How do I remove the plate covering the t-con board without damaging the board or cables connected to it? When I try to remove the plate, the t-con board and cables move with it.
On some sets the cables need to be removed before the metal plate will come off. If this is the case the top connector will release the ribbon cable by carefully flipping the black plastic piece down. The bottom connector has two points on the sides of the cable that need to be compressed to remove the cable from the T-con. The metal plate is having a resistance of removal due to the heat sink pad. A slight even pulling pressure will separate the two without damage, Hope his helps. :)
