How I start philco front loader washing machine model pw60e
aborcass
  • 2651 Answers
SOURCE: need a manual
here you go
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Use%20and%20Care%20Guide%20-%208182271.pdf
Posted on Apr 29, 2008
  • 4 Answers
SOURCE: bosch front loader washing machine water pump?
Always check to see if the water waste (located normally at bottom right) has no foreign objects in their such as bobby pins, coins etc It has happened to me 3 times (first time cost me $150)
Posted on Jun 16, 2009
GodBlessU
  • 3513 Answers
SOURCE: Samsung J845 front loader washing machine. Error
Hi
An OE error presents if the washing machine has not successfully drained the water in ten minutes.
there are a few simple steps to take before calling for service.
Step 1: Check the drain pump filter.
Items caught in the drain filter will prevent proper drainage. Over time build up can occur from detergents and additives used in the machine. Manually drain unit through the drain hose, then lay a towel down to catch the water, and remove the filter. Clean the filter thoroughly and restart the machine.
Step 2: Check the washers drain hose.
If the drain hose is not installed properly, the washer will not drain properly. The drain hose should not be installed more than 1 meter higher than the bottom of the washing machine.
Step 3: Confirm that the washer is leveled properly.
If the unit is not leveled properly, it will not drain properly. The front of the unit cannot be higher than the back or vice versa. If not properly leveled, the water can flow back into the machine. If this is the cause of the problem, please level the machine using the supplied leveling wrench. When you place a level on the washing machine, the bubble should be in the center. Confrim that the washer is leveled from side to side and front to back.
you can perform a diagonal test when leveling the washing machine to ensure that the unit does not tilt from corner to corner.
Thanks for contacting fixya.com
Posted on Sep 30, 2009
jsrock516
  • 5911 Answers
SOURCE: Need the part # for the door seal for a GE front
The part number for the model you have listed is WH08X10036. I found your washer listed at pcappliancerepair.com, with a complete illustrated parts breakdown. Other sites you may try are:
searspartsdirect.com
appliancepartspros.com
repairclinic.com
NOTE: For your search criteria enter your model number a "WBVH6240H0WW".
I found the gasket listed at repairclinic.com and appliancepartspros.com for the best prices.
If you have any questions, please post back and let me know. I hope this helps you.
Posted on Mar 05, 2010
  • 177 Answers
SOURCE: miele front loader washing machine W3275- error co...
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
Posted on May 24, 2010
My washing machine model NA-F701p did'n spin it blink code H25 . What wrong with my washing machine ?
the model can refer to any make of washing machine and the code will be relevant to that make
posts are not linked so post your question again with make model year and type , top loader or front loader
Nov 06, 2016 | Washing Machines
Model 5000 front loader. Why doesn't pump work?
Whirlpool washing machine drain pump replacement and ...
? 17:45
www.youtube.com/watch?v=2abTptUYXH8
Feb 5, 2012 - Uploaded by HandySavesMoney The drain pump replacement procedure will apply to kenmore, whirlpool, maytag and other front-loading washing machines. ...does anybody knows about front loader whirlpool that won┬Ęt start? i could use some help tx.
Oct 07, 2015 | Whirlpool Washing Machines
Simpson washing machine
More info would be helpful (model? top loader/ front loader?)
If it fills then stops filling (ie. knows that it is full) yet does not turn, and no sounds etc, it is likely a motor control module or motor start capacitor or maybe PCB (If fully electronic). Does it spin if you manually turn the cycle to the spin point?
May 27, 2014 | Washing Machines
Philco dryer
Check the motor.
Jan 15, 2014 | Bosch Washing Machines
Have a front loader kenmore model # 41744052400 washing machine
Ours doesn't even spin. I'm trying to connect with a repair guy.
If we gets our repaired, I'll try to remember to get back to this page.
Good luck with yours.
Apr 07, 2010 | Kenmore Washing Machines
Which is better a top loader or front loader washing machine?
Front Loading Washing Machine: Fully automatic.
1. Better washing than toploading as technologically proofed.
2. No extra effort except putting cloths and detergent inside.
3. No need to observe in between while washing. Start and forgot. You can go market and come back.
4. No issue if electricity or water went out during washing.
4. Take more water compare to toploading semi-automatic.
5. You can not open it once it started.
Top Loading Washing Machine: Semi
1. Save water and detergent.
2. Need extra effort to put the cloth from one box to another.
Oct 10, 2009 | Washing Machines
PARTS FOR WASHING MACHINE
Try this link and enter your model number. You may be able to find the part you seek there. Sure hope so and best wishes.
http://www.spares2go.co.uk/browse-PHILCO-m290.htm
Aug 25, 2009 | Washing Machines
Water leak under the rotating drum
Have you removed the front panel?
If not remove front panel two screws 5/16 on bottom
Start the washer in a cycle. look with a flash lite and look for leak.
It maybe the rubber boot.
Please let me know if you have any other questions.
I will also need model number, because a AWS52NW is a top loader model number not a front loader.
T
Jul 27, 2008 | Speed Queen AWS52NW Top Load Washer
Washing Machines Logo
29 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
