Question about Refrigerators
My freezer gets cold, and the coil freezes up and it goes up the copper wire. I just replaced the theromostat and heater myself. I plugged it in and within 15 minutes the bottome coil was freezing and the copper pipe was froze. Please help if you can.
  • 1 more comment
  • Kristy Adams
    Kristy Adams Jul 27, 2009
    It is a cooper wire inside the top freezer part of my frigerator. There are 2 separate copper wires, but only one is freezing up. I have a GE model, but I'm at work right now so I wont be able to provide the model number till I get home (if you need it)
  • Kristy Adams
    and yes, all of my fans are working the one in the top freezer and the one on the back of the lower part of the refrigerator
  • Mike Smith
    Mike Smith May 11, 2010
    What is the location of the copper wire you are refering to ?
  • Refrigerators Master
  • 4,654 Answers
Is the fan working in the area of the freezer. I do need the model number to help you better. Thank You, Sea Breeze
Posted on Jul 25, 2009
  • John Tripp
    John Tripp Jul 27, 2009
    When that happens it usually shows that there is a possible freon leak. Call me if you like and we can discuss this further, Thanks Sea Breeze
    864-812-1887
Why water is leaking in freezer where cooling fins are
The defroster coil melts the frost build-up on the coils and the water hits the aluminum plate that guards the plastic drain from he heat of the defrost element, but the drain freezes over because the air temperature and the metal heat shield are still cold enough to freeze the drain. You can cut away a small portion of the metal pan liner and expose the drain to the heater coil while defrosting. I also wrapped a piece of copper 14 guage wire around the heating coil and routed it down the drain to heat it while in defrost. No problems after this fix.
May 31, 2014 | Whirlpool GB2FHDXWD Refrigerators
Frigidaire freezer ce error
That is the temp sensor and should be hooked up to the board.
Oct 10, 2013 | Freezers
Hss25gfpd freezer not freezing
when you had the back wall off how did the evaporator coil look?was the frost pattern even all over the coil or just on the top or bottom,if it didn't have an even frost pattern covering the whole coil you have a freon leak and will have to replace the machine.it will just keep getting warmer
Jul 08, 2012 | Hotpoint HSS25GFP Side by Side...
Water is collecting in bottom of refrigerator
if the freezer is on top and water is under the bottom draws you have a plugged drain in the freezer.remove everything out of the freezer, shut down the machine or unplug it,remove the back inside wall of the freezer,with a hair dryer melt out all the ice.you'll see a drain hole under the evap coil,you have to blow that out,i use a steamer,you can try a turkey baster or something like that so you can blow out the line,when you think you have it cleared out,pour a half cup of hot water down the hole,if it goes down then it's clear,if not you have to blow it again until the water goes down,you can get a piece of copper wire like a ground wire from an electrical wire,slide it into the hole around 4 or 6 inches and cut it long enough so you can wrap it around the heater,when the heater comes on the copper will heat up keeping the drain from freezing up again.let me know how you make out
Nov 20, 2010 | Whirlpool Refrigerators
Refrigerator is cold, freezer not freezing
Amana refrig have 2 main problems . 1 is the defrost bimetal ( 1" cylinder at the top right on the freezer coils with 2 wires ) and the other is a refrigerant leak where the copper tubing joins the aluminum tubing at the freezer coils ( evaporator coils ) . If your freezer fan is not working and you have frost on the freezer coils then replace the bimetal as this also controls the defrost heater ( defrost thermostat ) . If you have no frost on the coils ( for both checks , you will have to remove the inside rear freezer panel , maybe 12 screws ) , then a refrigerant leak has happened and the best solution would be to replace the refrig .
Jul 18, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Our freezer on our ge profile side by side is not staying cold
Pull the refrig out from the wall . Behind it you will see an 8 " X 10 " panel , held on by several screws . Unplug the refrig and remove the panel . On the control board , you will see a blue plug with 3 larger wires going to it . Unplug this plug . Looking at the plug , you will see : wire1 , wire2 , space , wire3 . Get a short piece of insulated wire with both ends stripped about 1/4 " . Insert one end into wire2 and the other into wire3 . Plug the refrig back in . Open the freezer door and , at the bottom of the rear panel , do you see a red glow ? If no glow after about 1 min , then the defrost heater is probably bad . To replace this , you would have to remove the rear freezer panel , and under the coils , will be a glass tube . This is the heater . If you do see the red glow , then either the board or the #4 and #5 thermistor are bad . Start with the thermistors . Small 1" white cylinder , with 2 white wires going to them . One is clipped on top of the freezer coils , and the other is at the bottom of the freezer panel , inserted into a holder . These thermistors , tell the board the temp of coils , and freezer .
Sep 19, 2009 | GE Refrigerators
Maytag Freezer mqu1556aew 2004-07.Ice buiding up on the bottom of freezer.
if self defrosting model check frozen drain in freezer
Aug 09, 2009 | Freezers
Freezer not working
Hi, are you getting ice or frost build up.
The most common part that goes bad on these are the defrost heaters. THe defrost heater is below the evaporator coil and usually has a blue and pink wire to it. Test the heater for continuity. If it tests open, replace the heater. If it tests closed, check continuity on the bi-metal stat located on top the evaporator fast to the coil. The bi-metal stat has to be tested cold. Again, if it tests open, replace it.
If both of these test ok. you wil need to replace the defrost control.
Please let me know if this has helped you or if I can assist you further.
Thanks
Vic
May 24, 2009 | Refrigerators
Subzero 550 coils
I had same problem very recently.  The problem with both the refrigerator and freezer on the 550 is that the drain line that takes condensation and water from the defrost cycle to the drain pan freezes up. Sub Zero parts suppliers will sell you a fix-it kit which I used for the refrigerator.  The kit is simply a heater wire that you plug into one of the existing circuits and runs down the length of the drain pipe to keep it from freezing up.  When my freezer started doing the same thing I ordered the kit for the freezer but the wire was too fat for the drain pipe so a Sub Zero rep gave me a better and more elegant solution.  You need a length of bare 12 guage copper wire, about 24 inches.  Run it through the drain pipe with about 6 inches exposed at each end.  On the underside of the fridge, wrap the end of the copper wire a few times around the black heater coil that you will see running back and forth.  At the upper end, wrap the copper wire around the black heater coil that defrosts the freezer coil.  The heat generated by the two coil will simply conduct heat through the copper wire and keep your drain line from freezing up.  There is a 90 degree bend in the drain line which makes it difficult to feed the copper wire through.  I suggest using guitar string or picture hanging wire as a snake.  Feed that through first, then us it to pull the copper wire through.  Good Luck!
Aug 10, 2008 | Sub-Zero Bottom Freezer Refrigerator
Not defrosting into tray
You have a blocked drain tube in the bottom of the freezer. Remaove all the shelves and stuff from the freezer and then remove the back wall. At the bottom under the coils there should be a drain hole. It may be covered with ice or have food stuck in it. Clean it out with swarm water or a steamer and if it keeps happening, take a piece of solid copper wire and wrap it around the heater coil just above the drain a few loops, then shove some of the copper wire down the drain. This should put just enough heat into the drain when it defrosts to keep it from freezing again. Good Luck!
Jun 19, 2007 | Jenn-Air JCD2290HES Side by Side...
Refrigerators Logo
80 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
