Question about Dimplex Heating & Cooling
Hi - I have a Dimplex portable aircon unit GDC12RWA model and can't seem to work out how to make it heat.
I read the manual and confirmed it is a model that should heat and I can set the temp to a max 30 degrees C but my machine only seems to offer the snowflake symbol or the dehumidfy function when I press the function button. Am I missing something? Thanks Claire
catriver
  • 878 Answers
SOURCE: Digital Control (for oven temp and clock adjustment) not working
Puzzeled, usually when there is a stuck or shorted keypad there will be an error code. First let's see if we can tell if we are in Centigrade or Ferenhiet. Press the bake and broil button together for 2 or 3 seconds. SF should appear in the display. Press the broil pad again and C or F will be displayed. Toggle to F and press start. See if that was the problem. If not try to increase the speed of the + and - keypads. Press bake and broil together for 2 seconds until SF displays. Press the + keypad increase the speed of the control. It should toggle from 1 to 5, 5 being the fastest. Press start and see if that works. If niether works..then have someone remove the keypad ribbon cable from the control board and clean the ends with an eraser. See if that solves the issue...Catriver..post back and let me know.
Posted on May 12, 2007
  • 26 Answers
SOURCE: Electric Oven not getting hot enough
Sir, I think the top oelement is for broiling ONLY. It should not turn on when baking. The clicking may be the oven heating up.
How far apart were the oven temp instrument and the digital?
Don't expect them to match...they are inaccurate.
1. Heat water until it boils. Place digital therm in boiling water until it comes up to 212deg. If it is not at 212 in boiling water, record the error.(this gives a rough calibration to the digital)
2 Turn on oven, set to 350 deg, place digital therm on rack. Wait until oven reaches 350 (on stove) and read the digital. Note the difference between the two
Posted on Mar 30, 2008
hemantraj
  • 638 Answers
SOURCE: Hotpoint RGB747GER oven does not heat properly
www.repairclinic.com
Posted on Aug 18, 2008
kingbrizzle
  • 407 Answers
SOURCE: problem with mitsubishi air roof units
The thermostat would need to be insulated better from the air that is surrounding it. Im assuming that the thermostat is located on the wall unit where it blows out the air. This could mean that it is actually reading more from the outside temp, than whats inside the house. Another thing to consider is the location of the thermostat, even it being close to anything in the house that produces some kind of heat will effect the condition of the air. If anything, its the manufacturers mistake if it was properly installed in the first place and if defective, they should replace it. hope this helps.
Posted on Dec 28, 2009
  • 58 Answers
SOURCE: Compass reading on GPS 60cSx about 30 degrees too high
Calibrate the compass (Main menu --> Setup --> Calibration --> Compass), follow the instructions on the screen.
Also, see page 50 of the manual.
Calibration must be done outside - stay clear of any large metallic object (e.g. car).
Posted on Mar 11, 2010
Testimonial: "Many thanks for doing Garmin's job - In my opinion the Garmin hardware is great - the software, documentation and technical support are very poor."
I need a drain hose for a DAC-12005 Dimplex portable air conditioner as soon as possible thank you.
Google make and model and look for parts list and stockist's Fix ya does not do parts
Jan 08, 2018 | Dimplex Heating & Cooling
My heater isn't sending any heat .It seems like the fan isn't comming on
Most units heat comes on first. Does it get hot at all? may have over temp switch open and needs reset, after that check for fan operation. If fan does not come on it may lock out again. That would confirm bad blower motor.
Not sure if this unit needs this blower? Some space heaters it is an option.
Sep 07, 2011 | Dimplex Compact Electric Flame Stove...
The fireplace blower does not work therefore there is no or very little heat from my dimplex elect fireplace---thanks
This is a constant problem for ALL electric fireplaces with heaters. Either the Owners Manual fails to the manufacturer not telling you that the heating elements need routine cleaning, because they are sucking in household air to heat it and send it back out, So whatever is float in your household air (dust, lint & pet hair) near the floor goes into it, clogs it up and causes the heating element to overheat and fail. Or customers who have purchased these units don't read the Owners Manual.
These units, no matter who the manufacturer is were not designed to heat for long periods of time. In fact the heater element doesn't produce much more heat that a blow drier on high heat.
The heater and the blower and are in the lower compartment of the firebox. If you can access it, you can clean it with a shop vac and a brush attachment on the end of the hose. Be sure to unplug the fireplace from the wall outlet before attempting this. If cleaning it doesn't help, the blower motor will have to be replaced. You can order one from Dimplex USA.
Feb 06, 2011 | ACE Dimplex (r) Compact Electric Fireplace...
I wish to find a copy of an instruction manual for a Dimplex portable Evaporativeair conditioner - model Deva -13
Here's a link in pdf format for the owners manual for a DEVA-13 Dimplex Heater.
http://www.glendimplexdealer.com.au/Resource1049853HJDUFOS023X/Owners%20Manuals/Cooling/DEVA-13_IML.pdf
If the link doesn't work when you click on it, copy and paste it into your web browser.
Jan 18, 2011 | Dimplex DEC1000H Electric Heater
Can i fix the fan on my dimplex dac 9005 portable
1. Disconnect the dimplex aircon from the power source.
2. Dismount the motor driving the fan from its mounting.
3. Mark the motor lead wires accordingly.
4. Disassemble the motor, and replace the bearings.
(Take note of the bearing number located at sides)
5. After replacing the bearings, assemble the motor,
and have it remounted in place.
6. Reconnect the wires and palce an electrical tape
at the bare joints.
7. Conduct a test run of the unit..
Hpoe this helps.
Jan 05, 2010 | Humidifiers
Dimplex leaks from the bottom front
Hi, I have been through this many times. Locate the drain lines on the units. Check the filters and if they are foam, wash them in your sink. You will need to clean the drain hoses out as the have something in them, dirt build up most likely. If they have a drain trough for the condensation to drain to the hose, clean this also. If you have no compressed air tank to blow them out, you can try and lay something down to keep things dry, and try and poor hot water down the drains to open them up. Your best bet would be to spend $14.00 dollars and buy an air tank that comes with a hose and nozzle. Fill it with air and blow them out. This will solve this condensation problem. Best of luck to you, and happy Holidays,
Shastalaker7
Dec 16, 2009 | Heating & Cooling
Dimplex manual
HI
you could try here at or even email/contact them these should be able to give you the manual
Dimplex Heating & Fireplaces
riz.
Feb 05, 2009 | Dimplex Compact Electric Flame Stove...
Water leak with the dimplex dac12ac
Hi there seems to be a water outlet at thtop rear of the unit where you need to drain water from its a little" rubber plug" hope this helps good luck
Dec 07, 2008 | Heating & Cooling
Heating & Cooling Logo
Top Dimplex Heating & Cooling Experts
Paul Carew
ashburton
David Burbee
David Burbee
Are you a Dimplex Heating and Cooling Expert? Answer questions, earn points and help others
