Whirpool washer model LSQ9544KQ0 twists the clothes when washing. THank you for your help
    President:
  • 3,085 Answers
Move the top of the agitator clockwise then counter clockwise, it should lock and not move counter clockwise. if it does, you have a broken pawl.
Posted on Jul 25, 2009
WHIRPOOL washer model LSR8010PQ0, WHEN LOADED WIT...
If large items in the machine create an imbalanced load the machine is designed to switch off...Towels are notorious for doing this because they hold so much water. Jeans don't soak up much water. Wash towels with towels alone and the problem should be reduced....Good luck....Nomess
May 16, 2010 | Washing Machines
Whrilpool modle #lsq9544kq0 washer works in
Humming could mean a stalled motor. These machines also have a coupling between motor and gearbox which can fail. However, the pump is attached to the motor, so if it's not pumping it probably means the motor isn't spinning. Check motor and/or gearbox.....Nomess
Apr 18, 2010 | Whirlpool LSQ9544K Top Load Washer
Spin cycle won't work. Wash works OK.
sounds like motor brushes may need replacing.
Feb 17, 2010 | Whirlpool Ultimate Care II LSQ9549L Top...
My whirpool duel washer agitates or washes but
have you replaced the motor control. i had this happen 1 year ago and had to have it replaced. i am having the same problem and have done some testing but have not found anything else. you can buy this part from whirpool for about $160 delivered to your home. this is exactly how it acted the 1st time it went out. some loads would spin out great and the next load would be wet.
Oct 31, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Twisting of clothes
Fredkat2001, We are sorry to hear about your Washer twisting your clothing. Please make sure that you are loading garments in loose heaps evenly around the basket wall. We also would recommend mixing types of load items. If you try these troubleshooting tips and you are still in need of help can you please email usyour address, phone number, the model and serial number, the website you were contacted on, Fixya, your review ID, and date of purchase to Whirlpool_Digital@whirlpool.com?
Jun 15, 2017 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Duet - Soap not getting into wash cycle
O.K. Is the water draining out properly? If the filter is blocked then your washing will be churning in dirty water as the machine will drain for a maximum time then rinse etc. in the used water.
May 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool Cabio washer knots clothes/sheets into tight balls
whirlpool had a service bulletin on this. New agitator design. replace with new design.
Mar 14, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Clothes and sheets come out wrinkled and twisted
Try not to wash large items with small items the large items like sheet will twist around the small item. causeing twisting and wrinkling. Also If you are overloading the clothes or underloading the clothes they will come out wrinkled. I would try to do some testing wash a load of only towels then wash a load of only t-shirts and other light weight items that you may have. Then do just a load of your jeans. What happens? Please let me know
Jan 10, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer does not spin with load. It spins fine with just water & no load.
sounds like the clutch is either worn out or has oil on it
Jul 01, 2008 | Washing Machines
Beko wma 510 washing machien leaving clothes un rinsed and wet.
Find out where your filter is & clean it out thoroughly, refit.
May 10, 2008 | Washing Machines
Washing Machines Logo
111 people viewed this question
Top Washing Machines Experts
