Question about Garden
I want to have the trimmer string stay on . I stop and go a lot because I have difficulty walking the trimmer without stopping a lot and it cuts the linknext often and I run out of line quickly.
  • 4 Answers
SOURCE: 18v cordless string trimmer will not stop feeding line
Some of the trimmers recommend a certain size line, if you have one of these that let line out as needed, the speed at which the trimmer cuts will let out line as needed. If you have too small of line the drag for the friction let-out you will spoll all the line out. Make sure the line is the right size, They come in alot of sizes, anywhere from .060" to .125" line thickness so make sure you have the right size line!
Posted on Aug 07, 2008
  • 225 Answers
SOURCE: refill string trimmer
ARE YOU WINDING TO LINE THE RIGHT WAY ON TO THE SPOOL?? FOLDING THE LINE IN HALF AND WINDING BOTH ENDS OF LINE SAME WAY? NEIL
Posted on Dec 19, 2008
  • 11 Answers
SOURCE: How do I the automatic string feeder to work and
i dont remember how to put the line on i got a new head. But when the line gets low hit the head of the atomatic feeder on the ground when runin.
Posted on Jun 11, 2009
  • 115 Answers
SOURCE: Replacing the cutting head on Ryobi string trimmer.
There is a nut above the head, place a wrench on the nut then unscrew the head from the shaft, unless yours is different from mine this is how it works. I hope this helps.
Posted on Jul 06, 2009
SOURCE: My Grass Hog trimmer was
I can tell you what is is, the belt came off inside. Mine is doing the same thing, I took the case off and looked inside, the belt had come off the metal wheel. I put it back on but it keeps coming off. Im thinking theres a piece I must have lost that helps hold it on. Thats what Im looking for now. If you can get the belt back on and to stay on then it will work again.
Posted on Aug 21, 2010
What do i need for replacement string? Can i go heavier or stay with the smaller string? This is for mastercraft 20v grass trimmer. thanks
the size of the string is critical in electric driven trimmers
it does have mass and the thicker string will over load the motor
stay with the recommended string size and keep to the recommended distance to the grass being cut
string line cutters work on the principle that the tip speed of the string is what does the cutting and that means that the first 1/2" of string cuts the grass
the rest back to the hub acts like a brake as it is dragged across the grass and slows the cutting speed and loads the motor
remember that the machine is designed to trim edges and not to cut down growth-- that is a job for heavier duty units
May 13, 2016 | Garden
HOW DO I INSTALL A NEW STRING IN A PRO CUT 11 for Ryobi RLT30CD trimmer
LINE REPLACEMENT (Fig. 8) (For Reel EasyTM Head) Use 2.4mm monofilament string. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Cut one piece of string approximately 7.6m in length. n Rotate knob on string head until line on knob aligns with arrows on top of string head. n Insert one end of string into eyelet located on the side of the string head and push until string comes out through eyelet on the other side. Continue to push string through the string head until the middle section of the string is inside the string head and string outside the string head is evenly divided on each side. n Rotate the knob counterclockwise on the string head to wind the string. Wind the string until approximately 20cm remains protruding from the string head. INSTALLING STRING IN PRO CUT II STRING HEAD Use monofilament string between 2.4 mm and 2.7 mm diameter. Use original manufacturer's replacement string for best performance. n Stop the engine and disconnect the spark plug wire. n Gather two of the pre-cut lengths of trimmer line provided or cut two pieces of trimmer line, in 28 cm lengths. n Insert the strings into the slots located on the sides of the string head. String should be pushed in until approximately 2 cm protrudes from the holes on the top of the string head. n Remove old string by pulling it from the holes located on the top of the string head. http://www.screwfix.com/sfd/i/cat/pdfs/89/p4763889.pdf
Oct 29, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My Grass Hog trimmer was working fine then all of a sudden it stopped cutting. The string no longer spins around. I just hear a werrrrring sound. I just bought it last summer.
Aug 20, 2010 | Black & Decker 14" Grass Hog Xp...
Homelite Mighty Lite 26CS Model21004D
Once you have the string wound onto the spool, place the spool onto the shaft and pull the strings out of the slots so that the string feeds through the holes without going through the slots. Good luck...Lee
Jul 26, 2010 | Homelite Mighty Lite Lawn Trimmer
How to undo and change the cutting line
You need to start from the beginning of the trimmer string. Remove the entire spool. Insert the start of the line through and wedge it into the little groove to keep it from coming loose. Now wind the line tightly and neatly in the direction shown on the spool. (it should provide an arrow stating to "wind this way". As you near the end of the line, keep it snug and push the end through the hole where it leads out to the cutting zone. As you re-insert the spool into the housing, make sure it stays tightly wound as you lock it into place. This should help. Usually when your string is too short, you tap the **** (bottom) of the spool on the ground to advance the line. It should feed a bit at a time, and when you hear it getting cut off, you should stop advancing the line.
Hope this helps.
Apr 13, 2010 | Homelite Mighty Lite Lawn Trimmer
Aug 06, 2008 | Black & Decker String Trimmer Cordless 12"...
Black and Decker Grass Hog Model #GH1000
the drive cable probley kinked or bent and does not drive the head the cable goes from the motor to the head take the clamp bolt out and lift the head off the cutter check the cable
Jul 30, 2008 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
23 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
