Question about Cannon Computers & Internet
Help with checking mac address cannon ir2545 - Cannon Computers & Internet
I have the digiland tablet dl700d(c) and I can't connect to Wi-Fi I called Wi-Fi support they can't help because the mac address keeps changing is anyone else having this problem and what do I do
I find your question very interesting, and also your WiFi support comment, because in 18 years of IT consultancy and troubleshooting I have never come across a changing mac address.
The mac address is
"a unique identifier assigned to network interfaces for communications on the physical network segment. MAC addresses are used as a network address for most IEEE 802 network technologies, including Ethernet and WiFi."
The emphasis here is on "unique" and all network adaptors I have come across - ethernet or WiFi have had a fixed mac address. Are you sure they didn't mean IP address, as this is supplied by the router/access point via a DHCP server, and can change according to the access requirements of the router/access point.
If you go here:
MAC address Wikipedia the free encyclopedia
you can learn a lot more about mac addresses.
Hope this is helpful, if so would you please register that with Fixya
Dec 29, 2014 | Tablets & eReaders
How do i change mac address on panasonic tv
In Panasonic TV check your MAC Address:
Enter Set-up > Payer Setting
then Network> Network Setting or Network Status
After that LAN Connection Setting
here is your MAC address . for changing MAC address is easy but for better help
Apr 29, 2014 | D-Link DIR-600 Router
Blank wan mac address
You can't telnet based on the mac address you would be using the ip address. The mac is burnt into the device and isn't touched by a firmware update. If you did an update and the ip address changed, you can use a port scanner such as nmap to do a ping sweep and find the devices ip address.
Nov 17, 2013 | Computers & Internet
How to change my ditto mac address
The following procedure worked for me :
To change the MAC address of a Dane-Elec MyDitto Classic NAS, use the flash memory configuration hidden page :
http://(ip of your my-ditto)/flash.asp
- Enter the right MAC address (which is written on a sticker, under your my-ditto NAS... something like "001F1Fxxxxxx") in the field "NIC0 address:".
- Click the "Save settings" button. (The same page reloads, with empty fields : ignore it).
- Restart your my-ditto NAS (with the power switch).
After booting, the power led should stop blinking (stay lit), and your NAS should be available through PC client software (master/user usb keys) again.
If the problem remains or reappears (dummy MAC address again), the culprit could be the CR2032 lithium backup battery inside your my-ditto. In my 2-year-old NAS, this battery was too low (2.1V instead of expected 3V). To replace this battery on its socket, you have to open your NAS (voiding the warranty).
Good luck...Hope this helps someone !
Sep 26, 2012 | Dane Elec Dane-Elec myDitto 1TB 2-Bay Home...
Is there a free download for cannon LBP 3000 for a mac
Cannon LBP 3000 Driver
Please visit the above link from Canon Official Support & Downloads. Select the OS (Operating System i.e. Mac OS) and get the drivers for free.
Hope it helps! Good Luck!
Feb 26, 2011 | Canon LASER SHOT LBP-3000 Printer
(F5D6230-3) Wireless Router: i need to know how to change my mac address on my ...
In your browser's address bar, type
By default, leave the password blank.
On the Belkin setup page, go to Internet WAN.Then go to MAC address. You may close your computer's MAC address or type a specific WAN MAC address, if required by your ISP.
I hope this helps!
May 16, 2010 | Belkin (F5D6230-3) Wireless Router
Is a Cannon mp210 compatible with macs?
Mac OS X is supported for the MP210 but Mac OS is no...
I don't use the Mac myself but certainly that's the information provided on the website here:
Mar 03, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
Cannot scan to mac from a cannon mf4150
There is not yet Mac driver support for the scanner portion of this printer.  The printer should work fine, but no scanner as of yet.  Too bad no one told me at the Office store when I bought it.
Sep 07, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
X box live
tell it you have a pc...somehow...the problem should then fix itself. If you do have a MAC, first, your dumb for using a mac, second, check your macs information and settings until you find a mac address.
Jul 28, 2008 | Microsoft Xbox 360 Console
Computers & Internet Logo
Top Cannon Computers & Internet Experts
David Payne
David Payne
Are you a Cannon Computer and Internet Expert? Answer questions, earn points and help others
