What can be the problem if indicator lights not flashing but stand still
Why wont my Sony trinitron tv turn on but stand by light flashes?
That Flashing Standby Light Indicates A Defect In Your Low Voltage Or High Voltage Power Supplies...
May 25, 2014 | Sony FD Trinitron WEGA KV-36HS510 36" TV
Ariston l63 is not rinsing proper cycle but instead flashing 12hr light
Error messages,
Your dishwasher is equipped with a safety system which is able to detect any operating anomalies. These anomalies are reported by one or two wash cycle indicator lights "G" flashing rapidly.
24463930-0h3kxpflbez5mdeb5anq3st4-3-0.jpg Flashing LED diode above the mark 12h (drying) indicates faulty NTC thermistor. So, could be faulty: thermistor NTC, wiring between NTC and control board, control board.
May 20, 2014 | Ariston Technologies L63 Free-Standing...
Won't turn on.stand-by light flashes.timers are
my Sony trinitron kv-g21s2 TV not working . conned to the power blink in TV power indicator led
May 29, 2011 | Sony FD Trinitron WEGA KV-13FS100 13" TV
All error codes start with the letter "E". An error code of E11 will have the five indicator lights flash once and the Start indicator light flash once.
Some models of Frigidaire washers come with a digital readout display that informs the operator of the unit's function and any errors.
Error codes indicate that a problem has occurred and should be addressed. Different models of Frigidaire washers may vary in their fault displays.
Some washer models use flashing lights at the unit's start, door lock, wash, rinse, final spin and control indicators to display error codes.
If the five indica
tor lights flash more than nine times, this signals a letter in the error code. The letter "A" stands for 10 flashes, "B" for 11, "C" for 12, "D" for 13, "E" for 14 and "F" for 15 flashes. An error code of EB2 will have the five indicator lights flash or blink 11 times, and the Start indicator light blink twice
hope this help?
Oct 23, 2010 | Dishwashers
Sony tv won't turn on stand by light flashing constantly
you need the circuit diagram of the model as the fault lies in the "Switch Mode Power Supply" of the set
Aug 16, 2010 | Sony FD Trinitron WEGA KV-32FS120 32" TV
The on off switch in flashing twice every three seconds
perhaps, you mean it is the on / off indicator light or stand-by light, not a switch? What flashes and then the TV to the stand-by? if true, you have to replace the crystal filter with CF506B code. tersbeut part in the main PCB board. its location in horizontal area.
Aug 05, 2010 | Sony FD Trinitron WEGA KV-SW29M50 29" TV
Honda nsr 125 right indicator problem
check for a faulty ground wire/s, or a faulty or lose connection
Jul 10, 2010 | 2000 Honda NSR 125
Got a sony grand wega kf-42sx300u tv. the standby indicator on the tv flashes
Im afraid my friend the lamp needs replacing (model: XL-2100E), if you have a hunt on google you will be hit with the pain of the cost... like me :(
Aug 11, 2008 | Televison & Video
TV turns off and green light flashes
Sounds like a faulty thermal sensor. If the lamp was bad the lamp indicator would be light.
May 17, 2008 | Sony Grand WEGA KDF-60WF655 60" Rear...
Televison & Video Logo
14 people viewed this question
Top Televison & Video Experts
