B
Barbara Taylor Posted on Apr 28, 2017
I cannot get AM on my ONB154V203 mini stereo - Mini Audio Players & Recorders
How to set clock on onn mini stereo system
There are several onn mini stereo systems. Suggest you google onn stereo mini system, as there are several user manuals available. Select the one for your model & look for clock instructions
How do i get the sound from the computer to come out of a tv
Depends on output ports on your computer and inputs on your TV, what sort of cable required. I use a mini-stereo to mini-stereo cable, but most will use mini-stereo to AV (red & white). Look in the manual that came with the TV and you should be able to work it out.
I have a yamaha speaker yst-m7 but with no hookups I need all the wire
Amplifier Output 5W/Channel x 2 Frequency Response 90 Hz - 20 kHz + or - 3dB Speaker Unit 6.5 Cone, Full Range Magnetic Shielding Yes Diminsions (wxhxd) 3-3/8"x 8-1/2" x 5-3/4" Weight R: 1lb. 9 oz.; L: 1lb. 5 oz. Included Accessories AC Adapter, stereo mini plug cable, RCA pin plug cable Colors Black, Platinum Amplifier Output 5W/Channel x 2 Frequency Response 90 Hz - 20 kHz + or - 3dB Speaker Unit 6.5 Cone, Full Range Magnetic Shielding Yes Diminsions (wxhxd) 3-3/8"x 8-1/2" x 5-3/4" Weight R: 1lb. 9 oz.; L: 1lb. 5 oz. Included Accessories AC Adapter, stereo mini plug cable, RCA pin plug cable Colors Black, Platinum Amplifier Output 5W/Channel x 2 Frequency Response 90 Hz - 20 kHz + or - 3dB Speaker Unit 6.5 Cone, Full Range Magnetic Shielding Yes Diminsions (wxhxd) 3-3/8"x 8-1/2" x 5-3/4" Weight R: 1lb. 9 oz.; L: 1lb. 5 oz. Included Accessories AC Adapter, stereo mini plug cable, RCA pin plug cable Colors Black, Platinum Amplifier Output 5W/Channel x 2 Frequency Response 90 Hz - 20 kHz + or - 3dB Speaker Unit 6.5 Cone, Full Range Magnetic Shielding Yes Diminsions (wxhxd) 3-3/8"x 8-1/2" x 5-3/4" Weight R: 1lb. 9 oz.; L: 1lb. 5 oz. Included Accessories AC Adapter, stereo mini plug cable, RCA pin plug cable Colors Black, Platinum 3.5 mm. stereo mini jack x 2.
3.5 Stereo mini plug cable.
RCA Pin plug cable.
3.5mm stereo mini jack x 2.
3.5 stereo mini plug cable
RCA Pin plug cable
You might get these on Ebay im not sure which country you are in this might guide you to one
you could get this on Ebay if you dont have an account you will need to create one
Add Email adress
Add Bank Acc
Add Credit Card
also add your postal adress
also add a paypal account
when you get to the paypal login page at the bottom you will see new to paypal sign up tab
paypal to create an account
paypal registration password ,bank card /credit card,phone numbers home/mobile ,email adress and a postal adress
be very specific when you type in the search
always ask questions? before you make a purchase and keep the email/s for security reasons if the item arrives and its not as described
you will even see the pictures of your item so you cant make a mistake and get them home delivered
hope this helps
What Auxillary cord model will fit in my alpine cda-9853 stereo model?
Peripheral stereo mini plug cable (3 foot cable, male to male miniplug). around $20
Monster portable music player cable (stereo mini-to-RCA adaptor) around $20
Arista stereo mini-to-RCA adaptor (6 foot cable with mini and dual RCA plugs) around $5
Hope that helps.
HOW CAN I GET AUDIO ON THE PROJECTOR IF I CONNECT A DVD PLAYER TO IT??
hi, it depends how you connect the DVD to the projector. the projector itself has only one speaker (mono) - not so good for movies. the "audio in" is a mini stereo plug (same as headphones). you will need a RCA to mini stereo convertor - red/white (or red/black) RCA to mini stereo plug.
or you can connect a RCA to RCA (red/white to red/white) cable to an amplifier which is connected to speakers.
or just plain speakers, but you'll probably need a convertor cable from RCA (red/white) to a female mini stereo plug).
these cables are pretty cheap and can be bought in any Radio-shack.
hope it helps....
Just bought a stereo mini to rca cable. i have a macbook and a 32" dynex tv. I dont know where to insert the cables on the tv.
you need a mini to two rca plugs cable; once you have this: connect the red rca plug to the left TV stereo rca connector and, the white rca plug to the right TV stereo connector
and, the mini stereo plug to your speaker jack on the macbook You will now have sound.
then: connect the video to you macbook using another either s-video or, vga cable to the TV
I have connected my xbox with the projector but i seem to have trouble with receiving any sound,i have connected one of the yellow wire to the projector to get the visual but i'm stuck on getting the...
Your projector audio input is a stereo mini input. you will need to purchase a audio splitter. you will need a male stereo mini to two rca felmal. connect the stereo mini to your projector then the red to red and white to white rca.
1helpful
Kenwood Receiver connected to my pc
using the Y adapter method (i am guessing you are using just a single stereo mini-jack cable with a mini-jack to RCA adapter) you are only sending a standard Stereo signal to the receiver. Setting 5.1 in windows is just simulating (if using Stereo) or actually mixing 5.1 if you are using analog 5.1 (3 stereo mini-jack cables going to 3 mini-jack to RCA adapters using a 6 channel DVD input). if you have a surround sound audio card i suggest using the Analog 6 channel input by using 3 stereo cables each with their only adapter.
or, if you have a Digital output (Coaxial or TOSlink [optical]) try using that.
good luck.
2answers
Need Adaptor connect DJ Tech Turntable to Sony Mini Hi Fi MHCRG495
The USB turntable is likely a USB data connection and not a USB audio connection, so you will need to take the audio output from your Mac G4 to your Sony Mini Hi Fi...
You will likely need a stereo mini-plug (3.5mm or 1/8-inch) to stereo RCA plug cable (red and white RCA plugs). This is often referred to as a "stereo Y-cable."
Top Mini Audio Players & Recorders Experts
ADMIN Andrew
ADMIN Andrew
Steve Pack
Steve Pack
Are you a Mini Audio Player and Recorder Expert? Answer questions, earn points and help others
