Question about Dishwashers
Have a small Lamona Dishwasher. All power lights are on. Machine does not work. Occasionally the green light flashes when starting. Is there a time delay from closing door to actual start? Thanks
  • 87 Answers
SOURCE: GE Profile dishwasher LEDs do not light up.
You have a bad control pc board.
Posted on Jun 08, 2007
  • 2651 Answers
SOURCE: Frigidaire Dishwasher CL error light
sound as if your having an issue with the latch not closing properly( switches not making contact inside) yo can take apart, requires dropping the front panels and checking the switches, or replace the entire switch costs about 60 bucks part number 154529403 (black handle)
Posted on Mar 24, 2008
SOURCE: door locked light flashing when door is closed
push on the door where the lock is... it may not be fully locked.
Posted on Feb 24, 2009
  • 188 Answers
SOURCE: Clean light flashes constanly. Won't clear out to start new cycle
If the clean light flashes 7 times, pauses, then repeats...
When the dishwasher doesn't sense a water temperature increase, it will stop working and lock the functions (clean light flashes 7 times, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
...all the lights will turn on briefly and the machine will start a diagnostic cycle. You can press cancel or let the diagnostic cyle finish (1-2 minutes).
You should now be able to run the dishwasher as normal.
If the issue returns, you could have a problem with the heating circuit (ie. element, thermostat or wiring). It rarely happens but it could also be the door switch not engaging properly when the door is closed (slightly bend the door latch down making sure it doesn't hit the door when you close it).
Posted on Mar 02, 2009
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
Dishwasher asko 1895 the pump the working the lights are flashing but the machine is not working
The lights flashing is telling that there is a fault in the dishwasher.
I am assuming you have emptied the dishwasher after the drain cycle failed to work due to the pipe block.
You will have to make a fresh start. Empty the dishwasher, turn the power mains switch off and on to reset the dishwasher.
Start a new cycle and see if flashing lights stop flashing. If still same problem you will have to note which light(s) are flashing and send a post on this page. There is a chance the impeller in the drain pump may have sufferred some damage due to drain block depending on how long the motor operated before you found the problem with the drain.
Jan 04, 2013 | Asko 24 in. 1895 Built-in Dishwasher
Lamona (Howdens) dishwasher. Start/Cancel/Pause button is not working.
Probably a bit late for the original poster, but I found this page after searching with the same problem. You can actually fix this yourself. I had exactly the same problem - if you take the front off the dishwasher, the switch module is inside a grey plastic moulding. If you remove the two cable plugs and remove the two screws holding the moulding in you can then take it out. Carefully open it by pulling back the clips, and inside is a small circuit board that slides out. On one side are the two microswitches. I got mine working again with some switch cleaner. If that doesn't work, you should be able to get a new switch soldered on by any electrical repairer. Obviously, yours may be slightly different as I don't know what model dishwasher you have, but mine is a Howden's/Lamona too, so it's probably very similar. Good luck.
Oct 07, 2012 | Dishwashers
I have a whirlpool adp6600 dishwasher. the green light just keeps flashing (i think it's 7 times in a row each sequence) and the cycle won't start. have tried turning it off at the wall, clean
Dishwasher is in fault mode hold start/pause button for a few seconds this will reset the unit run your cycle again if dishwasher faults again call you local service man.good luck
Aug 02, 2012 | Whirlpool Dishwashers
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
The "clean" light is green, flashing.Dishwasher won't restart.
This is due to the water not heating properly. I have put together some instructions on how to reset the control so you can use the dishwasher again and what to check for as to why it failed. Follow the link and let me know if it was helpful.
Flashing Clean Light
May 23, 2010 | Kenmore 24 in. 17034 Built-in Dishwasher
Wash light flashes
Hi LIANNEshaun,
I'm Harvey the Master Plumber.
Your problem is: you switch on dishwasher and it seems to start then light goes onto wash and the machine stops and green light flashes
Could we have the make, model and year please?
Feel free contact me again!
Thank you,
Harvey your Master Plumber
Sep 19, 2008 | Hotpoint 18 in. DC27 Slim-Line Built-in...
Indecit dishwasher not circulating water
Checked that the motor was not seized by inserting slotted screwdriver through hole at back of machine to engage in slotted end of motor to spin up water circulating motor. Motor was not seized, so that was not the problem. Then took bottom off machine and on inspection found that the start capacitor which is bolted to side of motor was bulging and discoloured wher the terminals are. Replaced Start capacitor ( Less than £10.00) and machine motor started up. Machine behaved irratically at first, flashing lights etc.but got it to reset by switching on and off a couple of times, ran machine through cycle, now working ok.
Mar 04, 2008 | Dishwashers
Dishwasher indesit DI62
green light 2 flashing sounds like machines doing something switched of at mains & back on to same flashing green light
Mar 01, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Dishwashers Logo
24 people viewed this question
Top Dishwashers Experts
