Question about Max Audio Players & Recorders
I tried turning my volume up and in kept going up to max on its own. Now my controller doesn't do anything. Stuck on high. Thanks jimmy
  • 1074 Answers
SOURCE: AV-DV75 volume control not working
Hi Deebo check the following website good luck open the set and you will find the part number printed on the body of the component. NB.but i am in the belief that it IS your IC that is damaged.
Posted on Apr 26, 2007
  • 346 Answers
SOURCE: volume control
check the volume switch
Posted on Mar 18, 2008
SOURCE: Audio volume controller not properly working
I am not sure about the solution, but I had a similar problem. My technician opened up the controller and cleaned it physically, this solved my problem. I hope it solves urs too.
Posted on Sep 06, 2008
  • 2120 Answers
SOURCE: Volume control
Is there a sliding switch on the handset or on the left side of the machine?
Posted on Nov 22, 2008
  • 1940 Answers
SOURCE: The volume is stuck at 100 (max) and when I go to
It sounds like the a switch on the TV is stuck. This may just be a stuck button, or a bad Switch Board. Try moving the buttons around to stop the problem. If this doesn't work, you will probably need to replace the Switch Board.
Posted on Mar 14, 2011
Volume button sticks and raises to max level and cannot be turned down.
It sounds from your description there is a fault in the audio section electronics rather than with the button.
Dec 06, 2015 | Car Audio & Video
Pioneer vsx 52
I am trying to work out which has got the high volume.
If it is the Pioneer then it could be the volume control chip that is faulty. These days volume is no longer determined by a control that adjusts the signal level. The signal is passed to a chip and the volume control setting information is also passed to the same chip. If the chip goes faulty then the volume will sometimes go to max, regardless of the volume control setting. This can also apply to the TV sound as well.
If the sound level is high on other functions of the receiver, such as the radio, then it is certain to be the sound volume control IC.
Nov 10, 2017 | Pioneer Elite VSX-52
Volume on the WD 57733 turns up to full blast by itself. Cannot turn on the mute button using the remote.
volume button on your remote is stuck in the increase position. try another remote if possible or remove the remote batteries so you can atleast use the TV manually
Dec 23, 2013 | Mitsubishi WD-57733 57" HDTV
Kindle fire volume control doesn't work
Install an aftermarket volume control package like "Volume Control +" or if you have Root "AlsaMixer". These products allow you to set the "Master". Use one of the products to turn down the Master control.
Also, make sure the Volume Up is not jammed in the Up position.
Apr 08, 2013 | Amazon Kindle Fire HD
Vista: Volume control stuck at high. When I slide to min it resets it self back to max.
Does the volume gradually step up to max (1,2,3,4,5,6,7,8,9,10) or jump right to max volume (1>10)?
Jan 19, 2013 | Dell Computers & Internet
Tv volume stuck on max, volume + signal stuck, button is fine.
The problem is on the board with the controls----if remote receiver is not on same board disconnect that board--if it is unsolder the vol and channel buttons--the front buttons have priority over the remote--buttons will look fine but the switch under each will be your problem---better hope it is as only other cause is a microprocessor gone mad.
If you have a Ohm meter I can tell you how to prove this--going to have to get at the buttons--if you want to prove it is or is not a issue with the micro switches you are going to have to unsolder or test them.
Apr 26, 2012 | Televison & Video
The volume on my tv will not turn down. when i manually try to turn it down, it continues to go to full volume
Take the batteries out of all remotes that could control your T.V.s volume. Try turning it down. Try pushing the up button on T.V. to see if it's stuck. This T.V. doesn't really have a lot of digital controls, so it's probably a mechanical issue.
Dec 22, 2011 | Mitsubishi WS-55511 55" Rear Projection...
I turned the volume up the other day and it got stuck, it kept getting louder and louder. I turned it off, but now I can only use the CD player. I can't change the volume on the CD player. I also can't use...
You need to free the stuck switch. As long as it is jammed, it is going to send a signal to the microprocessor. The microprocessor can only handle one command at a time, so while the volume up switch is sending a signal to it, it will do nothing else.
Apr 07, 2011 | Sony CDX-R3300 CD Player
Top Max Audio Players & Recorders Experts
Are you a Max Audio Player and Recorder Expert? Answer questions, earn points and help others
