Question about Freezers
I have a Midea standup freezer. It keeps beeping and the code E5 is on the display. How do I fix it.
Hotpoint fridge freezer ff200 tx displays error code A1?
These tempratures are pretty cold should be around 0 deg. but it sounds like you might have a bad defrost timer or defrost thermostat the frost should not come back if defrost system is working
Jul 26, 2014 | Hotpoint Freezers
How do you "warm" a Midea fridge do you turn dial higher (5) or lower (1)?
The higher the number, the colder the fridge gets. Is it too cold in the fridge?
Apr 27, 2014 | Midea 1.4cf Refrigerator White
Frigidaire Freezer keeps making 3 beeping sounds then displays a 1
Hello Melinda, when the refrigerator is beeping or buzzing, it may be a warning sign of a possible malfunction or an unsafe, interior temperature. To silence the buzzer, you can depress the ALARM OFF button. However, if you have already done this, try unplugging the unit or flipping the household circuit breaker for about ten minutes.
If the alarm continues, it could possibly be experiencing a communication problem with the temperature control/board, wiring failure or faulty compressor since error code 1 typically indicates an issue with the compressor. I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
I hope this information helps to some degree.
Jul 30, 2013 | Frigidaire Freezers
How do you defrost a older modle 13 cu ft standup freezer ?
Empty it out....pull the plug... get out the hair dryer....when all of the ice is thawed and the water soaked up then you plug it back in and restock the food...
heatman101
Jan 30, 2011 | Kenmore 13.7 cu. ft. / 388 liter Upright...
Temperature Alarm beeping/buzzing Kenmore Freezer 26041
Just incase>>>>
Is your circulating fan working?
It may be slowing down.
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Mar 17, 2010 | Freezers
Freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
freezer not working on ariston... Solve freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every... (More) freezer not working on ariston fridge freezer 2 orange lights on top of fridge keep beeping every two hours causing fridge not to work is there a reset button
Sep 13, 2009 | Freezers
Kenmore commercial standup freezer alarm
Sounds like the temp sensor is bad or intermittant. Check the connections to the display to see if they are loose. If not, the sensor might be bad, causing it to read the wrong temp. The fact that it is jumping around like that points to this kind of problem.
Oct 09, 2008 | Freezers
Frigidaire Upright freezer with Beeping Display
First make sure you have a good 9v battery installed. If it is ok then the problem will probably be in the display board or the wiring connectors between the boards. CE is communication error. If your model has the electronic tempature control instead of mechanical thermostat the problem could be in there. My bet is a bad connection at display board.
Sep 05, 2007 | Kenmore 20.6 cu. ft. Upright Freezer 24092
Freezers Logo
82 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
