Question about Onkyo Audio Players & Recorders
How to align onkyo dx-340 disc tray - Onkyo Audio Players & Recorders
  • Official Brand Answer
  • 333 Answers
Hello, sorry there are no available instructions for that process . I suggest a service center. Thank you, Onkyo, USA
Posted on Apr 28, 2017
I have an ONKYO CD Changer and there is a CD that is stuck in the tray the tray will open but the CD won't drop down.
Ronald, The unit would have to go in for service to have a technician release the CD. Thanks, FJD
Jul 25, 2016 | Onkyo DX-C390 6-Disc CD Changer Player
I have a DX-C380 and it only works after about 2or3 minutes with a hairdryer playing warm air through the tray.
Either the laser is dirty or on it's way out or you are warming up the laser decoder to make it work or the motor the cd sits on is stiff
Jun 10, 2014 | Onkyo DX-C380 6-Disc CD Changer
Onkyo DX C330 carousel goes in and out without stopping and won't quit spinning around
Sometimes the tray ribbon goes bad causing bad connection to main board! Common
problem with alot of brands!
Apr 22, 2011 | Onkyo DX-C390 6-Disc CD Changer
Plays 1st disc ok...2nd disc ok has trouble seeing 4-6
Hello,that unit uses one laser and the tray brings each cd to that laser for it to be read.The fact that a particular disc is having problems leads me to believe the disc is at fault,look for scratches and/or fingerprints on its clear metallic side.
Feb 10, 2011 | Onkyo DX-C390 6-Disc CD Changer
Onkyo DX-703 CD tray engine tries to oepn but cannot when I put CD player on and hit open. What can I do?
You're tray may be opened with a belt, maybe it's slipping over the plastic wheel.
Good luck,
Gerard
Jan 14, 2010 | Onkyo DX-C390 6-Disc CD Changer
Onkyo C-707chx cd tray jammed won't open won't play
I have the same exact problem with my Onkyo C-707CHX and I found a solution that doesn't involve jamming any screws or other metal objects into your cd tray (which could most likely just cause more damage). This way seems a little safer: Power on your device and hit the open button. As soon as you hit the open button quickly push slightly with both hands on both sides of the cd tray that should be opening. You should hear the trays moving around in there and then you have to try to feel for a slight push from the tray. As soon as you feel that slight push, take your hands off of the tray and let it come out. This has been working for me for a while now (and hopefully will continue to work until I take it to get fixed somewhere). The only issue I have run into is that my "Disc 1" open button doesn't work with this method. So I just use this method with disc 2 or 3 and then once it's open I can hit the disc 1 button to get to that tray. So if it doesn't work with one tray, try the other two as well. Hope this helps.
Jun 07, 2009 | Onkyo DX-C390 6-Disc CD Changer
Onkyo 6 disc cd player onkyo DX-C390
The unit can not read the discs. It will search through all 6 positions then quit. Try opening up the unit and cleaning the lens using a cotton swab and alcohol. Update this with your results.
Dan
May 07, 2008 | Onkyo DX-C390 6-Disc CD Changer
Won't work
Sounds like there might be a disc jammed in the disc tray.
Dec 23, 2007 | Onkyo DX-C390 6-Disc CD Changer
Top Onkyo Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
