Question about NEC Lands Phones
My NEC DTL-8R-1G cordless phone is saying unregistered. How do i register it again? and set up the extension line to dial out. Many Thanks Michaela
The phone was taking incoming calls but not dialling out after i pressed the ext number 9. i was have a play around with the phone as couldnt get much help online and somehow 'De-Registered' it!!!!! Now i cant even recieve calls in. Please Help!
SOURCE: Cordless phones will not connect to base.
I just had the same problem and tried several things with no results. Then, I figured I had tried everything else so I just unplugged the battery pack, set the phone down for 25 minutes and then plugged the pack back in. Phone worked again after that.
Posted on Nov 14, 2006
  • 43 Answers
SOURCE: Will Not go to voice mail
Jennifer209, if you press FEATURE + the button VM is pre-programmed on what does it display? It should show the extension number pilot to VM. If you call it directly, what happens? If you get no answer calling it directly, your VM may be down.
Kaait, is it getting into the VM that's the problem, or doing things inside the mailbox that is the problem?
Posted on Feb 12, 2008
  • 43 Answers
SOURCE: Internal Call "Voice Call" and does not ring
You can toggle each individual phone extension as to whether or not it recieves a "voice" call or a "ring-first" call.
At the extension, press "SPEAKER - 60" it will display the mode. Press the * (asterick) key to toggle between the modes. Then press SPEAKER again to set.
SOURCE: Nec DTerm Series i - Feature Light Flashing URGENT
Thankfully I have found a solution that has worked.
A 'winking' (flashing) feature button indicates the station is in call forward - all calls mode.
To cancel this setting do the following
Lift the handset or press speaker
Dial the access code 4 + 2 (set as default)
Receive confirmation tone and restore handset or press speaker
I have found the manual at the following link to be the best resrouce ever - very easy to understand
http://www.nec.co.th/html/download/Manual/Features%20&%20Specifications.pdf
Posted on Jul 08, 2008
divatif
  • 39 Answers
SOURCE: uniden 5.8Ghz phone.
You need to reset the main base unit. Unplug the power from the back of the base. While the power is disconnected, press and hold the delete key while reconnecting the power. Wait for a long beep tone. When the display shows 88 or P, press play button one time. If you have a phone without an answering machine, disconnect the power from the back of the base, press and hold find hs button while reconnecting power.
Posted on Mar 17, 2009
How do I turn off DND????
For the NEC DSX DTL-8R-1, try pressing and holding the Volume Down button on the handset for 2+ seconds while the phone is in standby mode. This press and hold option toggles the Ringer Mute feature. It works when an incoming call is ringing or in standby.
The manual for the this phone is available online here: http://www.teamextenda.com/download/nec/NEC_DSX_Cordless_DECT_UserGuide.pdf .
I hope this helps.
Oct 31, 2014 | NEC DSX DTL-8R-1 DECT Phone
How do I set up the call divert on our NEC DT300 Series phone so that all incoming calls are diverted to another land line? The info on the back of the phone is - NEC DT 300 Series DTL-24D-1A(BK) TEL...
I am not sure which country you are in, but in Australia your divert depends on your phone carrier not your model. If your carrier and call plan supports call forward you just dial their set number and follow the prompts to turn on or off.
Oct 22, 2013 | NEC Lands Phones
Change the time on our NEC DT300 Series
What model of NEC phone system do you have? Go look in the phone or data room and look at the PBX. You might also be able to press Feature 3 to get some information which would be helpful to a tech. If it is an SV8100 try this:
To set the system Time:
1. Press
Speaker.
2. Dial
728.
3. Dial two digits for the hour (24 hour clock, 13 = 1:00 PM).
4. Dial two digits for the minutes (00~59).
5. Press
Speaker to hang up.
Oct 08, 2012 | NEC Lands Phones
DTL8R1 NOT REGISTERED
We have a NEC DTL-8-R1 cordless that was working fine last week and now today it says Not Registered. How do I fix this? Thank you
Sep 04, 2012 | NEC DTL8R1 Cordless Phone
How so i change the employee name on phone?
Press speaker key dial 700 Enter extension number (which will be 3 numbers like 101). Use the keypad to enter name (up to 12 characters) use # in between if there is a letter on the same button your just pressed. Press speaker once you've finished typing the name.
Jul 06, 2012 | NEC Dtl-12d dt330 12-button Digital...
I just bought Model D-1660-2. I cannot make the second handset work. I have charged the battery for more than 20 hours. I set all the Handset setup modes as instructed in the manual. Works for the main...
Welcome to FixYa.
Reset the units/set up by doing the following:
  • Turn OFF all the HANDSETS.
  • Remove the batteries of the HANDSETS.
  • Unplug the power source of the BASE.
  • Unplug the phone line of the BASE.
  • Let it stay that way for 30 mins.
  • Insert the battery again of the HANDSETS, make sure it is charged properly.
  • Plug back the power source of the BASE.
  • Plug back the phone line to the BASE.
  • Register any handset that is unregistered (refer to manual).
Keep me posted.
Jas247
Sep 10, 2011 | Uniden Cordless Phone
Handset says unregistered
The manual says that to register it needs to be completely powered off and then restarted. I unplugged my battery and then plugged it bacdk up.
Feb 28, 2008 | Uniden Cordless Phone
Oct 09, 2006 | Sony SPP-S2730 Cordless Phone
Lands Phones Logo
Top NEC Lands Phones Experts
Brian LaDuca
george  peters
george peters
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
