Question about The Computers & Internet
My toyota dyna no4c engine has n oil pressor problem when the oil is cold there is oil presser when i start it when the iol is hot i have to rev it to 2500 revs to get iol presser
Whatr is characters
    Top Expert:
  • The Master
  • 24,443 Answers
Old oil or wrong viscose can cause that phenomena. Use the correct grade of multi-grade oil, if it is correct, before the main bearings fail, check your oil pump if it doesn't knock.
Posted on Apr 28, 2017
Reconed dyna no4c turbo enjin strugles to start and white smoke
White smoke is usually steam vapor. You may have a head gasket leak or a cracked head or block that is allowing water to seep into one or more cylinders. If water is in a cylinder it makes it hard for the piston to compress it before the exhaust valves open to expel it into the exhaust system. Water in the exhaust is then heated to steam vapor. Check to see if you have any water in the engine oil.
Water in the oil is often associated with the above situation.
Oct 11, 2016 | Cars & Trucks
What may cause code P0045 to appear in a no4c toyota dyna
DTC Description: Turbocharger / Supercharger Boost Control (Solenoid A) Circuit / Open
May 06, 2016 | Toyota Cars & Trucks
I have a toyota dyna 2008 with no4c engine it does not want to pick up revs could it be the ecu??
Most likely a sensor fault, clean the mass airflow sensor and intake. Replace spark plugs wires etc, get the computer ran.
Apr 07, 2015 | Toyota Cars & Trucks
NO4C COMMONRAIL PUMP TIMMING MARK?
I need mitsubishi 4b10 engine chain timming marker. Pls help me
Feb 12, 2015 | Toyota Cars & Trucks
Vw polo, 1.4 petrol, 1996. when slowing down revs drop and car stalls and can be difficult to start again. when driving it can suddenly get abit jerky, no power from accelerator then loses the revs and...
HOT/WARM START ISSUE
Its a hot start issue.
Can be related to low fuel pressure or problem with crank sensor.
Also it can be weak battery or starter.
But possibilities are to be inspected to confirm what exactly it is.------
To troubleshoot and confirm the issue,i suggest you refer few solved help links with similar types of problem like yours:------
Click the link below:------
1991 Toyota Trecel: Engine Starts fine but dies when gets Warm?
http://whatisbyme.blogspot.in/2012/05/1991-toyota-trecel-engine-starts-fine.html
1994 Toyota Pickup: Starts fine but dies in few seconds?
http://howtobyme.blogspot.in/2012/05/1994-toyota-pickup-starts-fine-but-dies.html
1995 Lexus LS400: Running Hot?
http://whatisbyme.blogspot.in/2012/05/1995-lexus-ls400-running-hot.html
2002 Toyota Camry: Puff of Blue or White Smoke while Starting?
http://whatisbyme.blogspot.in/2012/05/2002-toyota-camry-puff-of-blue-or-white.html
Multiple problems on car: Car runs hot, A/C blows hot and car starts surging?
http://schematicsdiagram.blogspot.in/2012/04/multiple-problems-on-car-car-runs-hotac.html
Delay starting on Toyota Prius?
http://schematicsdiagram.blogspot.in/2012/02/delay-starting-on-toyota-prius.html
Honda car will not start intermittently?
http://technoanswers.blogspot.in/2012/02/honda-car-will-not-start-intermittently.html
Vehicle Starts, Runs and Loses Power
http://whoisbyme.blogspot.in/2012/07/vehicle-startsruns-and-loses-power.html
Intermittent starting issues on Volvo 760?
http://schematicsdiagram.blogspot.in/2012/02/intermittent-starting-issues-on-volvo.html
Car starts and cuts off immediately?
http://repairhelpcenter.blogspot.com/2012/01/car-starts-and-cuts-off-immediately.html
Car won't start when cold?
http://schematicsdiagram.blogspot.com/2011/12/car-wont-start-when-cold.html
These details will help.
Thanks.
Nov 28, 2012 | Cars & Trucks
Oil gauge on a 02 monte carlo ss when the engine is started up the oil gauge goes from L to H & when i idela thje engine it stays on HIGH /
Have your mechanic check the oil pressere with a scanner or a manual gauge if pressure is different from gauge it needs a sender or the gauge needs replaced
Oct 20, 2012 | Cars & Trucks
Toyota dyna oil light reset
After changing the oil and filter on a 2008 Dyna, the "oil change" light would not turn off. On the plastic dash screen, there is a small circular rubber plug just above the rev counter. This plug can be prised off. Prise off the plug, insert a pin and press the button. Oil change light turns off.
Jul 14, 2012 | Toyota Cars & Trucks
HOW MANY QUARTS OF ENGINE OIL ARE REQUIRED FOR A 2004 HARLEY DAVIDSON DYNA SUPERGLIDE WITH OIL FILTER CHANGE
Three quarts. Check the oil level with the dipstick once finished changing the oil. There are two marks on the stick. The upper mark is "FULL HOT" and the lower mark is "FULL COLD". Keep the oil level between the two marks. Do not overfill.
Good Luck
Steve
Jun 28, 2011 | 2004 Harley Davidson FXDX - FXDXI Dyna...
How do i differentiate between engine oil drain and trasmission plug drain?
the iol plug should be on the bottem side of your moter. on the iol pan.
Aug 25, 2010 | 2000 Toyota Corolla
Computers & Internet Logo
27 people viewed this question
Top The Computers & Internet Experts
Perry Ralston
Level 1 Expert
ashu k...........
Level 1 Expert
ted dux
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
