Question about Maytag MSD2454G Side by Side Refrigerator
Maytag msd2356ae ice maker will only give me hollow ice any ideas.
    Sergeant:
  • 187 Answers
Hollow ice cubes are most often cause by insufficient water supply. Icemakers fill for about 7.5 seconds, resulting in about 4.75 oz. (140 cc) of water into the ice cube mold. If there s not enough water pressure available at the fridge, cubes may end up hollow and/or the fill could continue to dribble, eventually causing the fill tube to freeze closed.
pls rate my suggestion.........
Posted on Jul 25, 2009
    Scholar:
  • 117 Answers
Turn your ice maker water fill up slightly. This is usaully found on the front of the ice maker under the cover and has a set srew with pos. and neg. to adjust . hope this helps.
Why are the ice cubes from the ice maker hollowed out in the middle?
in the ice maker there is a series of small pipes about an inch long emersed in a tray of water,the gas flows throught these pipes frezzing the water making the ice and thats why its hollow in the middle
Aug 26, 2012 | Maytag MFI2568AES Stainless Steel Bottom...
Maytag psd245ogr refrigerator, no water, no ice. Started with hollow cubes and over time smaller and less cubes. Finally, no ice in freezer and no water or ice at the door dispenser.
Check Temp inside freezer. It has to be down to about 10 or 15 degrees
See if water is in icemaker.
Pour water in Ice Maker and wait to see if it ejects.
If it ejects theb you need to replace water valve in rear bottom of fridge(Its the part that
attaches to water line out of wall)
If it doesn't eject then it is a faulty Ice Maker.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 23, 2011 | Maytag MSD2454G Side by Side Refrigerator
My wide by side Maytag refrigerator MZD2768GEB ice maker is making hollow ice. It seems that it is not cycling properly as very little ice is in the bin and most of the time the hollow ice is stuck to the...
Hi
Hollow ice is a sign of not enough water going into tray. Replace the water inlet valve or the fill and shut-off valve for problems with both parts. Hollow ice cubes usually indicate a low water problem. This is generally the result of an excess buildup of calcium and other deposits.Replace the self-piercing shut-off valve with a drill-type shut-off valve.Drill a 1/4-inch hole into the pipe and installs the shut-off valve the same way you would have installed the self-piercing valve.
Please get back to us if you have further query else please accept the suggestion.
Thank you for contacting fixya.com
Apr 01, 2011 | Maytag MSD2651 HE Side by Side...
Low water pressure in ice maker and water dispenser I changed the filter but water just dribbles out of water dispenser and ice maker makes hollow cubes
Make sure the water line to the back of the fridgeis not kinked.Ifit is replace it. Hope this helps,If so give us a 4 thumbs up. THANKS
Mar 02, 2011 | Maytag MSD2758G Side by Side Refrigerator
My ice cubes appear to be hollow. what is causing this?
The water valve is not letting enough water in . Replace the water valve .
Aug 06, 2009 | Whirlpool 21.0 cu. ft. Top Freezer...
Leaking ice maker
check tube in back of ice maker to see if it is all the way in
May 08, 2009 | Refrigerators
Water and ice maker
did you try changing the water filter? do you have good pressure at the water valve inlet?
Sep 13, 2008 | Maytag MZD2766GES Side by Side...
550 Ice Maker Making Hollow cubes or Small Cubes
Hollow cubes are usually a result of lack of water supply
Jul 12, 2008 | Sub-Zero Bottom Freezer Refrigerator
Ice maker is not putting out ice GE
Low water pressure usually the cause of that, just like when you get hollow ice cubes as explained here:
http://www.applianceaid.com/icemaker.html#hollow (http://www.applianceaid.com/icemaker.html#hollow)
Jul 03, 2008 | GE (PSS26MSRSS) Side by Side Refrigerator
My 9 month side by side refrigerator
Hollow ice would suggest poor water flow due to a blocked water filter, check the water flow before and after the filter, make sure you flush the water line out before fitting a new filter. Cheers Colin
Aug 12, 2007 | Maytag MSD2756G Side by Side Refrigerator
Maytag MSD2454G Side by Side Refrigerator Logo
496 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
