Question about Refrigerators
Model 450ahaewna - FLO light is on and compressor mtr/fan not coming on?
3 Suggested Answers
heatman101
  • 43501 Answers
SOURCE: compressor fan mtr hot, hear it try to energize
The motor bearings have siezed up and the motor needs to be replaced...
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool…
Air Conditioner Trouble -Review the Possibilities
http://www.fixya.com/support/r3571569-air_conditioner_trouble_review_the_possi
heatman101
Posted on Aug 22, 2010
jdvillanueva
  • 2098 Answers
SOURCE: I have an Aqua-flo Flo-Master
Yes this is replaceable, click this LINK.
Hope I helped you.
Have a nice day!
Thanks for using Fixya.
Posted on May 09, 2011
A amana French door fridge no fan water or.icemaker lights come on but no fan turning on or cold
Many Amana model fridges have the freezer fan wired through the bi-metal thermostat that is clipped to the evaporator. Either your compressor has a bad start device and that is why it is not cooling, or the compressor IS running and the unit has lost its refrigerant charge. Running compressor with no cooling = buy a new fridge.
Compressor hot, but not running = start relay replacement to get the compressor going. Start Device 8201786
May 13, 2016 | Amana Refrigerators
How do i fix AC Dolcool split type, Model KF61G, compressor not working. Breaker keep tripping.
It sounds like compressor is shorted,check ohms from compressor terminals to copper,clean area on copper.if it reads ohms,short,if not I would start by disconnecting outdoor MTR,indoor MTR,& see if still tripping
May 07, 2015 | Refrigerators
Fan spinning backwards
If its the original mtr. or was working fine before then mtr is bad replace mtr with new capacitor
May 17, 2013 | Intertherm P3RA-048K Air Conditioner
How do you trouble shoot 297241800 controller for a freezer to see if it's bad
What is the model number of your refrigerator/freezer?
Nov 20, 2012 | Refrigerators
Blower fan does not work?
wiggle the connection at the blower mtr .make sure all the fuses are good even take a hammer and lightly tap blower mtr...If that doesnt help and power is present at blower mtr connection then blower mtr needs replaced
Feb 17, 2011 | 2002 Dodge Caravan
Heater Fan Motor stops working
fan mtr needs to be replaced. If you locate the mtr under dash on the passenger side or under hood. then wiggle wire connector or lightly tap on the mtr. if mtr. cuts on and off you have found the problem
Feb 16, 2011 | 2000 Oldsmobile Alero
Compressor fan mtr hot, hear it try to energize for approx 2 seconds then stops aproximately 1minute later cycle repeats, removed coil voltage and manually acuated coil did not hear anything trying to...
heatman101
Aug 22, 2010 | Goodman CPLE24-1 Air Conditioner
With the thermostate off the interior fan runs but when i turn the thermostat on it trips the breaker
Not good! The thermostat only supplies power to the compressor section, so a breaker tripping is a sign of a 'dead' short to that area. If lucky, it just an exposed wire or terminal connection damaged in that area, but rarely the cause. More likely is compressor mtr "locked rotor", or stuck "potential" start relay holding the mtr circuit in hi-amp load, or shorted internal motor winding's. The condensor fan can also short closed, but is rare due to it's design. I have to assume the electic breaker suppling that circuit is not failing, as cause?
Jul 09, 2010 | True TD-95-38-LT Beverage Cooler
Laars LX400 Air Flo SW Error
is fan coming on if not bad fan motor also check pressure switch if 24 volts both sides that's ok make sure air flow switch hose is ok
Sep 09, 2009 | Teledyne Laars Laars Lx Pool Heater /...
Vacuumed my coils in my side by side, but the motor hasn't kicked back on. I don't know if i got the model number right...
which motor? compressor, condenser mtr next to the compressor or the mtr inside the frzr?
first chk to see if the fan mtr inside the frzr is running, if mtr is runnnig, then you have a problem w/compressor or relay loacted on compressor. alot of those compressor are locking up for no reason and maytag has a RECALL notice on their refrigs. contact maytag to see if your model is effected.
Jul 16, 2009 | Maytag MCD2257HE Side by Side Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
