Question about Garden
I have dixon zero turn ztr4516k.i have a new drive belt having problems putting it on.is the a tensionery on mower can you tell me to put it on
Loringh
  • 185 Answers
SOURCE: DIRECTIONSTO PUT NEW BELT ON MURRAY MOWER MOD# 385800X80A
rushville633;
Can't help you directly but consider the following
Relying on the fact that lawnmower makers don't make too many basic changes, may I suggest that you take a digital camera and go visit your local Home Depot and/or Lowes and take a picture of the belt arrangement on a new mower. I bet they are almost all the same.
Hope this helps Loringh PS Please leave a rating if this works
Posted on Nov 09, 2008
  • 376 Answers
SOURCE: z force cub cadet zero turn belt problem
Try this one. It may have what you're looking for. Without your model #, I don't know.... http://www.partstree.com/parts/ Click on Cub Cadet then enter you model # on the left.
Posted on May 16, 2009
  • 32 Answers
SOURCE: John Deere F620 zero turn mower
you probably have the belt on wrong, check your manual to see if you have it on right.
Posted on Jun 21, 2009
  • 4 Answers
SOURCE: drive belt broke murray riding mower how do i put one in?
yes the drive belt is the bottom one it looks hard but is really simple the main thing is you have to look rite above the left back tire and remove two 5/16 bolts with an 1/2 in wrench to in stall drive belt the you install other belts
Posted on Aug 08, 2009
sleprocks
  • 147 Answers
SOURCE: Craftsman 19.5hp 42 drive belt shredded
most likely the belt was put on the wrong side of the belt retainer clips on one of the two pullys. I've done the same thing more than once. Make sure on next belt there are no sharp edges touching anywhere and while engaged or not.
Posted on Oct 22, 2009
Mower blades start an stop on Dixon zero turn 42 in deck
PDF]OM, ZTR 5421, 1994, ZERO TURN: CONSUMER - Dixon
www.dixon-ztr.com/ddoc/DIXO/...USen/DIXO1994_USen_5421_.pdf
The information in this operator's manual applies to all Dixon ZTR Model 5421 Mowers. .... Before backing your Dixon Mower; stop, turn around and look. 13. ... startsvibrating, and any damage should be repaired before restarting and ... 13 GA stamped steel construction, 3 blades, 42" cut width, cut height approximately.
Sep 17, 2015 | Garden
Dixon 5020 mowerhow do i install drive belt on 5020 dixon
If, and I'm sure it is, like all other riders, remove the deck, turn the mower up on it's side and supported with a lawn chair or the like, it won't hurt the mower, remove the electric deck drive unit from the crankshaft by taking the center bolt out and pull it off, remove the clutch tensioner far enough to get the belt off it, then remove the belt from the motor pully and the hydrostat drive pully and pull the belt out towards the front. replace the belt with new one and put it back together.
Oct 15, 2014 | Garden
Carb problems
check and see if all your carb jets or clean sound like some dirt got into one
Jul 07, 2014 | Dixon Ticonderoga NEW 52" DIXON ZERO TURN...
What weight of hydraulic fluid is used in a dixon lawn mower
The motor takes 30 SAE. the drives take 20/50 SAE motor oil. I contacted the manufacturer of the hydro gear drives to find out what was used when I rebuilt one. There is only one manufacturer of all hydro gear drives. Their recommend Mobile 20/50 SAE.
Apr 05, 2013 | Dixon Ticonderoga NEW 61" DIXON ZERO TURN...
Should I buy a used 311 Dixon ZTR for my 1/2 acre yard?
Never buy one. Ever. Unless you have a mechanic from Dixon that will live with you to fix it every time you turn it on. I HATE it. If it isn't one thing, it is something else. Will not run. Tires a worthless. Seven thousand dollars of ****. Just call and complain and see if anyone cares. Nope. Cannot keep battery that works more than a summer. Nothing but trouble. Cannot get anyone west of the Mississippi to come to your house to service it. Must pull it in a trailer to get it serviced. Over all --junk. No one helps from Dixon, no one cares. Cannot wait until they go out of business. A sling blade would work better. Please get sheep or goats. Much more reliable.
Mar 07, 2010 | Briggs & Stratton Garden
My zero turn mower is not as fast as it was just changed the drive belt but it didn't help.
Although you'd think a new belt would do the job, there are a lot of other things that can cause your mower to slow down. I have a Cub Cadet myself, but it is a 1500 garden tractor. When mine began slowing down, I figured the belt was stretched and put a new one on.
If you go to www.cubcadet.com, take your model and serial numbers, you can download a parts maual and a service manual. One will show you what the other doesn't.
You'll see there are a myriad of adjustments to be made. The operator's manual will tell you there is no adjustment. Ain't true. When you get those manuals and have about two hours to spare, look up the section with drive belts in it. There you will see how it's done. Good luck!
May 13, 2009 | Cub Cadet Street Sign- tractor lawn riding...
Z force cub cadet zero turn belt problem
May 12, 2009 | Oregon Scientific Oregon Gator Mulcher...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
