Question about Brother LS-1217 Mechanical Sewing Machine
Thread Breaks I have a Brother Sewing Machine Model VX757. I have not used in I don't know how long. The thread keeps on breaking. It doesn't matter what setting I put it on. I am not sure whether I am threading it correctly or not. Do I need the manuel? I don't know what I did with it. Someone told me that the thread was too old. That was the reason for it breaking often.
The best information I ever received was from my Father-In-Law years ago. He said 90% of the sewing repairs he made for his customers was 1) Replace the old needle with a new one 2) Replace the thread with brand new thread 3) Clean out the lower bobbin section and the feed dogs 4) Check that the tension in the bobbin case is correct and finally 5) Re-thread the machine paying close attention to clicking the thread into each guide and the upper bobbin section between the plates. All of my machines are good old basic machines (no fancy computer models) so I hope this helps you.
Posted on Jul 09, 2015
  • 46 Answers
Dear Sir / Madam, please get your book out and follow the threading instructions very carefully. I am certain that is your only problem.
Kindest Regards,
Cookey.
Posted on Jul 25, 2009
Thread keeps breaking don' know how to adjusT tension
Since we don't know what machine you have, we're really limited on suggestions. The owner's manual should have instructions for tension setting. If you don't have a manual, search for:
Make Model manual
Assuming it is the top thread that is breaking. Breaking thread usually indicates either the machine is misthreaded or the tension is set too high. However, there are other symptoms that indicate other issues, ie if the thread is shredding or fraying, possibly the incorrect needle is being used or there is a snag/burr somewhere in the thread path. If the machine sews for approximately 2 inches and then breaks, something is catching the thread causing it to stretch until it breaks. Frequently, my thread slips off the thread spool and wraps around the spool pin and breaks.
AVOID old or bargain bin thread.
Remove the top thread from the machine.
Install a brand new needle.
ALWAYS RAISE the presser foot and rethread from the beginning.
Verify the thread path is correct.
Set the top tension to the midway point and retest the machine.
Mar 19, 2018 | Sewing Machines
After threading the machine, start to sew and the thread breaks it seems that it gets caught in step 4 in Threading The Machine in the manual.
Not knowing the make & model of the machine limits out ability to help. What is Step 4? When threading the top thread, ALWAYS RAISE the presser foot. Verify that the thread path is correct--mis-threading is a frequent cause of broken thread.
Sewing Machine Problem 1 Thread Breakage
Sewing Machine Thread Keeps Breaking
Why Is My Thread Breaking How to Avoid Thread Breakage at Your Sewing...
Mar 16, 2017 | Sewing Machines
Why does my thread keep breaking on my brother ce4000? The machine is 100% threaded correctly new needle properly wound bobbin, I just don't know what could be wrong with it.
Could be a multitude of things. Use only good quality thread--no old or bargain bin threads. Try a different brand of thread--some machines prefer certain brands over others. The needle and thread should be compatible--ie needle eye shouldn't be too small for thread weight. Burr catching the thread and breaking it. Upper tension too tight.
Remove the upper thread, RAISE the presser foot and rethread from the beginning. Verify the thread is not looped incorrectly in the thread path, like around a thread guide or around the spool pin. Is the thread snagging on the thread spool itself? Do you see the thread tightening as you sew and eventually it breaks? This indicates it is catching somewhere between the needle and spool. Is it shredding at the needle eye? This indicates the needle eye is not suitable for the thread being used.
Watch where the thread is breaking. This will sometimes give you a clue where the problem exists.
Why Does My Thread Keep Breaking While Sew
All About Needles
Jan 26, 2017 | Brother CE4000 Computerized Sewing Machine
Top thread keeps breaking
This sounds like a backwards needle. Take out the needle and when you re-insert it back in, make sure that put the flat side to the back.
Jun 07, 2010 | Brother LS-2125 Mechanical Sewing Machine
Breaking threads... you so about an inch and it
It sound like it is not threaded properly or the tension is too tight, You should be able to pull on the thread manually without breaking it
look for your manual here
http://www.brother-usa.com/manuals/default.aspx?ProductGroupID=3
Jan 22, 2010 | Brother LS-2125 Mechanical Sewing Machine
My lowerlooper thread keeps breaking. I can only
The lowerloop thread kept getting cut by the upperlooper.....I rethreaded the machine in order and then made sure that the lowerlooper thread was UNDER the part of the machine that makes the looks the loopings (silver part that comes to a point on the right side of the needles...sorry I don't know what to call it) and the upperloop was ON TOP of the same part.....it started working great. I actually have very nice tight stitches now.
Jun 19, 2009 | Brother 929D Mechanical Sewing Machine
Brother Embroidery machine thread keeps breaking
It doesn't matter so much the thickness of the stabilizer but more a matter of it being taut like a drum and the proper stabilizer for the fabric you're using. Couple of reasons the thread breaks...the thread gets caught on the edge of the spool in the crack where the thread originally starts, you're not using the right size spool cap or the upper thread is wrapping around the spool pin. When I use my 170 for embroidering I always use the vertical spool pin to eliminate this problem. Try it and let me know how you make out.
Nov 18, 2008 | Bernina Artista 180
the needle thread tension is wrong
bunching up under the material indicates that it is too loose
Nov 17, 2017 | Sewing Machines
Brother LS-1217 Mechanical Sewing Machine Logo
253 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
