Question about Health & Beauty
How do I return a blood pressure cuff that is too small
  • 50 Answers
Try different locations. The sensor must be over a vain to pick up the pulse. Locate the point on the cuff where the sensor is, and place this over the elbow. That should work. Good luck.
Posted on Feb 09, 2009
Max J
  • 22 Answers
E might represents insufficient inflation for your mom. For automatic inflation monitors usually there is a mechanism to keep inflating the cuff to higher pressures for people with higher BP. Check how is done. In some auto monitors,while cuff is inflated you keep pressing on START button until pressure reaches to some 15 to 20 mmHg higher than the pressure that auto usually stops and displays E.
Posted on Sep 08, 2009
SOURCE: Omron hem-704C blood pressure monitor show down
If your HEM 704C fell hard, it is probably the pressure transducer that is faulty, broken. To my experience it is cheaper to buy a new one then to have it repaired by a technician
Posted on Jan 19, 2010
Testimonial: "Sound advice."
SOURCE: How do you set the time and date on a Welby Wrist
I was able to do this by 1st pushing and holding the M button and then pushing and holding the on button and holding both for 3-4 sec. Once released you will see the month flashing. change by pushing the M key to desired month then toggle to day etc with the on button
Posted on Oct 07, 2010
SOURCE: Where can I get a replacement cuff for our Sunbeam
need a cuff for model 7650 sunbean blood pressure monitor. where can I purchase one?
Posted on Jun 19, 2011
My Blood Pressure comes up with E1 - what does this mean?
An E1 error can mean a number of things depending on the brand of your monitor and the way that you are trying to take your blood pressure. The general reason for E1 errors is to announce for whatever reason that the machine could not get a blood pressure reading.
Some common causes:
You did not let all of the air out of the blood pressure cuff before trying to take your blood pressure. Make sure that there is no air in the cuff by squeezing it or rolling it, prior to use to let out excess air.
Your blood pressure cannot be taken at this time. Sometimes this occurs if you are very nervous, overly excited, or have a fast heart rate. You can try sitting down and relaxing prior to taking your blood pressure.
You are using the wrong size cuff. If you are taking blood pressure on a small child, someone with a tiny arm, or someone with a large arm, the blood pressure cuff might not get an accurate reading. Many blood pressure monitor manufacturer's offer blood pressure cuffs ranging in size from small to extra large, and you should use the cuff that is most appropriate for the size of your arm.
You didn't line up the blood pressure cuff correctly on your arm. You can't just slap the cuff on your arm and expect it to work, it has to be lined up properly. Many companies put an arrow on the cuff to give you an idea with positioning.
You need to try a different spot on your arm. Occasionally some people cannot give a blood pressure reading on their upper arm for a variety of reasons, and you should try getting a reading on your lower arm.
If you are still having trouble with your blood pressure cuff, take your monitor with you to your next doctors appointment so that your doctor can show you how to use the monitor correctly.
Mar 27, 2017 | Health & Beauty
Mod hem 704c reads high compared to doctors blood pressure readings
There are many things that can affect the readings. Cuff size is one of the biggest. If the cuff is on the small side it will not read as accurately as a cuff that fits properly. Keeping the cuff at heart level is important as well. Many people have to put the cuff lower on the arm if the cuff is too small and then they don't raise the cuff to heart level. This will give a higher reading. What is most important is to ensure that the readings are consistent. While they may be higher than the doctors office, as long as they are not dangerous, use them as a baseline and monitor fluctuations over time to ensure that your medications are doing their intended work.
Feb 15, 2016 | Health & Beauty
Replacing leaky cuff
blood pressure monitor replacement cuff, links below are to replacement cuffs and are fairly self explanatory to install
press the helpful button and follow me on fixya for more tips
Blood Pressure Monitors Parts and Accessories
Blood Pressure Monitor Replacement CuffWalgreens
OMRON Healthcare Blood Pressure Monitoring
Feb 03, 2016 | Health & Beauty
User manual for equaline digital blood pressure monitor model BA-717A
No, it is not able to be calibrated by the user. If your arm is too large for the cuff it will read high. Most cuffs are made for small framed people. Try wrapping it around your lower arm and position it about 2-3 inches above the wrist. use the wrist to take the b.p.
Jan 12, 2016 | Health & Beauty
HD 1000S Blood pressure monitor will not display blood pressure after inflating code ERR 1
tighten the cuff more around the arm or if you have a small arm pull your sleeve down then put cuff on and try it that way see if it helps
Jan 22, 2012 | Health & Beauty
Omron- HEM712C- why does the\r\ncuff opens,when trying to take pressure.
It's likely due to either improperly seating the cuff over your arm, or the cuff being sized to small for the circumference of your arm. First make sure that the cuff is set up properly, the "hook" end of the velcro needs to be facing away from your arm. Once you double the cuff back, make sure that it is not so tight as to be cutting off circulation. If this occurs the force of inflation will cause the velcro to separate. It's also possible that the package included to small of a cuff. If so the manufactor has a largercuff here.
Mar 13, 2011 | Omron Healthcare Omron Hem-712c Automatic...
Cuff does not inflate properly. Blows up like a balloon and does not press on your arm
I think your BPM machine has some problems in the electronic components it might not due to the cuff. Shoud return to the shop when you bought it from.
Jan 10, 2011 | Life Fitness Ultra Blood Pressure Monitor...
Readings are too high compared to doctor's readings
There are several reasons for 'too high' readings; the cuff is too small for your arm, the muscles of the arm are not relaxed (squeezes on the blood vessels along with the cuff), arm not elevated to about mid chest level, BP tkaen before 5 minute sit/rest.
You can take your cuff into the doctors office to have it checked by the nurse and compared to theirs, rest 5 minutes ther as well befor taking BP. Their cuff could be too big for you and so would give a false low reading.
If the calibration is off, you will have to return it to the manufacturer - check their web site or call the customer support line.
Congratulations on taking an active role in your health care!
Dec 01, 2010 | Homedics Automatic Arm Blood Pressure...
My Omron 711 seems to register readings that are too high when compared to doctor's office or monitors in drug stores, etc. Is there a way to check accuracy of the monitor?
Take the cuff to your doctors office and have the nurse check with yours and the office BP cuff. If your cuff is too small, you will get a false high reading.
Nov 30, 2010 | Omron HEM-711 IntelliSense Automatic Blood...
Health & Beauty Logo
Top Health & Beauty Experts
Robin Hill
Robin Hill
Are you a Health and Beauty Expert? Answer questions, earn points and help others
