Question about Yamaha Music
Yamaha psr-e333. Can switch on but cannot play even the grandpiano func. Its just "yamaha" written on the display..
    Uploaded 5 video answers.
  • Yamaha Expert
  • 128 Answers
To start with try a master reset, whilst the instrument is off press and hold the top (highest) sounding key whilst turning on.
When the screen displays Yamaha release the top key.
If this doesn't solve the issue then it could be a number of things as the keyboard does a self check on startup and will hang if a fault is found. Check each rubber switch is not stuck down or even missing this can cause this issue. Please report back either way.
Becketts Music Ltd
Posted on May 03, 2017
  • wafid16 fidah
    wafid16 fidah May 05, 2017
    I did as u said and its working but after a few minutes playing my keyboard jammed and i cant switch off my keyboard use the on/off button so i switch off the main power.. I tried the same method as u told me but it didnt working. I try to rest my keyboard for a day, and try again the next day the master reset method,and its working..but the same problem keep happen..after a few minutes playing my keyboard it turn to that problem again..and again..:-(
  • 90 Answers
SOURCE: Instruction manual for a Yamaha PSR 195 keyboard.
Try going to There, you can try to find your owners manual for free.
Posted on Jan 22, 2009
SOURCE: Do you have yamaha keyboard psr 2000 spare parts?
My keyboard yamaha psr2000,so I want parts silicone rubber keypad 61 and including electronic board,thank you.
Posted on Feb 14, 2010
SOURCE: yamaha psr s900 screen/display gone bad
Posted on Aug 07, 2010
  • 5603 Answers
SOURCE: i have yamaha PSR-i425 keyboard.can i conect it
Yes. You will need to have a MIDI interface on your OC and also select in the sounds control panel of windows that you are using the external synth. The MIDI will expect the PSR to respond to the "general MIDI" assignments.
Posted on Sep 08, 2010
SOURCE: My Yamaha PSR-260 Lights up But can't hear a thing
Any one know how
Posted on Apr 26, 2011
If you have any key note problems with your yamaha psr 9000 and need It repaired contact a qualified engineer at
Jan 28, 2013 | Yamaha Music
Yamaha psr e313 can't switch on. The adapter is
Check that your power adapter is 12 volts DC AND MOST IMPORTANT is the center pin is positive... this is reversed of MANY adapters used for pedals, etc. The current rating should be around 1.5 amps. Don't take another techs word for it... check it yourself.
Sep 01, 2011 | Yamaha PSR-E323 Keyboard
I require a user manual for a Yamaha PSR 6000 Organ to down load
Yamaha has the user's guides available as PDFs for most of their instruments on their site: . Enter PSR-6000 or select Pianos & Keyboards > Portable Keyboards > PSR-6000 and then press Select.
The link to the manual will display below the search area.
I hope this helps.
Jul 28, 2011 | Yamaha Music
I'VE A YAMAHA PSR S700. The problem is with it's screen. Whenever i start playing, the screen fades and then it comes and it goes and vice versa. This occurs almost two - three days a week. There...
Likely a connection to the backlight is being broken. Tap on the unoit and see if it pops back on. Illuminate screen with a flashlight and see if the characters can be seen when screen is faded. If they can, then the backlight is the problem... IF NOT then the display may be bad... This has been a problem and if you are under warranty, excersise it immediately... else replacement of the display is relatively expensive.
May 28, 2011 | Yamaha PSR-S700 ARRANGER WORKSTATION...
This morning during a church performance, 1/2 of our display went out on my PSR-S500. Is this a user-replacable part? I'm pretty handy with a meter and not afraid to crack the case. This item is not...
It is shop replaceable. I have heard this is NOT an uncommon problem. You can get the parts through Yamaha America in California. Here is your service manual:
Scroll down to "Get Manual" and click on it to download the manual (about 12Mb)
Yamaha support/parts contact
May 15, 2011 | Yamaha PSR-S500 Digital Keyboard
Yamaha psr-280 flashing display no key response or sound. Is it dead??
Your adapter should be a 12 volt DC delivering 2 amps (2000 ma). If the adapter is too small, you will have the symptoms you are seeing. Make sure the polarity is correct. DO NOT use the so called "universal adapters".
Apr 13, 2011 | HQRP AC Adapter / Power Supply for Yamaha...
Yamaha psr s900 screen/display gone bad
Jul 22, 2010 | Yamaha Full-Size Keyboard
Feb 12, 2010 | Yamaha Full-Size Keyboard
Yamaha PSR-510 Keyboard
There is no need for a manual. It is so easy to operate because it is designed for easy opeating. If you need a manual to operate the PSR-510 then you really won't be able to operate it even after studying the manual. But here it is just in case you can by some miracle!
Aug 31, 2008 | Yamaha Full-Size Keyboard
Music Logo
32 people viewed this question
Top Yamaha Music Experts
Michial Gueffroy
Are you a Yamaha Music Expert? Answer questions, earn points and help others
