It sounds like the pump is stuck.
SOURCE: Loud humming noise from subwoofer
if it is a powered sub you should lift the ground. you can do this by adding a three prong to two prong adapter. you know, like when you go to plug something in and the cord your plugging in has three prongs and the outlet your plugging in to only has two. it doesn't have the hole for the ground so you go get a little grey adapter that has three holes on one side and two prongs or tabs on the other.if that doesn't take the hum out (actually, is keeping the hum from getting in) you have a problem with the amplifier.
Posted on Jan 27, 2007
  • 126 Answers
SOURCE: 2001 escape
sounds like you may have to replace your fuel filter is it origional or have you replaced it before ? if the fuel pump is screaming then there is usually a restriction in the line sometimes caused by dirty fuel filter , its also possible that the electric fuel pump is on its way out they will screem when they are ready to retire first replace fuel filter and monitor the sound if it comes back after replacing the filter then you will need to have a pump replaced .also check the level of fuel in your tank when you hear the noise sometimes the level of gas in the tank drops leaving the fuel pump unsubmerged in the fuel making it easier to hear the noise follow me . replace fuel filter and diagnose the sound from there thanks for using a fine web tool like fixya
Posted on Jul 19, 2008
  • 110 Answers
SOURCE: Pump hums and does nothing or no noise at all.
pump starter solenoid problems.
Some-times you can lightly tap and will un-frezz it.
BUT will have to replace soon.
Posted on Jul 07, 2009
  • 37 Answers
SOURCE: My saniflow toilet is full of water and has leaked
Either the condenser has blown and needs replacing or something is stopping the motor/pump from rotating
Posted on Feb 26, 2010
  • 43501 Answers
SOURCE: My up flush toilet makes a humming sound every 5
The pump has either gone bad or it is siezed can try to unplug the pum and let it sit for a few hours then plug it back in... sometimes if you jog it on and off a few times you can get tiit to break loose and work again...if not you will have to take it out and replace the pump.
Posted on May 04, 2010
We have a saniflo compact the toilet will flush 3 out of 5 times and the motor sounds fine but the other times when flushed it will sound like it is trying to flush and then just turns off at the end of...
This could be a problem with the capacitor that has gone bad or something stuck on the blade or impeller and is not allowing the waste to be pumped out. Typically when the capacitor has seized up or there is a clog on the drain pipe, blade or impeller; the unit will just hum and not pump the waste out and eventually back up on the toilet and overflow.
Sep 30, 2010 | Saniflo & Saniplus& Macerator Pump
Toilet will not work. when plugged it it hums even if i dont push the button,
When the unit is humming it could be something stuck on the blade or impeller preventing it from spinning. The drain pipe can be clogged or the capacitor which drives the blade and impeller may have gone bad. Tipically when the capacitor goes bad it will just hum and not pump the waste out.
Aug 21, 2010 | Saniflo & Saniplus& Macerator Pump
I have a proline pool pump model # SD-15-1N11CC and it worked fine until I back washed my pool and now it stopped working. It makes a humming noise and nothing else.
Check for:
1. Centrifugal switch stuck in open position.or if capacitator start could be bad capacitator. Possible loose connection.
2. Binding of motor shaft. (something stuck in impeller) Does motor turn free. IF not check for jamed impeller. If it she sp2605x7 you can view a manual here:
Aug 17, 2010 | Hayward 3/4hp Super Pump Inground Pool...
Water will not drain humming noise
Humming sound could be jammed pump.Remove th filter and check pump Blades are free, nothing is stuck in it....
Nov 25, 2009 | Washing Machines
Humming sound from the washer
Sounds like the pump is locked up for some reason could be something stuck in it,I have pulled a lot of nickels out those for some reason, they are the perfect size to get down into the pump and get stuck.
Sep 22, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Frigidaire FWX233RES4 washing machine won't work
Sounds like there's something such as a small sock that has gotten sucked into the pump. This will keep the pump from spinning, cause extra noise, and the belts may appear fine but it may be stretched... if you're willing to deal with a little disassembly, unhooking hoses, spilling some water, you can probably handle this.... Good luck and let me know if you need any more assistance..
May 10, 2009 | Washing Machines
the humming noise is problably the drain pump, which problably has something (sock or such) blocking it, by removingthe fornt panel youlll be able to acess t hdrain pump assy, to check for a blocklage,,( UNPLUG UNIT LIVE WIRES!!!)
Jan 30, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Stalled Motor
quite possibly the drain pump which would cause it to stick in rinse cycle. the humming noise you heard is probably the drain pump powered up but jammed. likely cause is a foreign object stuck in the pump impellor - main culprit is bits of bra wire. take the pump to pieces and extract whatever is jamming it.
May 12, 2007 | Kenmore 24852 Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
