Question about Indesit Washing Machines
My Indesit DIF16 starts OK & the pump runs however after about 30 seconds it starts to beep continuously but the wash doesn't start? Help!
No lights are flashing to show an error code, the chosen program light just stays on?
3 Suggested Answers
  • 27 Answers
SOURCE: Indesit DV620 Dishwasher
You have a internal leak in the dishwasher...there is a safety float system in the base (below where you put the dishes in!) of the unit, which in the event of water in the base will stop the cycle and activate the drain pump continiously.... You will have to open the unit and find the leak. Don't know these models, but usually you have to remove side panels and front panel, drain water from the base and re-start....then check with flashlight where the leak is. Oshie
Posted on Jun 26, 2007
vladmototole
  • 226 Answers
SOURCE: indesit dif16
http://www.youtube.com/watch?v=kO2eZNP8FCk
Posted on Aug 26, 2013
Will not start cycles
is it doing the initial pump out then filling with water and stopping b4 the wash cycle? if so it may be that the wash motor has failed(you may hear a buzzing) or the pcb is faulty. if the water does not fill into the base there may be a valve fault of a supply fault. any engineer worth his salt should be able to diagnose this fault on first visit and return with a part so dont expect multi visits.
Jul 18, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Service number kuds301xbl2
I would find the electrical breaker for this unit and shut it off for a minute, then re set the breaker thus resetting your unit.
Apr 28, 2013 | Maytag MDBH975AWS Stainless Steel...
Indesit washing machine IWC6165 will not start a wash cycle.
my Indesit washing machine start washing normally taking water and spinning and draining but for each cycle i have to do manual its automatic cycle is not working by it self the way it meant and suppose to be . for example if i start on number 3 to wash it just stay on number 3 not moving to next cycle . plz can anyone knows why this happen .?
Dec 23, 2012 | Indesit Washing Machines
Dishwasher INDESIT IDL42 does not load water.
You will need to change the water inlet valve.
Nov 02, 2012 | Indesit Washing Machines
The wash light Indesit DI 67 dish washer is flashhing ?
Try pressing the start button in for 5 seconds, doing this cancells the old program and starts a new one.
Dec 12, 2009 | Indesit 24 in. DI67 Free-standing...
Shortly after turning my indesit idl530 on a fault code appears
the problem you are getting is a f01 fault,this is water in the base part of the antiflood devise.to check this if you tip the appliance backwards and water comes from the back at the bottom this is the problem,if you do this till it stops and then leave for approx 24hrs to dry out any water that may have gone on to motor,then check by switching on to start a program,if appears to work ok but then goes back to the same fault(draining all the time and light flashing)you will have to remove base and check for leaks.
Jul 04, 2009 | Indesit 24 in. IDL500 Built-In Dishwasher
Maytag Performa Dishwasher draws water then stops
More than likely you need to replace the washer control panel.
Jul 19, 2017 | Maytag 24 in. MDB5600A Jetclean II...
Indesit IDL40 Slimline Dishwasher - Won't start cycle
indesit idl 40 not pumping water out properly, ends with flashing light no 4 and plates dry but water still in machine -have to pump out using start stop button but within 2 hours base filled up with water. Can't afford massive call out prices as lady on my own.....
Nov 12, 2007 | Indesit 18 in. D41 Slim-Line Free-standing...
Jun 21, 2007 | Indesit 23 in. DV62 IX Built-in Dishwasher
Washing Machines Logo
27 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
