Question about Saws
Piston, wrist pin and wrist bearing blew on a Hilti ds hs 80-14. Where can I get parts? Who made the engine?
  • 2,176 Answers
I would suggest calling Hilti direct at 1-800-879-8000 and speak with their tech department and they will be able to assist you in locating parts and your mfr question
Posted on Jul 25, 2009
    President:
  • 583 Answers
Suggest a hilti distributor try TOOLKING----------
youdoit
Steve P I have 60lbs of compr.any thing I can do besides junk the bike
Hey Brian,
oh yea...you can rebuild the top end.. if you can find the parts you need.. usually a piston, rings set, wrist pin, wrist pin bearing, two wrist pin circlips, and a top end gasket set. If the cylinder bore is scarred, deep scratched, etc,, you may have to bore the cylinder "one size over".. the dealer will let you know,, the "overized" parts do not cost more than standard..
assuming you are in the U.S.
Aprilia Official Retailers
Aug 30, 2017 | Motorcycles
I have a2005 yamaha fz1 and the wrist pin is stuck on the stator side of the case. How do I remove it?
I am not sure if you are referring to the correct part, but the wrist pin connects the piston to the connecting rod (piston rod). If you truly have a frozen wrist pin the only way to correct it is to remove the piston from the cylinder. On some engines the cylinders can be removed without disassembling the case, others can't, but this is not a job for the casual mechanic because it involves the timing.
Feb 23, 2017 | Yamaha Motorcycles
05 Dodge Neon 2.0 Head gasket fail between #3 and #4 cylinder.
YES SOUNDS LIKE A FAILED WRIST PIN, PISTON SLAP IS MOVEMENT OF PISTON INSIDE OF CYLINDER
Feb 22, 2017 | Dodge Cars & Trucks
99 olds.intruge 3.5 engine
loud knocking internal lower part of engine usually means [ rod knock ] --bad wrist pin -spun bearing -or piston ring]s] --that the worst other can be timing failure --or component failure --you need to isolate the noise and diagnose from there
Oct 01, 2016 | Cars & Trucks
Kia sorento 2012 produce sound look like power steering problem and it gets louder when ever I acceleration gear, so I took belt out and start the engin with no belt I found that sound was in engin!!
If its a knocking sound:
A KNOCKING SOUND IN THE ENGINE IS MOST LIKELY CAUSED BY ONE OF THE FOLLOWING
1. PISTON SLAP: Makes a sharp metallic noise. Idle engine and short out each cylinder plug. The noise will disappear when plug with bad piston is shorted. Noise will also disappear at acceleration. This can be caused by worn or out of round cylinder, or broken piston ring. Correct problem by re-boring cylinder and/or replacing piston.
2. VALVE NOISE: Makes clicking or rattle noise. Caused by excessive wear on valve stem or lifter, out of adjustment, or stuck valve. Correct by adjusting valve clearance, replace worn valve or lifter, regrind cam, replace valve guide and /or valve. A stuck valve can sometimes be loosened by passing oil through the carburetor while engine is running.
3. ROD BEARING KNOCK: Makes sharp metallic noise similar to a piston slap. Detection is opposite of piston slap. Rod knock is not heard at idle. Knock becomes louder as engine speed is increased. Caused by excessive rod bearing clearance. Correct by adjusting rod bearing clearance to .0015 inches by removing shims. May require re-pouring rod bearing.
4. REAR MAIN BEARING KNOCK: Makes dull knocking or thud noise. Detected at speeds between 20 and 50 MPH. Knock will normally decrease or disappear while pulling or decelerating. Noise will be detected the loudest at normal driving speed, when not pulling or decelerating. Correct by adjusting bearing clearance to .001 to .0015 inches. If knock is excessive, crank should be checked for out of roundness. May need to re-pour all main bearings to correct.
5. TIMING GEAR KNOCK: usually the most difficult to diagnose. If gear is loose or badly worn it will knock in all ranges. Run engine slightly above idle speed. Slowly open and close throttle. Knock will continue to be present, but just as engine slows down knock will become a slight rattle. Remove timing pin and reinsert into timing hole on timing gear cover. Press timing pin tightly against timing gear and accelerate slightly above idle. Knock will significantly be reduced or disappear. Correct by replacing both timing gear and crank gear as a matched set. The two gears should have a backlash clearance of .003 to .004. If more than .009 inch backlash, an oversize (.005) timing gear should be installed.
6. WRIST PIN SLAP: This can not be detected by shorting out the cylinder plugs. Rapidly accelerate and decelerate the engine speed. The engine will pass through a certain speed range when the wrist pin will rattle at about the same pitch as a valve tappet noise. This can be corrected by installing a new wrist pin bushing in the rod or new wrist pin f badly worn. Wrist pin should fit the piston and connecting rod with a tight metal to metal fit. The pin can be pushed into the piston and rod with a slight pressure of the hand. Pin to rod clearance is .0003 to .0005 inches.
Dec 15, 2013 | Kia Sorento Cars & Trucks
Makes knocking noise that sound like something is loos banging only when jeep warms up and only in gear
TROUBLESHOOTING ENGINE NOISES
Dec 07, 2013 | Jeep Cars & Trucks
Making knocking sound
Dec 06, 2013 | Nissan Cars & Trucks
V6 knocking noise
Dec 06, 2013 | Cars & Trucks
Knocking noise just started. Gets worse when accelerating. Seems to go away at certain rpm.Not sure what it could be?
Worn wrist pin or worn connecting rob bearing, regardless it a sign or worn internal engine bearings. Try adding some Lucas engine oil additive and see if the knocking goes away. If it does then it's your connecting rod bearing and if it's still there. Then it's going to be a worn wrist pin and will need to be replaced before you loose the engine from a broken piston.
Thank you for using fixya and good luck
Oct 21, 2010 | 2001 Honda Civic
Saws Logo
82 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Saw Expert? Answer questions, earn points and help others
