Question about Poulan Garden
Poulan PP 2228 Trime blade will not move with motor running.
Motor runs fine but blade stopped running, It the blades are not jamed up.
    Master:
  • Poulan Master
  • 645 Answers
The problem sounds like the clutch is not working. Follow this link for information on how to change the clutch. https://www.youtube.com/watch?v=61-4-9TetJA
Posted on Dec 04, 2017
  • 3 Answers
SOURCE: Motor runs blades not turn
Sorry about that, there is no gears for that machnie. Have a great day!
Posted on May 09, 2008
sparkysbox
  • 61 Answers
SOURCE: Motor on / Blades don't move.
Sounds like the internal gears or drive shafts are either broken, or out of alignment. Not exactly something that can be easily fixed usually. Hopefully, it's still under warranty?
Posted on Mar 13, 2009
Healeyman
  • 1198 Answers
SOURCE: When I apply "any" pressure to the blade the blade seems to go into nuetral while the motor keeps running???
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/blackdecker/RS450_TYPE_1 Take it apart and find the broken part.
Posted on May 07, 2009
  • 188 Answers
SOURCE: Motor runs but blade does not move. sounds like
It sounds like the spocket gear is stripped, the smaller gear drive may be stripped also. You will need to replace these parts. You can order them online at www.masterparts.net. The part should be listed in your owner's manual. If you do not have an owner's manual you can give your model number and I can try to find a copy for you. They also may have a parts break down Master Parts website. I hope this helps you!
Posted on Jul 17, 2009
  • 3 Answers
SOURCE: loose blade
Its a fault with these machines. The blade is fixed on a plastic mounting (the black hemisphere you can see on top of the blade) and this seems to wear quite quickly. So the blade is not fixed to the shaft! To fix - you have to access the end of the motor shaft. To do this, pull the base out as far as it goes(15-20mm) insert a flat screwdriver into the barbed flaps on the central plastic shaft and push gently to release (not the easiest of jobs!) once released you should see the end of the motor shaft with a flat slot. Now, you can unscrew the capping nut holding the blade. I replaced the blade assembly with the following: First, 15mm OD washer with 4mm hole onto shaft. This should sit on the shaft at the bottom of the thread. Then the blade. You'll need a washer that sits into the hole in the blade to center it on the shaft. This washer needs to be slightly thinner that or the same thickness as the blade. Thesn another 15mm washer over this followed by a lock nut or cap nut to secure. This worked perfectly for me.
Posted on May 07, 2010
Gas hedge trimmer blade locked up motor runs find
look for a bad nick in the teeth and file or grind it off smooth
Sep 16, 2014 | Poulan Pro PP2822 22-Inch 28cc 2 Cycle Gas...
I have a petrol hedge trimmer TRY26PHTA. The engine will start fine but the blades will not move
If the engine starts 'fine" then it has not seized.
Many, if not most, hedge trimmers are , for safety, equipped with a "CENTRIFUGAL CLUTCH" between the engine and the blade to prevent blade operation unless the engine is at full RPM.
IF your machine is so equipped, it's possible that the clutch is worn and slipping so badly that the blade can't move.
Jun 11, 2014 | Ryobi Factory-Reconditioned 30cc 18" Gas...
Hit fence with blade and now it wont move
Without direct exposure to this model, check the parts catalog, there is more than likely some type of coupler between the engine and blade assembly. Usually they are added for exactly this situation. Worse case senerio, the gearbox for the blades is "toast".
Oct 05, 2012 | Poulan Ght225 25cc Gas Hedge Trimmer
Our hampton bay fan has stoped spinning but lights still work, why would the fan itself all of the suddent stop working? thanks
One of the biggest problems I have encountered with ceiling fans has been the wearing out of the manifold, the rubber device that holds the fan blades to the motor. I have never seen them fail where all blades fall off at the same time, but I guess it is not impossible. If this has failed the blades would still be hooked to the outer ring, but not move even when the motor runs. If you can hear the motor running and the blades are not moving it may be the manifold. If the motor is not running it seems obvious that it is a motor problem or a motor controller/remote controller problem. Not easy to repair.
Aug 29, 2010 | Dryers
Homelite hedge trimmer , motor runs but blades do
Had the same problem: when I turn on the trimmer, the motor would hum but the blades won't move.
What I did:
1. Sprayed a ton of wd40 between the blades
2. Took a screwdriver and kinda wedged it between the blades to get them unstuck. Also removed some guck between the blades.
And it worked!
May 16, 2010 | Homelite Factory Reconditioned 26cc...
Ryobi 775r edger blade does not turn. Motor runs
Have you made sure the drive shaft cable is tuning and is properly installed and that there is no debris or dirt stopping the blade from turning?
Jun 13, 2009 | Ryobi Garden
Poulan 18" Chainsaw - Motor runs fine but blade stopped spinning
Chain may be locked in the bar. Caused by low oil flow to chain. You will probably have to remove the bar and blade. Then try to rotate the sprocket, if it will not rotate you may have to replace or repair the clutch. with the blade off try starting the saw and see if it is oiling. There is a small hole in housing that oil should be visible coming out at a fairly good rate. If not you will either have to open orifice in the housing or repairing the oil pump.
Apr 11, 2009 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Garden Logo
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
