pin which holds the blade may be sticking.
Jul 31, 2011 | Dewalt DW304PK reciprocating saw kit with...
I need directions on how to change the baldes on a reciprocating saw.
There are 2 types of clamps that hold the blade in that type of saw.
Since this one most likely has the type where the blade is held in place with a set screw and a "U" shaped piece of metal that holds the blade tight against the shaft. There should be a screw hole in the shaft of the saw. The blade rest next to the shaft and then the metal piece clamps the blade against the shaft. This is all held in place by a set screw that screws into the shaft. This screw uses a hex key to remove and tighten it.
If your tool doesn't have this style then it should have a twisting clamp. This will rotate and release the blade. Sometimes a pliers is needed to loosen the collar, but not to tight tho.
Jun 30, 2011 | Skil 921502 85 Amp Reciprocating Saw
How do you change the blade on a chicago jigsaw #35778
Like most reciprocating saw there would be a screw on the collar. The collar is the piece of metal on the end of the shaft that moves up and down simply loosen this set screw and pull the old blade out.
Mar 22, 2011 | Garden
Saw blade loosens no matter how much or often I
put a little bit off LOC-TITE on screw, worked for me
Apr 08, 2010 | Craftsman 8.0 amp Reciprocating Saw
Clamping a blade in the saw
it's either a cylinder behind fence,twist it to open,let go so it close's. or there is a lever on the side that you lift up to insert blade let down to hold in place
Apr 07, 2010 | Dewalt 10.0 AMP Reciprocating Saw
Saws Logo
Top Blade Saws Experts
bozarthm
Level 1 Expert
Wayne Johnson
Level 1 Expert
Are you a Blade Saw Expert? Answer questions, earn points and help others
