Question about Car Audio & Video
Need wiring scheme for cma3558 - Car Audio & Video
How do I can to find wire scheme for Mobility Craftmatic Comfort Coach IV (4)?
You may be able to contact MonsterScooter to see if they can obtain a manual or give you some knowledge as to where the wires attach.
Jun 22, 2014 | Drive Medical Health & Beauty
I need a Craig CMA3558 Bluetooth speaker manual
http://www.craigelectronics.com/site/pdetails.php?id=496
Sep 05, 2013 | Audio Players & Recorders
I have 2 15" dvc 4 ohm kickers 1000 watt / 500 rms &a1000 watt avionixx 4 channel amp what would be the right wiring scheme?
need to know the ohms on the amplifiers then might can tell you best solution for system
Mar 05, 2013 | Car Audio & Video
Panduit mini-com tx6 cjs688tgy how can punch cable and what is the color coding
The colours refer to the (usually) colored pairs of wire in a Cat5, 6 or 7 cable. There are two schemes called 568A and 568B, where some wire are different. Since these jacks are used for permanent wiring, you can choose one of the schemes and use it at both sides of the cable. Watch out if someone has already installed network-cables in the same building and use the same scheme!
You dont need to "punch" the wires. This old method (LSA+) is not good enough, if you have very high bitrates, like we use today. Go to the panduit-website and download a data-sheet of your jack - it should include wiring directions.
hth, Karl
Oct 18, 2011 | Panduit Mini-Com TX-6 Plus (cj688tpor)
Need to know how to wire a RJ45 Cate 5E wall socket. Trying to understand the wiring diagrams which are numbered 1 to 8 where as socket is configured as A and B in two rows of 4. Fittings I have are Krone...
If you place the socket in front of you, the terminals from on the left side from bottom to top will use the white/blue, blue, white/brown, brown wires and the terminals on the right side would use the green, white/green, orange, white/orange wires from bottom to top.
A and B are used just to differentiate from the T568A and T568B schemes. So if you don't need cross-over configurations, you can just use the same on both ends. The method above is for the B scheme.
Apr 30, 2011 | Philips RJ45 Female to Female Ethernet...
Need color scheme identifying wire colors and use
Have you tried auto electrician or autobarn car audio dept but a store that does installs on site??
They are very knowledgeable & could more than likely write it out for u if they not flat out which is mainly on weekends
May 03, 2009 | Car Audio & Video
Need to know wiring scheme on back of garage door opener
join both wires the white one with the white one, and the white with black strip, with the same other, then connect it on the back of the motor the white wires with the white terminal (a white square) and the white with the black strip with the black terminal (a black square) .. check that both leds of sensors are on
Mar 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
97 color scheme for aux hok up
I could go outside and pop my dash apart real quick and tell you.Its real easy to take it off and pull the cd player and radio right out.Is your wiring harness missing or something?Is that why you need to know what it looks like?
Nov 23, 2008 | 1997 Chevrolet K1500
Car Audio & Video Logo
24 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
