SOURCE: fax confirmations
i have read the manual end to end and I don't think you can.
Only thing I see is this.
Customizing your settings using the Lexmark Fax Solutions
You can adjust the fax settings in the Lexmark Fax Solutions. These settings apply to the faxes you send or receive.
The following table contains the Setup and Settings tabs for the Lexmark Fax Solutions.
On this tab
You can
Personalize
Send
Select when to print an activity report is the only close item I can find. Nothing whatsoever about a confirmation report.
SOURCE: Fax Confirmation Sheet
HP LaserJet 3050, 3055, 3390, 3392 AiO Product - How to Print a FAX Confirmation Report
Description
By default, a Fax Confirmation report (Fax Call Report) will only print when a fax error occurs. However, this option can be changed using the printer control panel.
FAX call report options
SOURCE: fax confirmation set up
document.tlSearch.tx.value=unescape("")
Description
SOURCE: Toshib E-450 fax confirmation.
Press the user functions button on control panel
Press Admin button and key in password and then ENTER
press the LIST/REPORT button
press report settings
press COMM.REPORT button
then press desired butons for each item
press enter
hope this helps!
C
Testimonial: "Thanks!"
SOURCE: How to have fax confirmation sheet print
open both one-touch speed dialing panels--press DATA REGISTRATION >set> press search buttons to display REPORT SETTING >set> search to OUTPUT YES (This will print a report with every transmission, next option will give you the option of whether to print the first page of the document (yes) to remind you of what it contains)
