Question about Garden
Bought a Garden Treasure patio table 25 yrs ago - great product- but the removable glass top (48" diameter) shattered. Is a replacement glass top available?
  • 5911 Answers
SOURCE: shattered glass top for Hotpoint range/ how to replace
The cook top on your range should come off by removing 2 to 3 screws under the front edge of the cook top. You will need to open the oven door to see them. Once you have them removed the top should lift up. Please ensure you have the range unplugged and/or the circuit breaker turned off before attempting any repairs to the heating elements. Live voltages are still present with the unit turned off. Now...depending on the type and model of your range, the wiring harness may have a quick disconnect type of plug. If yours is so equipped, replacing the top will be a cinch, because you can remove it from the range to work on it. Take the old top and new top and place them next to each other upside down on a padded surface. Placing some towels on a kitchen table or counter top works best. Now all you have to do is carefully transfer the entire harness and burner elements to the new cook top. You should be able to move the entire assembly with all the burners still connected. A second set of hands will make the process go much easier. If your range does not have the quick disconnect type of wiring harness have someone hold the cook top up or prop it up with something. Carefully remove the element mounting brackets from the cook top (with all the elements still attached). Carefully support all the wires as you do so, and lay the entire assembly (elements and wires) on top of the oven cavity insulation. Once you have everything disconnected from the cook top, discard the old one and position the new one in place. Carefully reinstall the elements while supporting the wires. Additional care should noted not to handle the ceramic material of the elements and/or the heat coils themselves. They are very fragile and the oil from your hands can potentially damage the elements and shorten the life of them. Let me know if this helpful to you. If you get stuck along the way, or have any questions, please respond to this posting by adding additional comments.
Posted on Sep 10, 2007
  • 135 Answers
SOURCE: Replacement of glass top
Unplug first! Find the screws that hold the cooktop to the range. Usually in the front just above the oven door when it is closed on the underside. This should release the cooktop. The burners and wiring may have to be removed. You can order the part at
Posted on Apr 07, 2008
  • 1543 Answers
Check your warranty in the back of your use and care book. If the unit was manufactured prior to 1/1/06 it may have a five year part (not labor) warranty as long as you did not physically abuse it. The glass top comes as an assembled top (glass, the black seal, and the metal frame holding it)
Disconnect power. remove screws under the front edge of cook top. lift cook top and remove crossbars holding burners up against glass top. Unhook cook top / frame assemble. Install new top in reverse order.
Posted on Aug 31, 2008
SOURCE: I have a Martha Stewart Melrose Bar patio table
If it is made by numark, you will find the list of models on this link.
By you post, I believe you have
Numark should be able to get you a replacement top.
Yes, there are lots of these tops that break, but it is mostly due to quick weather/temperature changes. i.e. putting a cold ice bucket on top in 100degree weather. or just carrying the table in an A/C house from a moving truck.
Posted on Jul 31, 2009
SOURCE: how do I replace the shattered glass in my GE oven door
No doubt this is a double paned glass panel. Two panes of glass with a divider strip separating the two for a "thermal break". Okay, you will need to remove the door from the hinges, and along the sides of the door, or possibly under the door gasket, you will find multiple screws that hold the two sandwiched halves of the door together. There should be a front panel, formed sheet steel, and an inner formed sheet steel panel which is coated with porcelin. When you have the front and back halves of the door separated, inside of one or maybe both of the panels you will find the clips, screws, or materials that hold this glass panel in place. Possibly it is in it's own frame, and the frame and glass both remove as one unit. Then it will be a matter of contacting Customer Service and Parts for your product, giving the Model #, Serial # and any other data that may be needed in order to replace the part with the correct one. Since this should be tempered glass, it will be quite heavy and at least 1/4" thick or so. The "thermal break" or space between the panes is so that heat does not transfer readily to the outside panel. Watch for any electrical connections for a door switch for the oven lamp, and be careful when removing the springs which allow the door to close and seal when in the closed position. And it might be helpful to take some photos of the disassembly process so that you can have a reference when you are ready to re-install the door. Be careful when removing the broken glass, and dispose of this carefully. Take your time, be patient, and don't force any thing, and you should be fine. Good lock. Kindest regards, Slats.
Posted on Sep 26, 2009
I've got a rattan Outsunny cube patio set. My glass on the table shattered in the hot weather and I've been trying to get in touch with Outsunny to complain about it. Can you help me please.
Armoured glass is used for table tops, oven tops etc. To get the glass to break/shatter, it requires temperatures exceeding 200 degrees Centigrade and then cooled quickly in one spot or something has been dropped on it.
Jul 12, 2017 | Ovens
I need a glass table top for The kingston patio set, 810213847
Hi Donna:
I'd suggest that you Google with the patio set information. Hopefully you will come up with some sites that either are dealers or have parts available.
An alternative would be to go to a local glass shop and see if you can get an appropriate product.
Best of luck.
Sep 05, 2015 | Heating & Cooling
I have a bassano oven the front glass broke and need it replaced
The glass is installed from bottom up.on stoves. Call the company that makes the stove and talk to the service department for the list of parts required (glass and seals). Get the new parts and once you have it, remove the door and place it on a table. Take a photo of the screws location and remove them. Clean the tracks of the door, install seals, glass. Put the screws back.
Mar 04, 2015 | Ovens
He laid it down on the table, went to walk away and it shattered. Glass and all
There must be a warranty as that was not cheap to buy. T bet if you quoted your statuary rights as a consumer, they will make good.It is bad practice to sell faulty goods.
Mar 19, 2014 | Cameras
Where can I get glass to put on top of my end tables?
Below is a great website that specialized in making customglass table tops. They deliver all overthe country and have been reviewed very well.
May 29, 2012 | Furniture
The o-ring for my garden treasure pf 1600uv filter needs to be replaced. Do you know where I can purchase one?
o-rings come in all sizes usually in milimeters
any hardware store auto parts store stocks them; just bring the old one with you for comparison
Jun 23, 2009 | Garden
Glass is shattered to to replace
To replace the door glass do the following:
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Remove the inner screws. Keep all set of screws ordered, and take noteof the order you remove them. You will follow reverse order inreassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
dd5ebd3.gifclick here
Inner Door Glass
May 15, 2009 | Maytag MER5765RAW / MER5765RAQ /...
Garden Logo
20 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
