Question about Mini Audio Players & Recorders
My mini audio player will not pick up AM - Mini Audio Players & Recorders
Tip
How to watch commercial DVDs on your wide screen TV via WD TV Mini Media Player
WD TV Mini Media Player provides an easy and affordable way to play back your digital media on your wide screen TV.  It serves as a conduit between your TV set and USB drive storage, no matter it is a camcorder, a humble flash drive, or an external HDD. Simply connect WD TV Mini to your TV, plug a USB-connected storage into the player and you are ready to enjoy all your digital media in DVD quality playback.
WD TV Mini Media Player supported media formats:
Videos:
AVI (Xvid, AVC, MPEG4), MPG/MPEG, VOB/ISO, MP4/MOV (MPEG4), RM or RMVB 8/9/10
Audios:
MP3, WAV/PCM/LPCM, WMA, AAC, FLAC, MKA, OGG, APE
From the above list we can see that VOB is a playable format for WD TV Mini Media Player, does it mean that WD TV Mini can play all kinds of DVDs – whether home made DVDs or commercial DVDs? The answer is WD TV can not decrypt copy protected commercial DVDs, so you have to rip them. This tutorial aims to show you how to make it possible for you to watch commercial DVDs on your wide screen TV via WD TV Mini Media Player. What you will need is Pavtube DVD Ripper, it not only rips, but it encodes too. Following is the detailed operating steps:
Step 1: Click "DVD Rom", "DVD Folder" or "IFO/ISO" to load DVD files into this program.
Step 2: Select subtitle and audio track
Click on the pull down menu of "Subtitle" and "Audio" respectively to select your needed subtitle and audio language.
Step 3: Select output format for WD TV Mini Media Player
Click on the drop-down list at the end of "Format" to choose an output format for WD TV Mini Media Player. Your selection should be in the range of AVI (Xvid, AVC, MPEG4), MPG/MPEG, VOB/ISO, MP4/MOV (MPEG4), RM or RMVB 8/9/10. Here I select "Xvid AVI" as an example:
Step 4: Click "Settings" button to adjust video and audio parameters
The user manual tells us that when playback .avi (Xvid) video files, WD TV Mini supports up to 720*576 30fps or 720*480 30fps, so we need to follow the manual while ripping a DVD.
Step 5: Click "Convert" button to start DVD ripping
Once finished, you can get the generated files for WD TV Mini via clicking on "Open" button with ease. Afterwards, just copy the output files to My Passport portable hard drive or other USB drive, and then connect WD TV Mini to your TV, plug your USB drive into the player and you are ready to enjoy the movies ripped from your commercial DVDs.
For more: http://www.pavtube.com/dvd_ripper
on Mar 29, 2010 | Audio Players & Recorders
How do i hook up our panasonic mini dv player to our tv?? We want to watch our recorded video but CAN NOT figure out how to view it on our tv. We have hooked up the cables but can not view it...PLEASE...
If your mini DVD player has an Audio and Video outputs (A / V) connect the A/V cable (Yellow,White,Red) at the DVD and the other side to the TV audio video input (A /V) when you're done select at your TV the video source input.
Jan 07, 2010 | Panasonic IS-D898 IS Technology In Dash...
No sound form the headphones jack? The mini disc is playing on the frunt of the player can see.
Are you getting audio out of the back jacks on the unit? If audio output is okay, it's just the headphone circuit/jack.
Nov 28, 2009 | Sony MDS-B5 Mini Disc Player
I have a Sony MDS JE520 mini disc deck. How do I
requirements needed....1 rca (red & white) cable to mini plug, a software http://audacity.sourceforge.net/ ......once downloaded software and your device is connected to pc mic in / audio in...audacity lets you choose a format to save your file (pick MP3) this will take up less space on pc....this will take a little time to get uss to so prcactice a bit. if your mini disc tracks already have gaps between them or not...once recorded audacity lets you edit what you just recorded..(you can fade out/in any part of the file)....hope this helps you do what you wanna do...feel free to rate the help
Jun 24, 2009 | Sony MDS-JE520 Mini Disc Player
No audio after replacing ipod mini battery
You might just need new headphones..
Only one of my earbuds work on my earphone because they have been used a lot.
Jan 01, 2009 | Apple iPod mini 2nd generation MP3 Player
Dvd wont play in mini hi fi system
First, you should never use commercial cleaners on CDs or cassette heads. They can create more problems than cures.
Unit may have bad disk motor or optical pick-up
May 01, 2008 | Audio Players & Recorders
Converting a sony mini disc into a mp3/audio cd
i understand (i've gone through 3 sony md recordable players & now i have about 15 - 20 md with good mixes from clubs/carribean islands beach partys) the only thing i can suggest is invest in another mini disc that is capable of playing the 74 min disc (and speed that was recorded) here are two sites to check out 1--http://shopping.yahoo.com/s:Portable%20MiniDisc%20Players and 2-- http://www.google.com/products?hl=en&q=mini+disc+player&um=1&ie=UTF-8&ei=OhkbSozEApC6tAOr9NCSDw&sa=X&oi=product_result_group&resnum=4&ct=title
Nov 25, 2007 | Sony Net MD Walkman MZ-N910 Portable...
27 people viewed this question
Top Mini Audio Players & Recorders Experts
Jerry Greenberg
Jerry Greenberg
Are you a Mini Audio Player and Recorder Expert? Answer questions, earn points and help others
