Question about Garden
Replacing transmission from K46 to a K66 in my D170 lawn tractor. Is there a "hardware" kit available with all the nuts,bolts required to change it out?
  • 376 Answers
SOURCE: large belt routing for crafstman lawn tractor
Go to... http://www.searspartsdirect.com/partsdirect/index.action Enter the model number that is under the seat. If it's a lawn tractor, it will start with 917. That will get you to all the diagrams of the mower.
Posted on Jul 02, 2009
mowerman1857
  • 389 Answers
SOURCE: How do I chamnge the oil in my Craftsman lawn
There should be a pipe OR quick release valve coming out the right side at the bottom of the engine where it bolts to the frame. Most of the Craftsman riders I have worked on, had a long pipe with an elbow at the end of it and a plug in the bottom of the elbow for draining. Turn the wheels all the way to the left to allow enough room for a collection pan. It holds less than 2 quarts so the pan doesn't need to be too large
Posted on Sep 22, 2009
nova2nv
  • 197 Answers
SOURCE: I have a John Deere LT 1`33 lawn tractor with a 13
I believe they are 8mmX35mm.
Posted on Nov 14, 2009
SOURCE: Loss of drive in a Craftsman Lawn tractor
I also have a Craftsman tractor with the same problem. Sears repairman said it needed a new transmission and it would cost $1,400 to install. A new one is about $1,000. Anyway, if you remove the battery and the battery tray under the seat it will expose the transmission fill hole (hex). I opened the top and it looked empty. I had a bottle of 90 weight gear oil in my shop and filled the transmission to the top. I have not had any problems with it since. $4.00 bottle of oil verses a new tractor is worth a try.
Posted on Nov 30, 2009
  • 8 Answers
SOURCE: Replacing blades
It is standard threads and should turn left.
Posted on May 18, 2010
Where do i purchase the nuts & bolts to replace headlight kit
Try Napa they may well have the parts . Try them on line
Jan 15, 2018 | Ford Cars & Trucks
Transmission repair or replace
Jim, The links below are what I found on the Net., You could also do a search with your year, make and model# for possible better results. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Rebuilding lawn tractor transaxle Part 1 of 2
1 Hydrostatic Garden Tractor transmission rebuild 1 of 4 Hydro Gear
Tractor hydro transmission rebuild part 1
Part 1 K46 hydrostatic drive Removal
MTD Transaxle Basic Rebuild Replacing all Bearings Part 1 of 2
Aug 20, 2016 | Huskee Tractor Replacement Riding Lawn...
Info on repairing transmission, install belts
This transmission will be a Tuff Torq K46 series. You will need to look along the transmission's drive axle housing to get the model number. From there you can look-up the parts at Tuff Torq website under their catalog page. There is no service manuals that I know of but I did find a discussion on .tractorbynet.com about repairing the K46 that has pics. See links below:
Tuff Torq Parts Look-ups
Tuff Torq K46 Repair Guide with Pictures
As belt installation Searspartsdirect.com will have the IPL for the mower.
Nov 14, 2014 | Garden
Hydrostatic mower won't go up hill
How old is your machine? I have a John Deere X300R which after just over 200 hrs got slow going upslope and then when hot would actually run back while on full revs and pedal right down hard. Contacted JD who said to get it "Lapped". Cost was $1,400 and likely to result in same again after another 150 to 200 hrs. This was a K46 drive unit. In the end I bought a K66 transmission and butchered the chassis to fit it. It is OK but I would not do it again as it cost about $3,000 all up and is not ideal. I am a retired manufacturing engineer so had the skills and gear. I suggest that your machine may be like mine was. I filled my new drive unit with synthetic oil, 15/40 grade and although expensive, I believe it is worth the expense. There is no quick or cheap way of overcoming the result of a defective drive unit that I know of.
Sep 27, 2014 | Husqvarna Garden
John Deere L130
I have not worked on these lawn mowers but there is plenty of posts on different lawn mower sites on how to rebuild the John Deere L1xx series transmissions. I would suggest have a read of this site. It also mentions the parts required and the cost. I understand these lawn movers use the K46 transmission system.
TuffTorq K46 Repair Guide with Pictures
Aug 15, 2014 | Garden
How to remove a stuck bolt on blades on riding mower.
The blade bolt can be very difficult to remove sometimes and will require an impact wrench. If that doesn't work, you will need to heat up the nut only with a Ox/Acetylene torch, then it will remove easily. Do not heat the nut too much or it will ruin the thread on the spindle when it comes off. Remember to heat the nut only.
Aug 06, 2014 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to replace transmission belt on x324 john deere lawn tractor
Remove 3 bolts and guard-A
Loose hardware-B-C
Remove nut-D
May 01, 2014 | John Deere Garden
How do you adjust the deck to cut evenly on a craftsman riding lawn mower.
make sure tire pressure is even first. one of deck hangers ether has an adjustable bolt and nut or ecentric. point blade tips out measure from tip to ground adjust nut up or down to even out. if ecentric loosen jam bolt in cente then turn bigger nut till tips are even tightn jam bolt
Jul 17, 2010 | Craftsman 42 in. Precision Cut Plus 24hp...
I have a husqvarna tractor yth1542 xpt . When it has run for about 45 minutes it will not climb hillls.replacing drive belt didnt work.
It is likely that your transaxle just isn't up to the task. I suggest that you try to operate the machine on the hills prior to going on flat land. This is a huge problem with these machines.
Jun 29, 2010 | Husqvarna 23 Hp 48" Deck Yard Tractor
Garden Logo
153 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
