SOURCE: problem jumps back and froth from tv1 to tv2
One of the inputs on the back of the 322 box is bad. usaly 1 wire runs from the dish into a seperator that splits the signal into 2 at the back of the box. you will need to call dish and have a new 322 sent out. 1-888-333-3474
SOURCE: Sharp TV CX51N3 How to tune channels
Here's the link to the full user manual.
Cheers
Rich
http://support.sharp.net.au/downloads/opmanuals/CX51N3om.pdf
SOURCE: In single mode, my remote for TV1 works, but in
Your shared view is enabled. , press the menu button, then option 6 then option 2, disable shared view then select done. ( this can only be done in single mode) then go back to dual mode.
SOURCE: I disconnected the 322 to install a new TV1. TV2
You should have one line entering the home behind the TV1 attached to it there should be a device exactly as you saw outside. You will want the line from outside connected to the single port called in/out and the SAT port goes to the silver seperator. The two lines leaving the seperator attach to the SAT in on the receiver. The UHF poret on the device connects to the home distibution port on the receiver.
Thanks for using Fix YA.
SOURCE: Dish Network 322 will not work both TV's at the
Hello! Dan Busa with Dish Netywork here intermittent signal loss like that is usually caused by some sort of glitch a hard reset ( unplugging it for ten seconds ) will usually resolve this. If your signal strength is at or above 80 that should be fine, but keep in mind you need good signal strength on both the 119 and 110 satellites ideally you should be at 70 .
