Question about Kenmore Kitchen Ranges
My Kenmore electric range clock has to be set every so often. No power failure just start blinking
KOakaKO
  • 135 Answers
SOURCE: how do i set the clock on my electric range
Here's the URL to page 8 of the User's manual for your JBP24 Range:--> http://www.fixya.com/support/p128492-ge_jbp24_quickclean_electric_kitchen/manual-12867/page-8 ...and the rest of the User Manual is there as well, of course. Hope that helps. ;)
Posted on Aug 09, 2007
fridgetech
  • 473 Answers
SOURCE: clock,timer and oven does not work on Kenmore gas Range
Unplug the unit and see if this will reset the board. If this doesn't work then replace the oven control board.
Posted on Oct 05, 2007
the dr
  • 447 Answers
Let me know the model# and ill see if there are any thermal fuses. If not than most likely you will have to replace the EOC (Electronic oven control). Available at www3.sears.com
  • 11 Answers
SOURCE: need part number for a kenmore range clock/timer replacement
part #496225
Posted on Dec 05, 2007
SOURCE: Display area and clock will not re-set on Electric Range
on any appliances need to know the model and serial num some problems are model specific
Posted on Dec 28, 2007
I have a kenmore portable ac 12000 btu model number on the side says 35132 i have a serail 351321102073 i have a e3 code displayed what does that mean?
The E3 F1 error code indicates a Fuel Type Failure. The control board on the Kenmore ranges and ovens that use this error code can detect whether the control board programming is set for electric (E) or gas (9). The troubleshooting for this failure is to unplug the range or shut off the breaker to completely kill power for 30 seconds. After powering the unit back up, hold the CANCEL and START/ENTER keys for 5 seconds. You should see "E" for electric or "9" for gas. If you have an gas range and the "E" is showing for electric, then the electronic oven control board will likely need to be replaced. The opposite is true if you have a gas range or oven.
Jun 13, 2017 | Kenmore Heating & Cooling
How can I determine the cause of the error code on my Kenmore Free Standing Electric range, Model # 911.9344190? Error code is PF.
PF stands for power failure. Check the voltage at the wall outlet and make sure the connections are tight at the terminal block...
Dec 31, 2016 | Kenmore Kitchen Ranges
Kenmore electric range model 970 6362 SAB code.How do i reset this so the oven works again?
Hello. Try pressing and holding the "clock" button until the "SAB" starts blinking. It will then clear and the normal clock display will be showing--your oven is in "Sabbath mode" presently!
Sep 10, 2015 | Kenmore Kitchen Ranges
KENMORE ELECTRIC RANGE 95032. EVERYTHING WORKS BUT OVEN DOES NOT HEAT.
If your electric oven is taking too long to heat or just not heating up right,then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Nov 25, 2010 | Kenmore 95032 / 95034 Electric Kitchen...
Oven has a PF by time what is that for
PF is telling you that there was either a power failure (utility) or there is a problem with power coming to the unit from the house wiring. (Circuit Breaker) If you have a stop /pause /cancel button press it and then set the clock again. If the problem persists, just reply here and I will help you.
Kelly
Sep 21, 2010 | Kenmore 95002 / 95004 Electric Kitchen...
Fault code f90, door lock light keeps flashing and then the oven beep continuosly.
maximum oven door unlock time exceeded. Check wiring between eoc & door lock micro switch. more likely you need to replace the EOC
May 19, 2009 | Frigidaire 30" Self-Cleaning Slide-In Gas...
Pf??
PF means power failure.
For short outages the clock may still have correct time
(there is a battery backup for that), but the PF will
be displayed. Setting the clock will clear the PF
indication.
Press 'clock set-start' button, (under clock display)
enter time with numeric keypad,
press 'start' button. (to right of clock)
Jan 03, 2009 | KitchenAid KESC308LSS Electric Kitchen...
JKenmore Range
hi. thanks for the question. the fi failure code says to replace electronic oven control. sorry . thanks the appliance doc
Sep 17, 2008 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Kenmore electric range 911.9369181
F8 Failure of Electronic Range Control (ERC) Replace Electronic Range Control/Clock (ERC)
Dec 01, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Kitchen Ranges Logo
26 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
