Question about Building Materials
MY DOOR WORKS FINE WITH WALL MOUNTED SWITCH BUT MY REMOTE WOUNT WORK
    Master:
  • 496 Answers
Either your battery is very weak or dead or your remote has lost the code for the door. Replace the battery and reprogram your remote and you should be fine.
Semper Fi,
Z
Posted on Apr 28, 2017
The remote mounted on the wall works fine but the hand held remote don't work.
are the batteries in the hand held new. Are you stand within 20ft of door opener. You may have to re-sycn the codes with the handheld.
refer to owners manual.
Oct 12, 2014 | Building Materials
I have a liftmaster formula 1 1280R opener that works fine from the wall mount but all of a sudden both remotes and the built-in remote in my car stopped working. It is not the batteries in the remotes. ...
The motor/control unit may have gotten reset. It needs to relearn the codes transmitted by the remotes.
MIne has a "learn" button on the control unit. Press and hold, then press the button on the remote. Lights will flash indicating it has received and stored the code. Release button.
Check to see if the remote works now. If so, all three should be working. If not, dig up your manuals.
Feb 28, 2013 | Sears Craftsman LiftMaster Chamberlain...
Lift master formula I will not close, only goes half way down, but fully opens. Worked fine until my wife closed the door on the car, after that it would fully close
I had this problem as well with the door opening just fine but was not closing when using the remotes or when breifly pressing the wall mounted control. The door would close only when using the wired wall mount control. I have experienced this problem with other garage door openers I've had in my previous homes and it was always caused by sensors at the bottom of the door tracks being either misaligned or the lenses were dirty. In this case, and it was just a moment ago today, I simply cleaned the sensor lenses and then the door began to function properly. Give it a try.
Jan 28, 2013 | liftmaster Chamberlain Garage Door Opener...
Monte Carlo ceiling fan and light not working
Even a brief power outage can cause amnesia in the receiver. You can try disconnecting power at the source and spending a few minutes removing the battery from the wall-mounted remote and pressing all buttons to eliminate the 'stuck button' problem. Reinstall the remote battery and reconnect main power to the unit. Test operation.
Lastly, there always is the possibility that some gremlin changed your original control setup.
Jun 23, 2017 | Dryers
My Chamberlain Liftmaster Formula 1 garage door (2002) has stopped working. The power is on -- light turns on when I push the wall mount button. But the remotes no longer work. The door does not move. ...
The light by the learn button may be sending a diagnostic code. See if it is flashing a number of times, pausing and then repeating. Count the flashes. Is your door stuck in the open posititon?
Jun 11, 2011 | Sears Craftsman LiftMaster Chamberlain...
I have a door with two buttons and remote but only
On the wall control with the flashing light press and hold the button with the lock icon for 3 seconds and release.
Jan 10, 2010 | Sears Craftsman LiftMaster Chamberlain...
Genie Screwdriver, garage remotes won't work, batteries are fine.
Your receiver has quit working. A call to your local Genie dealer should get you back in business.
Sep 22, 2009 | Sears Craftsman LiftMaster Chamberlain...
Liftmaster garage door openers Model # 3245 (remote Issue)
it is possible that when you programmed the car remotes you erased the pairing between your hand held remotes and the unit. Follow the instructions to pair the remotes again and you should be good to go.
Sep 16, 2009 | liftmaster Chamberlain Garage Door Opener...
My keypad works,my remote opener does not, even
It is related. One of the buttons on your wall control is the lock button and has a lock icon on it. Press and hold it for 3 seconds. The blinking should stop and your remote should now work.
Aug 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Building Materials Logo
Top Building Materials Experts
Terry Smith
Level 1 Expert
Tom Chichester
ray gallant
Are you a Building Material Expert? Answer questions, earn points and help others
