Question about Refrigerators
HOW TO REPLACE DEFROST TIMER ON A RT14WKXGW02 REFRIGERATOR?
22yooper
  • 828 Answers
SOURCE: Defrost timer
http://www.us1internet.com/FRS24XGCW2_141846.htm
The above URL will take you to an exploded view of the controls. Look at number 23 which will be located behind toe plate below door on the left side. That is the defrost timer. Rotate the clutch head screw Clockwise SLOWLY until you hear a loud click. That is the defrost timer starting the defrost. If the unit restarts after 18-22 minutes and defrost does not take place you problem is most likely the defrost thermostat.
Posted on Jun 20, 2008
SOURCE: defrost timer board for mzd2766geq
Defrost control board is in the top of the refrigerator behind the two levers that control the temperature. You have to take off the plastic cover. There are two screws and then you slide to cover to the side to remove. The board is in a white plastic housing.
Posted on Aug 25, 2008
  • 111 Answers
SOURCE: Defrost timer sticking
Your model doesn't have a defrost timer. Everything is controlled by the main motherboard in the back. The ONLY way to get an acurate diagnosis is to call GE FActory Service at 1-800-432-2737. There is proprietary software and the tech will be able to plug in a laptop to your refer to find out what is going on. No other companies have this or have access to this software. By the way that deforst thermostat you think you found isn't what you think it is. It looks like one but it only a saftey device. Trust me...!
Posted on Dec 16, 2008
  • 93 Answers
SOURCE: Need to Replace Defrost Timer
check bottom back left should be a small hole with a small plastic place to turn with a srew driver some are insidethe fride on the left side arond where the lite is if you see a mall plate with a srew open it it should be there thanks from gilles
Posted on Mar 15, 2009
  • 531 Answers
SOURCE: Location of Defrost Timer
you unit do not carry it carry a board it at the back off the unit
Posted on Apr 01, 2009
Maytag refrigerator model number rsw22eo having problem with freezer not defrosting
You have a=>68233-3 Defrost Timer mounted somewhere behind the kick plate at base next to floor. Can you turn the timer slowly clockwise until the compressor and fans stop? I want you to force the refrigerator into defrost. If after 30 minutes the refrigerator does not restart running again replace the defrost timer. Once you place the refrigerator into defrost the elements should melt the ice that has been building up. If placing the timer into defrost does not help you will need to replace the=> 61001846 Defrost Heater Assembly . I am here if you have questions, John Tripp Appliance 911
Contact me here.
Jul 31, 2014 | Maytag Refrigerators
Tip
How to Replace a Defrost Timer in a refrigerator?
What is timer?
Timer is a small motorized unit that controls the function of defrosts cycle in a refrigerator. The defrost timer tells the refrigerator when to cool and when to defrost any ice frost collected on/in the evaporator coil.
Now the procedure to replace the timer is as follows:--
1) First of all for proper safety please unplug the unit from power outlet.
2) Then to locate the timer. It is located behind the refrigerator beside the compressor of the refrigerator. You will have to remove the metal kick plate on the bottom of the refrigerator. In older models refrigerator it is built into the icemaker unit.
3) In some models timer is fitted by the screws on the side wall of the refrigerator unit. so if screws are seen remove the screws holding the timer to the refrigerator wall.
4) Then slowly/carefully remove the timer out of the unit so you can disconnect the wiring from the connectors. For easy access of connectors try wiggling the connectors back and forth it will be disconnected.
5) Before removing the connectors please take a note of which connector was connected where and in what position.
6) Then take a new timer and plug the connectors in same position and at same spot in the new timer.
7) The refit the screws if you removed while removing the old defrost timer, replace the kick plate cover and plug in refrigerator and check out.
This will help. Thanks.
on Mar 10, 2010 | Refrigerators
Defroster timer
Hello there,
Defrost timer is what is set automatically by the defrost unit consisting of the defrost thermostat, defrost heater and the defrost timer. It is the timer that sets the routine timing of self defrost in the refrigerator.
If the defrost timer goes bad, it will stop the defrosting cycle of the refrigerator.
HERE ARE SOME TIPS ON HOW TO TEST AND REPLACE YOUR DEFROST TIMER. http://www1.fixya.com/support/r10523722-test_defrost_timer http://www1.fixya.com/support/r10523742-replace_defrost_timer
Hope this helped. All the best Elect_Comp
Sep 26, 2011 | Refrigerators
Replacing defrost timer,needs manuel
I check there is no free manual for Kenmore, I find. Better follow these steps to replace defrost timer.
Unplug the refrigerator. Locate the defrost timer. The timershould have four metal terminals coming from the bottom of the unit. It isusually situated behind the refrigerator, in the refrigerator's control panel,the freezer compartment toward the front of the cabinet or behind a metal kickplate on the bottom of the refrigerator. Older Kenmore models may have it builtinto the ice maker. Remove the defrost timer by takingoff the kick plate (if there is one) and removing any screws attaching it tothe refrigerator or freezer. Carefully pull the timer out from the wall of theunit so you can disconnect the wiring from the connectors. If removal isdifficult, try wiggling the connectors back and forth to help loosen them andpull on them firmly. Plug the wire connectors into thenew defrost timer and replace the timer in the refrigerator. Secure with screws, replace coverand plug in refrigerator.
Thanks and helpful?
Jan 23, 2011 | Kenmore Side by Side Refrigerator
Frost free fridge freezing up
How to check everything
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Sep 11, 2009 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerator or freezer is not cooling much ...
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Sep 07, 2009 | Refrigerators
Freezer coils freeze up solid with ice and have to be defrosted manually
Aug 30, 2009 | GE Refrigerators
Fridgidaire 18 cu new defrost timer and evap fan stil freezes
Did you replace the timer with the correct one for your refrigerator? If so you may need to check the defrost thermostat out.
Mar 26, 2009 | Frigidaire FRS3R5EMB Side by Side...
Refrigerators Logo
35 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
