Question about Toro Garden
I have a Toro lx468 lawn tractor I have replaced the starter motor selnoid voltage regulator and have a good battery all my selnoid does is click
  • 283 Answers
You need to rotate the starter motor. It's possible the brushes need replacing.
Posted on Apr 28, 2017
Toro zero turn mower,motor quit running,replaced fuses,no start,crossed post on selnoid,engine cranked,no response with key,just clicking,battery not dead.Ingtion module bad?
Are you sure battery is not worn out? you can have power in the battery but if it does not have 12 volts the starter will not work. If that's not the problem check the starter solenoid.
Oct 24, 2015 | Toro Garden
How to change drive belt on a xl 468 lawn tractor
remove mower deck and crawl under the tractor and go at it .
Jun 08, 2015 | Toro LX468 46" 22-HP Kohler Lawn Trac...
Disconnect the battery for ten minutes. this is generally a universal method of clearing codes on electronic control modules. Hope this helps, plese post solved on I get credit for a solved problem if it does. If not, check back and give me more info.
Apr 24, 2014 | Toro LX468 46" 22-HP Kohler Lawn Tractor
Battery fuse location toro lx468
On LX468 Model 13AP61RH848, S/N 18099H10231, the 20A fuse is right under the battery tray. Lift out the battery (under the seat), hold back a little tab, and pull out the tray with a pliers. You should be able to spot the little yellow fuse immediately.
This is totally inconsistent with the text in the Service Manual and Operator's manual which indicate in several places (with pictures even) that the fuse is right near the ignition switch module on the front side (inside) of the dash panel.
On the model and S/N I indicated, the fuse is under the battery.
Apr 25, 2013 | Toro LX468 Tractor
I have a problem with the charging system or coil on my toro 52 inch lawn mower. I have replaced the 25amp fuse but when i take the postive battery cable off while the mower is running to check if there is...
I had the same problem
1) find your voltage regulator 3 wire- the one at both end
should be your ac voltage around 20 volts the mildell one will be your 13 volts DC go to the batterie or starter with your engine running, if no voltage there check the rotor with a ohmeter the wire at both end for open circuit or ground circuit with the motor off
p.s. the voltage regulator has to be ground
Apr 11, 2010 | Toro Lawn Mower With Toro Power Tools
My Ford Taurus 1994 only clicks when trying to even when jump sta
You need to see if the battery is holding 11 volts or more while trying to crank it over. If it is, then you need to see if the same is getting to the starter motor. If the voltage looks good at the starter, the starter is bad.
At the starter you will have a larger wire from the battery, that always has positive voltage, and a smaller wire that has positive voltage only while trying to start it.
Oct 03, 2009 | 1994 Ford Taurus
Garden Logo
37 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
