I have condensation on outside of 30 pound propane tank. It is in upper 30's F outside temp. Is this something to be concerned about?
  • Heating & Co... Master
  • 2,557 Answers
Is the tank being used and its compensating?
Posted on Apr 29, 2017
All lights come on except heater light coul it be tha i changed fro a large propane tant to a small tank
The heater is failing to fire for any number of reasons, not related to the gas. If the heater was functioning properly you would have gotten a "call for heat"; and the ignition device would have activated whether gas was present or not. The service light was telling the truth. Best to get a tech out there to see where the problem is.
Nov 20, 2013 | Pool & Spa
Unit runs about 10 minutes then stops but red light says its heating. unit comes back on after about 30 secons but now there is a very heavy smell of propane.
Hi pameroo,
I see that you are having issues with your Pool Heater.
I have hear Links that may help you regarding your concern, you also mentioned that it runs about 10mins then stops and a red light says it is heating then the unit comes back on after 30 seconds but there is a heavy smell of propane.
maybe you can check all the connection if there will be any leaks on the machine.
make sure that the line to the Gas tank does not have leaks, turn Off of the Gas connection before doing any troubleshooting...
Link1
Link2
Manual/Service Manual
See the Links above, the third Links has the Owners manual and the service manual for the Troubleshooting that can help check with your concern.
I hope that this helps.
Thank you for choosing Fixya,
mvincentc
Jun 30, 2011 | Pentair 460736 Master Temp Pool Heater...
My Coleman gas furnace turns on, ignites and the flame will keep going out. The entire time the blower motor will stay on humming until its hot to the touch. If I tap the gas pipe I can get the pilot to...
IT could be the temp is too cold at night and the tank cannot make vapor ie gas, The liquied has to boil inside to make the gas you can get a heat blanket to warm your tank. Ask you gas suppier if they have one.
Mar 17, 2011 | Coleman Propane Forced Air Heater...
Outside temp was 113, the compressor stoped fan stayed on.Only hot air. Latter in the day compressor and fan worked fine. Should I be concerned ? Thank Mike duo therm 13500 .no heater
It just got so hot that the unit kicked out on high head pressure...
Check the outside condenser coil for dirt... wash it out with soap and water so that you can get maximum air flow through it...
Air Conditioning - Cleaning the Condenser Coil
heatman101
Sep 28, 2010 | Dometic Rooftop RV Air Conditioner
How much water condenses in a 97 % efficient propane furnace. 5 gal overnight? I would like to know if this is filling up my holding tank.
It's typically less than 5 gallons. However, it is acidic so if your holding tank is metal, corrosion will be a concern.
Let us know if you found this helpful. Good Luck!
Feb 16, 2010 | Goodman GMS90703BXA Heater
Ac not blowing cold after outside temp reaches 98 degrees
Sounds like you have dirty condenser coils. Remove the upper shroud and check the condenser for clean. Take a water hose and gently spray out the coils paying special attention not to bend the coils over with too much pressure. This will allow more air movement through the coils and give you better cooling efficiency.
Hope this helps,
Jeff
Jun 29, 2009 | Dometic Rooftop RV Air Conditioner
How long will one pound propane tank last
The 16.4 oz propane bottle contains 1.02 pounds of propane.
1.02 lbs propane equals 16.320 oz
16.320 oz equals 22.032 BTU’s.
The RMC-8001SS has two settings, maximum and minimum
The Max setting is rated at 8,000 BTU hour.
22.032 divided by 8,000 equals 2.754 or 2-3/4 hours
The Min setting is rated at 4,500 BTU hour.
22.032 divided by 4,500 equals 4.896 or 4.8 hours
One 16.4 ounce bottle will burn 22.032 BTU’s @8,000 BTU’s per hour for a period of approximately 2-3/4 hours and @ 4,500 BTU’s per hour for a period of approximately 4.8 hours.
Jan 18, 2009 | Dyna-Glo RMC-8001SS Heater
How to use propane tank?
leave the propane tank on and install a gas ball valve after the tank. you can see that the gas is on by the position of the valve,
Aug 16, 2008 | King Kooker Grilling
Propane tank
yes, you need to buy an accessory cord that connects your tank to the regulator
Jul 03, 2008 | Coleman Roadtrip Grill LXE 9949-750
Heating & Cooling Logo
27 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
