Question about The Computers & Internet
I have a 2005 Master Replica, Luke Skywalker fx light saber. The batterys corroded inside and I can not get the battery compartment open to remove old battery's.
I've tried WD4 and it lossen up a bit but it's still very stuck. Please Help?
    Sergeant:
  • 283 Answers
The battery salt is water solvable.
Posted on Apr 28, 2017
Tip
Flashlight Battery and Bulb Installation and...
FLASHLIGHT
BATTERY INSTALLATION FOR TORCH:
Open the Torch Battery Door located on the bottom of the Torch.
Insert 4 “A A” (1 .5V UM-3) (not included) batteries (alkaline
batteries are recommended) into the torch compartment. Be sure
the polarity (+ and
-) matches, as marked inside the battery
compartment.
FLASHLIGHT:
Slide the Torch Function Switch to the “FLASH” position, the Torch will light. To turn off, slide the Torch Function Switch to the “OFF’ position.
FLASH/BLINK FUNCTION:
Slide the Torch Function Switch to “FLASH/BLINK” position, tha Torch will light and thc bulbs on both sides of Torch will blink.
BULB REPLACEMENT:
Rotate the Torch Cover anticlockwise to hear “click”
then p
ull out the cover, remove the old bulb. Then pull
out the torch cup, remove the blinker’s
old bulbs and
reinstall new bulbs. Replace the torch cup, then reinstall
on Mar 05, 2009 | Jeep KNG36-JXLWBC AM/FM/Weather Radio
How do I replace battery in darth vader fx light saber
Barb, I believe it is accomplished by removing the very bottom end cap by twisting counter clockwise and replacing the 3 AAA batteries. 25300531-tld3yejbcqcrludchedm25ji-3-0.jpg
Nov 29, 2014 | Toys
My son stuck his master replica Yoda lightsaber into the ground and now the saber doesn't work. i need to know how to fix it, can you help? thanks
hi. i'm his son. and FYI I got the blade to work but now the sound isn't working. and thanks for throwing me under the bus like that dad
May 21, 2011 | Master Replicas Star Wars Yoda Lightsaber...
2005 Tucson. Good battery. Blinking lights in
Is the battery new or just charged. the battery could be the problem. Check the cables for corrosion or loose connections. The cables can corrode inside the insulation near the battery this can be seen by swollen cables.
Mar 29, 2010 | 2005 Hyundai Tucson
I have a master replicas anakin skywalker force fx lightsaber, it seems im losing color in the l.e.ds in the blade and i am curious on how to go about fixing this problem
Your problem is most likely due to fact that your batteries are wearing out. Replace them and see if that helps.
Oct 05, 2009 | Toys
2005 FRONTIER 4.0 GOES TO LIMP MODE ,OPEN THROTLE ONLY 30% WITH PEDAL OPEN 100%,LACK OF DOWNSHIFT
How are your batt. terminals/battery?? Is it all corroded?? If so, clean battery terminals. Also clean all grounds in engine compartment. There are 2 next to the battery, 2 next to the iol fill hole and 2 next to the air box assy. Check and clean. Is the check engine light on?? If you have a throttle problem, check engine light should be ON. Let me know. Oh and how many miles on it??
Jul 25, 2008 | 2006 Nissan Frontier
Star Wars The Complete Saga for Nintendo DS
If you haven't tried this, use the X button to switch between Luke and Vader. The emporer will hold the first while your new character can hit him. You have to go back and forth this way, chasing him all over, but this is the way to defeat him.
Otherwise, I don't know if you have a tech problem or not. My son had a glich in one episode (Grevious would stick in one place and you could not do anything to move on) and I exchanged it no questions at Best Buy (once they got more in).
Mar 01, 2008 | Nintendo DS Lite Console
Corroded batteries
If it is really stuck inside the only way is to open it up
be "Very" carefull when opening, only open it enough to where you can stick something thin in the battery compartment to push out the battery, then use some rubbing alcohol and a Small file to clean the contacts.
good luck
thanks for rating
Jan 14, 2008 | Sony BM-23MK2 Handheld Cassette...
Computers & Internet Logo
Top The Computers & Internet Experts
Carl Rick
colinat108
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
