Question about GE Monogram ZDI15C Automatic Icemaker
GE Icemaker stopped making ice. everything else
GE ZDIS15CSSL icemaker stopped making ice. everything else in machine appears to be working fine. I cleaned coils, ran cleaning function with solution. Water container fills with water, it's cold, just no ice. It's like the water isn't getting from the water container up into the cold section to make ice. Any suggestions please.
  • noble3104 Jul 25, 2009
    It is a free standing icemaker...not part of a refrigerator.
    Sergeant:
  • 187 Answers
Try these steps
  1. Check the shutoff arm
  2. Check the supply valve
  3. Inspect the water supply line
  4. Test the shutoff switch
  5. Check the freezer temperature
  6. Inspect the ejector gear
  7. Test the ejector motor
  8. Test the ice mold heater
  9. Test the holding switch
  10. Test the water inlet switch
  11. Test the thermostat
  12. Test the water inlet valve
pls rate my suggestion.......
Posted on Jul 25, 2009
How to trouble shoot GE ice maker that is not producing ice
Here is some information for you to study
  • GE Refrigerator - Ice Maker Not Making Ice - Easy Fix and ... www.youtube.com/watch?v=fPeZ29XdX5U
    • BY DIGITALPIMPLE
    • 4 MIN
    • 295K VIEWS
    • ADDED 2013-05-15
    Video embedded · How to fix your GE Refrigerator if it stops making ice. Easy quick Ice Maker fix if your ice tray suddenly stops filling. Check for this issue before going ...
  • How To Fix Refrigerator That's Not Making Ice ' Fridge Repair www.partselect.com/Repair/Refrigerator/Not-Making-Ice Find out how to repair a refrigerator ice maker that's not making ice by troubleshooting common ... can cause a refrigerator's ice maker to not ... GE Parts ...
  • Icemaker Not Producing Ice - products.geappliances.com products.geappliances.com/appliance/gea-support-search-content?... Icemaker Not Producing Ice. To minimize the possibility of electric shock, unplug this appliance from the power supply or turn the house circuit breaker/fuse to the ...
  • New Icemaker Not Producing Ice - GE Appliances products.geappliances.com/appliance/gea-support-search-content?... New Icemaker Not Producing Ice. If the refrigerator icemaker has just been installed, there are a few things that must happen before it can produce ice:
  • Jan 02, 2016 | GE Refrigerators
    Amana model tg21vl stops making ice
    pull on icemaker fingers to force icemaker , check for ice in tube to icemaker and listen for the valve to open , if all checks ok replace icemaker
    Feb 24, 2013 | Refrigerators
    My ice dispenser quit working
    There are multiple components that can cause this.
    Open the door and put your finger in the ice tray. Is there any ice or water in it.
    If so then the problem is likely the ice maker.
    If not then the water supply is either stopped up or the water valve solenoid is broke.
    If their is ice then the ice maker may not be making ice for other reasons. Is the Ice Level arm down? If so, the Icemaker has a clock like motor that is actuated by a temperature sensor.
    Ice maker calls for water, solenoid fills ice tray, temperature sensor gets cold over about 45 minutes and closes the motor circuit telling the icemaker to dump ice.
    If everything is right and still doensn't make ice, some mechanical aspect or the icemaker appears to be broken.
    Thanks for using FixYa, Good Luck.
    Mar 03, 2011 | GE Refrigerators
    Our GE side by side fridge isn't making ice. The arm in the ice maker starting clicking in the middle of the night and my husband just went into the freezer and held the arm up for a few seconds. The...
    It sounds like you have a bad icemaker. Usually when the arm is clicking its the gears that are stripped out. Feel in the icemaker if theres cubes frozen in there then you know the icemaker is definitely bad. With the arm in the up position it will not make cubes at all that is the off position for the icemaker. Hope this helps _MJ_
    Apr 13, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
    Icemaker not making ice
    Sounds like you need to replace the ice maker. The mold heater appears to be defective.The mold heats up prior to a ice dump. I donot believe it is worth repairing
    Sep 29, 2009 | GE GDS18LBR Bottom Freezer Refrigerator
    Water but no ice. ice in tray
    If you have a "paddle" switch just below the icemaker make sure there is tension on it, i.e. the tension spring might be loose. Make sure the tension spring end is inserted into a tiny hole. Mine wasn't, I did it and ice maker works fine now.
    Jul 17, 2009 | GE GSH25JSRSS Stainless Steel Side by Side...
    Good Afternoon: Icemaker on my side by side GE refrigerator all of a sudden start making a loud noise this morning and has not stopped since. There is evidence of ice buildup under the icemaker. Can...
    Hello: I have solved my problem for right now. I defrosted the ice buildup under the icemaker applying hot cloths until the ice dissolved , after the ice fell, the noise immediately stopped. In the past two days so far the everything is running smooth. Thanks so much!
    Jun 04, 2009 | GE GSS25JEMWW Side by Side
    Icemaker does not make ice after first harvest.
    theres whats called a cam inside of the ice maker and that is more than like;ly the problem. you can but your own ice maker from place like first service. good luck.
    Jan 30, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
    Ice maker stopped working
    Just a question... Is the motor that flips the ice down into its tube moving? or spining? your motor in the ice maker may have went out. might have to replace it.... hope this helps....
    Jun 17, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
    Icemaker just stopped making ice
    As these ice makers cycle there is an arm that moves up while the ice is being freed from the ice maker. After the ice is dumped into the dispenser bin the arm continues a downward motion. If it encounters ice in the downward travel it shuts the ice maker off. If this arm is locked in the full up position the ice maker is manually shut off. Check this arm and make sure it is not locked in the up position.
    May 15, 2008 | GE PSS26MGS Side by Side Refrigerator
    GE Monogram ZDI15C Automatic Icemaker Logo
    933 people viewed this question
    Top GE Kitchen Appliances - Others Experts
    John Tripp
    John Tripp
    Charles T Nevin
    Charles T Nevin
    Sal De
    Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
