Question about The Office Equipment & Supplies
How do I get the points I have
Scan number 3081 4720 0195 2818
How to use the launch scan tool reset the code p1589
I believe most if not all scan tools have a means to reset (clear all errors). the automobiles On Board Computer.
P stands for powertrain
Apr 03, 2016 | Cars & Trucks
What's your question? my konica minolta c451e printing machine showed me an error code p21, what could that mean and it is not printing any image but black-green shade
P-21 - Color regist test pattern failure
• The number of points detected in the main scan direction is more or less than the specified value during main scan direction registration correction.
• The number of points detected in the sub scan direction is more or less than the specified value during sub scan direction registration correction.
P-21: Color regist test pattern failure
Relevant parts:
• Transfer belt unit
• PH unit
• Printer control board (PRCB)
Step/Action:
1/ Wipe clean the surface of the transfer belt with a soft cloth, if it is dirty.
2/ Change the image transfer belt unit if the transfer belt is damaged.
3/ Change the PH unit.
4/ Change PRCB.
(See Service Manual, pages 599, 603):
http://www.imcopexamerica.com/service-books/Bizhub/Color/bizhubC451_C550_C650FieldSvc.pdf
See also here:
Konica Minolta Bizhub c451 Reparacin de Fotocopiadoras YoReparo
Thread Problemas na C451 7 21
May 31, 2015 | Konica Minolta Office Equipment & Supplies
We have a computer set up with Windows 7 and we cant scan from the printer to the computer or vise vera....any suggestions
Sure,
Find the make and modle of the scanner/printer combo and install the driver software from the maufacture website. This will help big time.
Without software that scan button is just a hotkey that points to nothing. You need software to scan. If you have software and it still does not scan then you got a hardware issue that needs to be diagnosed after witch your model number ad make would go a long way here on Fixya.com.
Thanks
We work for reviews!
Rulds2008
Aug 23, 2011 | Office Equipment & Supplies
When we scratched the card half the numbers came off how do we get the numbers to work does the barcode scan tell u the numbers??? thanks
u have to tell that to nintendo. they should give you the code. i think their num. is 1800 255 3700 and u have to press 0 to speak to them. next time, be careful with scratching.
Apr 24, 2011 | Nintendo 2000 Points Card for Wii or DSi -...
My scanner will only scan bank 1 and 2
When your scanner is scanning normally (in only banks 1 and 2 at this point) just hit the number for the banks you want to scan. To remove a bank push that number again. Make sure it the scanner is actually scanning when you do this.
Regards, Tony
Apr 22, 2011 | Radio Shack Pro-82 Scanner
How do you put the numbers in or just get the scanner to scan i have a undiden bearcat BC340CRS
Hi, my name is John. Welcome to FixYa. You can get your frequency,s here www.RadioReference.com . To program your unit, press the PROG. button, then enter the channel you want to store it in on the number pad including the decimal point, ./DELAY, press the ENTER button, then SCAN button. Good luck and thanks for choosing FixYa....John
Nov 04, 2010 | Uniden BC350C Base Scanner
How do I scan a picture
Scan in Windows without Using HP Software
Scanning with PaintTo scan a document using Paint in follow these steps:
  1. Click Start , point to All Programs , point to Accessories , and then clickPaint .
  2. Click File , and then click From Scanner or Camera .
  3. Make any desired setting changes.
  4. Click Scan .
Sep 06, 2010 | HP Photosmart 2575 All-In-One Printer,...
Cant get wireles signal, i just switched service providers and can not pick up wireless signal.
Do a channel scan before you call provider and ask them to change it to a channel number that is not being occupied. Ask you provider to change your channel number on your router? You and your neighbor is sharing the same channel number. One is over powering the other.
Dec 09, 2009 | Linksys Wireless-G WGA54G 802.11g/b...
How do I find out what my wep number is. lost the manual
You can locate the Wireless Network Security key (WEP key) by login to the Access Point or Router.
Or using any third party utilities which will scan the saved WEP key from the Computer.
Good Luck!!!!!!!
Oct 28, 2009 | Apple AirPort Extreme Base Station
Laserjet 2840. Not able to scan. When I hit the scan to button, it says not set up on PC. I have turned both printer and PC off and on again to reset but didnt help.
There have been a number of problems identified with the software for this all-in-one. Some pertain to USB connect and some to network.
After installing the printer you will need to set up the "Scan to Button" through the HP Director. Open this user interface from your desk top and click on Settings, then scan settings and preference, then scan to setup. Make sure that the feature is turned on and that you have selected a folder to scan to. Click the apply button once you have made your selections. At this point try the button to see if it is working. If not, from the same location outlined above try turning the scan to feature off and then on again. If the scan to button still does not work, hard boot your PC (shut it down complete) and then restart.
Jan 12, 2009 | HP LaserJet 2840 Printer
23 people viewed this question
Top The Office Equipment & Supplies Experts
Victorman
Victorman
micky dee
fhonwizards
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
