Question about Saws
Are there ceramic tiles that I can buy with my own design on them?
    Top Expert:
  • 12,744 Answers
Their are tile stone places hat will do customize work or make custom products will need to search in your area
Posted on Apr 28, 2017
Where can I buy high-quality bathroom tiles in London?
There are a lot of tiles and marbles suppliers and manufacturing companies in London who provide an exquisite range of top-quality porcelain and ceramic tiles suitable for both indoor and outdoor spaces including kitchens and Ceramic Tiles Bathroom in London.
MKW Surfaces offers one of the biggest ranges of bathroom tiles in the UK at very reasonable prices. In ancient time, fine stone that adds a touch of luxury to any space. It comes in hundreds of different colors and patterns and every piece is unique. Explore at: Carrara Calacatta Natural White Marble Kitchen Worktops
Jan 19, 2016 | Felker FRS-38 Tile, Marble & Granite Rail...
How do you drill through ceramic tile
Go to Lowes, Home Depot, Menards or reasonably good Hardware store. buy a ceramic bit. They are usually with the wood, steel and concrete bits. Small bits arent to pricy. If you need a larger hole like the on the shower pipe goes through, you will need a ceramic hole saw. Hole saws are coated with diamond chips and will probably cost $40 or more. good Luck
Oct 08, 2015 | Porcelanosa Ceramic Wall Tile: : Mosaico...
How install the soap dish
There are a couple of designs, one is surface mount and the other is recessed. Surface mount mounts with silicone (hard to imagine it would last) and the other installed similar to a tile, but using grout. The grout install gets a hole cut in the tiles, goop everything up with grout, and goosh it into the wall, clean same as you would when working with grout.
Both designs need support until the adhesive dries.
Dec 12, 2010 | Daltile Bathroom Accessories Resin Soap...
Can ceramic tile be installed over old ceramic tile?
You can install tile over tile. However here are the risks. The new tiles will require at least 3/16" of tile adhesive UNDER the tiles when put in place after they have been pressed into position. Additionally the trim around the tiles willhave to be removed and elevated the distance of the tile thickness and the 3/16" grout distance. The tiles if on the second floor of a home will easily losen due to the expansion and contraction of the home and the difference in the 2 types of tiles expansion and contraction rates.
It is not difficult to remove old tiles. You use a flat bar type scraping tool and the old tiles usually will pop right up off the floor. You will have to break maybe 2 tiles to get started but after that they are easy to remove.
My experience in my own fully tiled in all rooms 2900 sq ft home in the tropics is that I have to remove the old tiles as over time the new tiles losen on top of the old tiles. I have tried it several times and have had at least 1 tile come loose each time.
Thanks for choosing FixYa,
Oct 05, 2010 | Home
Where can I buy a tile guide
this site will help you to buy
thank you
Sep 22, 2009 | Ridgid Wts2000l 10" Wet Tile/stone Saw...
Tile Saws types problem
Mass produced ceramic tiles of medium to soft grades are cut easily with hand tools. The glazed surface of the tile is first scored with a tool that carries a hardened metal wheel. Then with a support directly under the score pressure is applied to either side of the cut and the tile snaps along the score. The harder grades of ceramic tiles like fully vitrified porcelain tiles, stone tiles, and some clay tiles with textured surfaces have to be cut with a diamond blade.
Aug 27, 2008 | Mk Diamond Wet Saw with Stand
Tile Saws question
Since tiles are so thick, brittle, and made of ceramic, a special saw must be used. An ordinary circular saw for wood or metal would either break the tile or get so hot that it would seize up and stop cutting. However, ceramic tile is not cut well with sharp blades. The wet tile saw was invented to address all these unique properties of ceramic. It doesn't overheat, uses a relatively dull blade with no serrations, and can be transported to a job site and set up on top of an existing table or sawhorses.
Aug 27, 2008 | Dewalt DW8306 36-Grit. 4-1/2" Blue...
Saws Logo
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
