Question about Daewoo Washing Machines
Daewoo DWC LD1412 washing machine that comes up with an error code of "HI" whether there is a load in the drum or not, but which prevents me from operating the washing machine.
2 Suggested Answers
  • 44599 Answers
SOURCE: I have a washer dryer combo (daewoo DWC-LD1412) am I able to use the dryer without having to do a load of washing?
check the hand book ( download from the net if you have lost it) you should be able to program it to dry with out a wash as you should be able to hang the washing with out using the dryer
Posted on Jun 25, 2015
Jun 25, 2015 | Washing Machines
Model DWC-LD1421 WHAT DOES FAULT CODE LE MEAN ON THIS MODEL
this is the code issue for the Daewoo washers things to check The washing machine or washer dryer door has been detected as open or unlocked.
  • Close the door!
  • Check the door lock switch
  • Check the door latch
  • Check PCB
Mar 09, 2015 | Washing Machines
Daewoo washing machine model number DWC-LD1421 what dose the fault code LE mean for this model
  • Close the door!
  • Check PCB
Mar 09, 2015 | Daewoo Washing Machines
My Daewoo DWC-UD1212 washing machine does not spin; and shows IE whenever the light indicator is on Spin. What should I do?
not sure bout the IE error But I would check the clutch, the motor coupler, the door switch, and the belt if applicable?
Feb 28, 2015 | Daewoo Washing Machines
DAewoo DWC-LD1013 will not spin
The Daewoo DWC-LD1013 is a washing machine, you may wish to post your question in that category, not in air conditioners.
Jan 09, 2015 | Daewoo Heating & Cooling
Installation instructions DWC/CV701PC
Is this : http://www.daewoo.cl/sta/manuales-tecnicos/Manual%20Tecnico%20DWC-300M.pdf what you are looking for?
Oct 07, 2014 | Washing Machines
Daewoo DWC-UD1212 Washing Machine
Washer machine when I select manual wash , LE letter show on program monitor , and washer machine is not work.
Aug 29, 2013 | Daewoo DWDWD3011WW Front Load Washer
Hi we have daewoo washing machine coming error E2
Error code E2 is overflow problem, possibly related to the pressure switch.
If the pump runs continuously then try checking that the drain hose is not blocked or that the waste outlet is not blocked.
If that checks out OK then the pressure switch is stuck in the high level.
Take the capillary hose off from the pressure switch and blow down it to remove any residue stuck in the pipe.
Jan 14, 2011 | Daewoo DW500M Top Load Washer
Water pouring out from under my washer as it fills...
hello mam please check the rubber sleeve of the drum if there is any crack it should be replaced and check the drum if there is any holes in it, so please call the engineer and make him to check these.
Sep 29, 2009 | Washing Machines
Error code E8
Most likely a control or motor issue. Probably should call service.
Sep 15, 2017 | Daewoo Washing Machines
Washing Machines Logo
Top Daewoo Washing Machines Experts
Owen Barnes
Are you a Daewoo Washing Machine Expert? Answer questions, earn points and help others
