Question about Hannspree Televison & Video
Hannspree ST25 - Potential Digital Tuner problem. When I switch the AV to DTV (digital) the screen goes off/black.
I know the screen itself is fine because when I first switch on the hannspree logo appears.Also if its been unplugged for a while and i switch it on, it defaults to the analogue AV and I can see the black and white fuzzy wuzzy picture so the screen is definitely fine. Then when i switch to DTV, the screen goes off.
  • 304 Answers
SOURCE: Samsung PS42q7hdx/xeu. digital pictures work fine but no sound i
Replace the Main bd.
Posted on Jul 17, 2009
diodeic
  • 1622 Answers
SOURCE: NEC - Model NLT-32HDB2. The DTV (digital receiver)
You can fix this, all that is needed is to carefully understanding the electronics parts used and having little of basic knowledge in electronics.
The problem is in either power supply or the Y sustain board. The Y sustain board is are relatively large board if out of which go connections to the side of the display , it therefore closer to either the left or the right side of the display , has at least one rather large heat sink on it and far power cables connecting it to the mains power supply .
Often there are fuses on that board , one or more , check them
If they are blown you can try to replace them, but expect them to blow again , usually the whole board needs to be replaced.
Often that need to be done in a service center as there are some adjustment to be made after replacement.
Posted on Aug 22, 2010
VOTIT
  • 2071 Answers
SOURCE: I have a 22" Hannspree HF 237 monitor about a year
It is the inverter problem maybe it is loose or cold solder already. You better open the unit and look for the inverter section then re solder all leg parts there.
Regards;
votit
Posted on Feb 08, 2011
  • 8457 Answers
SOURCE: My Hannspree 25" HF257 monitor
Ur tv have a dead 1 or 2 long board that call the LCD inverter boards.These 1 or 2 long LCD inverter boards job are to help the LCD screen panel to have a backlight to produced a picture.Tries websites like Shopjimmy.com,Ebay.com to buy those 1 or 2 long LCD inverter boards for the replacement.
Posted on Feb 28, 2011
SD Tech
  • 14553 Answers
SOURCE: I have a Hannspree ST42DMSB 42 in LCD TV and an intermittent problem with picture - these whie interfrence lines appear from time to time. I've been in touch with Hannspree and thier tech support
It is going to have to go to a service center for repair or replacement of a board or boards---if the reset did not fix it then it has a fault.
Posted on Apr 23, 2012
The DTV input in my GV46L stays black. Why?
You don't say what you are trying to input but take note that your model does not have a digital tuner on the DTV input. If you use a digital OTA antenna, the signal must first go through a digital converter or tuner before it goes into the DTV input. The DTV/ANT input is only cable ready. There is no digital tuner in the TV to activate the DTV menu.
Nov 02, 2012 | Vizio GV46L 46 in. LCD Television
Is jvc av-32d503 digital ready or do I need to buy a converter box for use with an outside antenna system
Looks like you'll need a converter.
Here's some background info:
Analog TVs were made up until 2007.
Digital tuners for over the air signals are called "ATSC tuners".
To tell if your TV has one:
-If the TV was sold as a "HDTV" or "DTV", it's supposed to have an ATSC tuner built in to it. "HD ready TVs" do not have a digital tuner.
-Check the specs in the owners manual or google the make & model of the TV to see if it has an ATSC tuner.
-If your TV's menu has an option for scaning for digital channels, then it has an ATSC tuner. If it dosen't have a way to scan for digital channels, then it doesn't have a digial tuner.
Most DTVs also have a digital QAM tuner that is used in some (but not all) cable systems.
Jun 11, 2011 | JVC AV-32D503 32" TV
Philips 32PFL5322D/37 Black w/any of the analog inputs. Tuner ok
WHEN IT BLACKS OUT, GENTLY PUSH OR TAP ON THE SCREEN. YOU SHOULD SEE A SLIGHT WHITE DISCOLORATION WHERE YOUR PUSHING. IF THIS HAPPENS YOU PROBABLY NEED A MAIN TOTAL ASSY. DO YOU STILL HAVE AUDIO WHEN IT BLACKS OUT?
Sep 25, 2009 | Philips Televison & Video
Have digital TV have 3 yr old sony VHS VCR DVD player combo
A DTV converter box will take digital broadcast signals from the antenna and convert them to a format compatible with the VCR. You will be able to record programs received through the DTV box on your VCR if you could record analog over-the-air programs before the digital changeover. You can use either the RF output or the component output from the DTV box to input to the VCR.
Jun 30, 2009 | Quasar VHQ400 VHS VCR
Have a vizio lcd tv . can not get any channels today with the switch over to digital. i use an antenna
Your TV probably does not have a digital tuner connected to the DTV/ANT input. Mine didn't. I had to connect the digital antenna to a digital converter box THEN go to the DTV/ANT input. Only then would it activate the DTV menu and allow me to scan for channels. If your TV worked fine with Cable TV connected to the input, it was because your signal was coming from the digital tuner in your DVR, or your cable provider was sending you an unscrambled digital signal (not likely).
I used a digital converter box I had purchased with the government $40 coupon back in 2009 but the resolution is only 480 and looks like a Monet or Renoir. Now I am shopping for a high quality tuner.
Jun 13, 2009 | Vizio L32 32 in. LCD HDTV
Is this TV digital ready
According to http://www.dtv.gov/consumercorner.html#faq9
How can I be sure that I am buying a digital TV (DTV)?
By law, beginning March 1, 2007, all television reception devices (including TVs, VCRs, DVRs, etc.) imported into the U.S. or shipped in interstate commerce must contain a digital tuner. Retailers may continue to sell analog-only devices from existing inventory, but must prominently display on or near the analog-only device a Consumer Alert label with this advisory:
What is the difference between “Integrated” DTVs and DTV or HDTV “Monitors”?
An Integrated DTV set is a television with a built-in digital tuner (also referred to as “a DTV”). A digital tuner is also sometimes called a DTV decoder or DTV receiver. If you have an Integrated DTV, you will not need any additional equipment, with the exception of a broadcast antenna (either a rooftop antenna or “rabbit ears” connected to the set), to receive over-the-air digital broadcast programming. Integrated DTVs can also receive and display analog broadcast programming, so you can continue watching analog broadcasts.
In contrast, a DTV Monitor is not capable of receiving digital broadcast programming without additional equipment; it is simply a display device without the processing capability for DTV reception. A digital or HD set-top box must be connected between the antenna and the monitor to receive and display over-the-air digital or HD programming.
If you have a digital or HD “Monitor” and would like to purchase a digital or HD set-top box to view over-the-air programming, confirm with your retailer that the set-top box is compatible with your Monitor.
Feb 12, 2009 | Recoton Advent Advent TS2066A TV
Do I Need A Convertor Box?
No, your television has a digital tuner built in. You will not need a converter box. When the switch to digital is made, simply use the auto scan feature to program all of the new channel locations. Instructions found in the manual here - http://www.p4c.philips.com/files/2/26pf5321d_37/26pf5321d_37_dfu_aen.pdf
Dec 27, 2008 | Philips TV Tuner Video Capture PCI Card -...
Programming a ATSC DTV tuner on a RCA Universal Remote
Try a code for a "satellite receiver" of the same manufacturer of your DTV tuner. I've heard of a cross-remote complaint with the DirectTV box and the DTVPal box. Note, your DTV tuner may say RCA, but it could be manufactured by a common DTV tuner maker. The system looks very close to a Zinwell. Don't have an RCA model to try the codes out, though.
Dec 27, 2008 | Televison & Video
DTV Question
Based on the features described by JVC and the technical details listed on Amazon.com the answer is no, no digital ATSC tuner, just NTSC analog.
So yes, she'll need a converter box for the ATSC over the air signals.
Jan 16, 2008 | JVC AV-27D201 27" TV
Televison & Video Logo
Top Hannspree Televison & Video Experts
Are you a Hannspree Televison and Video Expert? Answer questions, earn points and help others
