Question about Lands Phones
1. How can I change a BIN number day and night COS on the console if the display shows VIEW and not which Flex key to use? 2. What are the possible causes of LDK PC Admin not connecting to system?
SOURCE: Missing Processor Cores
If you are runnung Vista HP 32 bit (maybe Ultimate also), the problem lies with Vista. I had the same problem. I installed Vista Ultimate 64 bit and presto! Problem solved.
Posted on Nov 14, 2008
  • 6 Answers
SOURCE: Battery drain bin 1997 Ford Fairmont Ghia
probally the alternator check connections to it or replace it, take to auto electritian to ckeck if its servicable.
Posted on Apr 22, 2009
  • 149 Answers
SOURCE: Cannot change Main Voice Mail Greeting
after dialing 72 you must first hit the instr key in the display than dial 001 or 002.
Posted on May 02, 2009
  • 16 Answers
SOURCE: Compaq TFT 8020 Display Problim
have you tried going to menu and setting back to factory defaults? also, disconnect power cable and leave unplugged for 1 minute. Plug back in then see if problem is still there. Otherwise, something is wrong with the monitor that will need serviced or exchanged.
Posted on Jun 24, 2009
  • 910 Answers
SOURCE: Panasonic SC-HC3 micro system .
The least you should do is with the unit unplugged, remove the rear cover and check for an internal fuse. It should be somewhere near where the mains cable plugs in.
Posted on Jun 28, 2011
Unable to change time and program
HA hA ha ha who posted these suggestions? For a time change press "run" "clk" "the time in military time 2:55pm woul d be 14:55:00 and that's in hours:minutes:seconds" then press run again.
to set the day which is 1-7 and 1 equals Monday, Tuesday = 2, Wednesday =3 and etc... you'll have to press "run" "clk" "which day it is 1-7" "day" "run" to end it.
As far as programming the schedule for the bells I can't figure it out. I know it's something like "prg" "loc, which would be the location number 1-99 or however many location positions there are" then "time, 24hr military format again" then "day, 1-7(days of the week)" then "cde, which is the code format( have no idea what the code format is, but i just use 3 as the code" and then i assume it's "run" to end it but it doesn't work.
Nov 10, 2012 | Computers & Internet
Last night the screen for my Motorola V365 stopped coming on. I hear the usual musical tones when the phone is turned on or off, and the keys light up for a few seconds as usual, but the screen remains...
there is nothing wrong with your screen, the problem is from the flex that connects your screen to the phone's main board. This flex must have worn out that's why your screen is not displaying any picture.
The problem is common with flip and slide phones. The flex gets worn out as a result of constant opening and close of the flip or slide phone.
I would urge you to replace the flex and I am assuring you that your screen will display picture again. You might also be lucky to find out that the flex is not well fix, that is, it may have loosed contact.
If you cannot change the flex yourself, maybe you should take the phone to a local repairer within your vicinity, so that the flex can be fixed/replaced.
Take care.
Aug 01, 2010 | Motorola Mobility V365 Cellular Phone
How to use the cosine,tangent etc functions of calculator fx-82ES plus
1.Set the correct angle unit required by your problem: degrees, radians, or grads. [SHIFT][MODE] [3:deg] or [4:Rad]
2. Press the key for the function COS, SIN, or TAN
[COS] displays Cos(
3.Enter the angle 12 deg Screen shows cos(12
Close the right parenthesis ) Screen shows cos(12)
4.Press [=] Screen displays 0.9781
If you want the inverse trigonometric functions you access them with arccos [SHIFT] [COS] (cos^-1)
arcsin [SHIFT][SIN] (sin^-1)
actan [SHIFT][TAN] (tan^-1)
You have to know the principal domain for the inverse trigonometric functions (see any book on trigonometry) to understand the results.
Hope it helps.
Nov 05, 2009 | Casio Office Equipment & Supplies
Need to program extension to ring on incoming calls
Professional Level 1 programming to make a phone ring on incoming calls:  1. On the phone you want to change ringing, press <FNC> - 4 and the screen will show the port number and the station number. If it doesnt have a display, borrow one and plug it into the cord that is attached to the wall, then do this. The port number is needed since all station programming is port based.
2. From ext. 10 or 11 (or whatever the extension numbers are for ports 01 and 02 are), with the phone idle press ,<FNC>, <HOLD>, #,0,*. The screen should show "PROGRAM MODE".
3. Press Line Key 4, which is the 4th button across the top. Dial "15", screen should show "01 / 15: 12345678" if you're in the right place. In this mode, the * key moves the cursor right, and the # key moves the cursor left. The first two digits are the port you're programming, the next field is the program code, "15"in our case, which is Daytime Ringing, and the last field is the data setting for this port.
4. Move the cursor to the left so you can change the port field to the port number you found in step 1. After changing the port number, move the cursor back to the right to the data field, and press the digits corresponding the the line number you want to ring, e.g. for line 1 press "1", for line 4 press "4". Each digit pressed in this field is a toggle, so if you press "1" when the digit "1" is already displayed, you will turn off ringing.
5. Verify that the display settings are correct. For example, if you want port 04 to ring in day mode on lines 3, 4 and 5, the display should show "04 / 15:   345    ". If all is correct press <TRF>, and note that the screen advances to the next port automatically.
6. You can change Night Mode ringing by setting the program code field to "16" instead of "15", then the same procedures apply.
7. When all changes are completed, press <SPKR> to exit program mode (or lift handset and hang up).
Dec 16, 2008 | NEC Electra Professional ETW-16DC-2
Phone in night mode
go to EXT 100 and program a key with a code 560.
you will do that by pressing the menu or F1 key and then fallow the steps for programming a key.
once you have programmed the key press it once and the display will start changing from night to day to holiday, pick the day and you are done.
Better yet, go to the phone that has on the display word NGT/night, or DAY, HLDAY and press the each key until the display changes that word on the display. one of the keys is programmed with key code 560. the phones that do not show Day, Night and Holiday will not have the key.
let me know if this does not work for you, or you need other help
Oct 07, 2008 | Executone 64 Corded Phone
How too change time
Norstar Merdian Press Feature.
Enter "**8463".
Enter the password (default is 266344). The display shows
Hour: 01
Next Change
Select CHANGE. Display shows:
Hour: __
Cancel
Enter two digits for the hour. Chose AM or PM when Prompted.
Select NEXT.
The display shows:
Minutes: 00
Next Change
Enter the minutes.
Press the RLS button to end, or press NEXT to change the date.
The diplay shows:
Year: 99
Next Change
Enter the two-digit year.
Select NEXT and repeat to change the month and day.
Press the RLS key to save the time and date and exit programming.
Top of Page
Norstar Meridian CICS Time
  • Press "FEAT".
  • Press "*".
  • Press "*".
  • Press "266344" (CONFIG) or "23646" (ADMIN).
  • Enter password "23456" (ADMIN) or "72787" (SCPLUS).
  • You will see "Terminals & Sets".
  • Press "Next" five times.
  • Press "Show"
  • When you see "Hour", press "Change" or "Next" to skip.
  • Type in the hour using military time as a 2 digit number.
  • Press "Next".
  • When you see "Minutes", press "Change" or "Next" to skip.
  • Type in the minutes using a 2 digit number.
  • Press "Next".
Date:
  • When you see "Year", press "Change" or "Next" to skip.
  • Type the year in 2-digit format.
  • Press "Next".
  • When you see "Month", press "Change" or "Next" to skip.
  • Type the month in 2-digit format.
  • Press "Next".
  • When you see "Day", press "Change" or "Next" to skip.
  • Type the day in 7-digit format.
  • Press "Next".
  • When you see "End of List", Press "Rls" to exit.
Top of Page
Nortel Norstar Telephone Systems Changing the time on a Norstar system must be done using a display phone. Using a M7310 or T7316 the right 2 buttons under the display are "NEXT" and "SHOW" respectively.
  1. To enter programming mode press "FEATURE" and "* * 2 6 6 3 4 4"
  2. Enter password (default = 266344) - display should read "Terminals & Sets"
  3. Press "NEXT" 5 times - display should read "Time and Date"
  4. Press "SHOW" - display should read "Hour:___"
  5. Press softkey "CHANGE"
  6. Enter hour - display should read "AM OK or Change"
  7. Select AM or PM
  8. Press "NEXT" - display should read "Minutes:___"
  9. Press softkey "CHANGE"
  10. Enter minutes
  11. Press "NEXT" - display should read "Year:___"
  12. Press softkey "CHANGE"
  13. Enter year
  14. Press "NEXT" - display should read "Month:___"
  15. Press softkey "CHANGE"
  16. Enter month
  17. Press "NEXT" - display should read "Day:___"
  18. Press softkey "CHANGE"
  19. Enter day
  20. Press "NEXT"
Sep 15, 2008 | NorStar T7316E Corded Phone
Phone doesn't ring at station
Sounds like your station (phone) is set to not ring. You need to check your ring assignment.
Feat # *
Enter password (default is 000000)
Press the soft key under "show"
Press the soft key under "next" until 1. STATION appears in the display.
Press the soft key under "show" SHOW STA:_ appears.
Enter your station number and press the show soft key
Press the "next" soft key until RING ASSIGNMENT shows on the display.
Press the "show" soft key. You will see CO LINE 1 : followed by NONE or DAY or NITE or BOTH.
If it says NONE, your phone never rings for an incoming call. If DAY or NIGHT your phone rings depending on the time of day and the time definitions for DAY and NIGHT programmed into the KEY unit. If it says BOTH, your phone should ring all the time.
If you need to change the setting, press the "chg" soft key until the desired setting comes up.
When you're done with LINE 1, press the "next" soft key to move to the next line. Repeat the process for all your active lines. Obvisously changing settings on lines with no CO connection will have no affect.
While your in the mode, check your RECEIVE ASSIGNM as well to make sure your phone is configured to receive incoming call. It was the station feature just before the RING ASSIGNMENT feature.
Hope this helps.
Jun 04, 2008 | Vodavi Starplus SP7314-08 Corded Phone
PLease help me with my Nokia 6288... Thanks!
hi there i have had that problem once, and i'v solved it.
for the heating of the battery and no lights, no display, no signal its all for the flex(ribbon) problem all i did was remove again the flex and clean the contacts sometimes it shorts i just re-solder the contacts of the flex. because some of parts that we bought is not 100% ok. just try it again maybe you'll make it.
ok
peace!
Mar 28, 2008 | Nokia 6280 Cellular Phone
Blank screen
You can try the following: Trying pressing the * + # + Power at the same time - if it works the screen will show some letters and numbers - then you can try the following: 1) Flash the unit; 2) You or someone should check the flex cable which attaches the LCD to the main RF board; 3) Display and flex need to be changed (Expensive)
Aug 05, 2007 | Motorola Mobility RAZR V3
Need help withe the sin, cos, tan problem with ti - 83 plus
here are the steps in changing it from radian to degrees
1. turn on your TI-83 plus
2. press the MODE button near the top of your calculator
3.go down to options and move the highlight from radian to degree, press enter and clear
you're good to go
Feb 17, 2007 | Texas Instruments TI-83 Plus Calculator
Lands Phones Logo
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
